| Namespace reporting is not ebavled [message #2685] |
Sun, 24 August 2008 08:06  |
Hello all,
I'm trying to hunt some leak using mat. I've generated an heap dump using
jmap. The dumo loaded by mat, but when clicking on Leak Suspects, an
exception is raised: java.io.IOException parser configuration problem:
namespace reporting is not enabled.
What should I configure in order to make the Leak suspects report working?
Barak.
| Re: Namespace reporting is not enabled [message #3120 is a reply to message #3095] |
Mon, 25 August 2008 07:22   |
Thanks for helping, and sorry for the typos in the previous post...
So, I download the standelone Eclipse Memory Analyzer from
www.eclipse.org. I'm running Windows XP, professional edition, Java
version is:
java version "1.6.0_02"
Java(TM) SE Runtime Environment (build 1.6.0_02-b06)
Java HotSpot(TM) Client VM (build 1.6.0_02-b06, mixed mode).
The dump was created on linux box (Centos5, same jdk), using jmap.
Here is the stack:
eclipse.buildId=unknown
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Mon Aug 25 14:12:14 IDT 2008
java.io.IOException: Parser configuration problem: namespace reporting is
not enabled
The other 2 frames in the stack (somehow I cant copy them) show exactly
the same: Parser configuration problem: namespace reporting is not enabled.
Thanks for any help, I'll try to open the bug soon.
Barak.
FUDForum. Page generated in 0.05066 seconds
