Home » Eclipse Projects » Eclipse Platform » Get effective file attributes with IFileStore
Get effective file attributes with IFileStore [message #310137] Wed, 22 November 2006 14:46
Originally posted by: daniel4321.terra.com.br
--=-CBsko1YE5YYvDtwppBLM
Content-Type: text/plain
I was using !
IFileStore.fetchInfo().getAttribute(EFS.ATTRIBUTE_READ_ONLY) to check if
a directory is writeable.
I noticed that this check return true if the owner of the file has +w
permissions, but not if the user has effective permissions.
For example, suppose a directory owned by root and that has write
permissions only for root. A user, eg daniel, will call
IFileStore.fetchInfo().getAttribute(EFS.ATTRIBUTE_READ_ONLY) and return
false, meaning that it is possible to write to the directory. But
actually, daniel has not permission to write the directory only root.
Did someone also have this problem?
Daniel F
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.10.3">
</HEAD>
<BODY>
Hi,<BR>
<BR>
I was using ! IFileStore.fetchInfo().getAttribute(EFS.ATTRIBUTE_READ_ONLY) to check if a directory is writeable.<BR>
I noticed that this check return true if the owner of the file has +w permissions, but not if the user has effective permissions.<BR>
<BR>
For example, suppose a directory owned by root and that has write permissions only for root. A user, eg daniel, will call IFileStore.fetchInfo().getAttribute(EFS.ATTRIBUTE_READ_ONLY) and return false, meaning that it is possible to write to the directory. But actually, daniel has not permission to write the directory only root.<BR>
<BR>
Did someone also have this problem?<BR>
<BR>
Best regards,<BR>
Daniel F
</BODY>
</HTML>
--=-CBsko1YE5YYvDtwppBLM--
Previous Topic:Tabbed property sheet question
Next Topic:Open the select file window
Current Time: Sun Nov 09 07:43:44 EST 2025
Powered by FUDForum. Page generated in 0.02823 seconds
