Home » Eclipse Projects » Eclipse Platform » The type org.eclipse.core.resources.IFile cannot be resolved. It is indirectly referenced from , req
The type org.eclipse.core.resources.IFile cannot be resolved. It is indirectly referenced from , req [message #310508] Wed, 06 December 2006 09:14 Go to next message
Hi all,
I've got a problem using IFileEditorInput. After adding
org.eclipse.ui.ide to the dependencies of my plug-in the following error
appears while trying to use the IFileEditorInput.getFile() method.
indirectly referenced from required .class files
What can I do to fix this?
Jan
Re: The type org.eclipse.core.resources.IFile cannot be resolved. It is indirectly referenced from , [message #310509 is a reply to message #310508] Wed, 06 December 2006 09:18 Go to previous messageGo to next message
Jan,
Add org.eclipse.core.resources to the plugin dependencies. For any
other issue like this, use Ctrl-Shift-T to find the class, use the
little left-right arrow in the navigator/project explorer to find out
where that class lives, and then add the containing plugin to the
dependencies.
Jan Weidauer wrote:
> Hi all,
> Jan
Re: The type org.eclipse.core.resources.IFile cannot be resolved. It is indirectly referenced from , [message #311141 is a reply to message #310509] Sun, 31 December 2006 14:12 Go to previous message
Originally posted by: mcfaddin.us.ibm.com
Ed, Jan,
I have a similar problem with IFile -- except it happens at run time. I
have a snippet of code in a menu action delegate that checks the current
selection to see if it is a file, e.g.
ISelection current_selection = null;
public void selectionChanged(IAction action, ISelection selection) {
current_selection = selection;
public void run(IAction action) {
if( current_selection instanceof IStructuredSelection ) {
IStructuredSelection s = (IStructuredSelection) current_selection;
Object ob = s.getFirstElement();
IFile ifile = null;
if( ob instanceof IFile ) ifile = (IFile) ob;
.. code to open and read the file ..
At runtime I get a NoClassDefFoundError thrown at the "instanceof IFile"
evaluation. Doesnt seem to happen on the preceeding "instanceof
IStructuredSelection" evaluation, however.
I have org.eclipse.core.resources in my plugin dependencies but it looks
like the runtime can't get at the IFile class def. Do I need to force the
loading of the org.eclipse.core.resources plugin? Any idea what I am
missing? I'm not an eclipse expert so this is probably something really
simple.
FYI I'm testing the plugin in my WID 6.0.1 environment.
Thanks!
Previous Topic:Trying to use the ANT-Editor for Canoo Webtest
Next Topic:Load external File / Where is EFS?
Current Time: Sun Oct 26 05:01:28 EDT 2025
Powered by FUDForum. Page generated in 0.40435 seconds
