Home » Eclipse Projects » Eclipse Platform » Estimation of the testing efforts on Eclipse plateform SDK based on package leve
Estimation of the testing efforts on Eclipse plateform SDK based on package leve [message #310567] Fri, 08 December 2006 07:47
Originally posted by: akalvi.ccse.kfupm.edu.sa
Hello:
I divide my query into more elaborative way through which you can easily
understand what I need to know.
Objective:
Based on available source code and JUnit test code of Eclipse platform I
want to evaluate the package level functional testing in corresponding to
the efforts done for the testability. Also I want to find the reflection
of the testing efforts in corresponding to the package level Metrics.
Research Problem:
Our methodology is to accomplish the empirical study for the evaluation of
a set of object-oriented package level metrics in relation to predict the
effort require for the testing activities. These metrics which has the
known effect on testing effort inform us to determine the real factors
which affect the testability of the system. These results may come up to
final set of refine metrics which has significant effect on testability of
the system.
Questions:
We have opened every folder in the Eclipse platform SDK and corresponding
to the JUnit test folder of the Eclipse platform. We try to find the
efforts in the form of the corresponding same packages for testing to be
written in JUnit.
a- We have seen the problem that if we have selected any package
from Eclipse testing folder i.e C:\Eclipse JUnit
test\eclipse-testing\eclipse\plugins
and corresponding source folder C:\eclipse-SDK-3.2-win32-latest
release\eclipse\eclipse\plugins we found that they are different in
version number.
How we identify JUnit test folder which is written for test the
folder. In short how can we find the pair <source, test> in package
or other level?
b- Which files is showing the package level test information; through
that we can
understand the package level functional testing in Eclipse?
c- Is in the download option in www.eclipse.org all source code and test
code of Eclipse
available. (Because I found no .java files after un jar the .jar
files in some test code or
source )
d- There is any tutorial available for information about how package
level functional
testing was done in Eclipse project.
I hope for the positive reply as soon as possible.
Aleem Alvi
Previous Topic:Update PropertiesView on context menu action
Next Topic:Updating Projects
Current Time: Thu Oct 30 11:49:36 EDT 2025
Powered by FUDForum. Page generated in 0.05806 seconds
