Home » Eclipse Projects » Eclipse Platform » Eclipse Misreading Installed JVM Version
Eclipse Misreading Installed JVM Version [message #309337] Tue, 24 October 2006 19:15 Go to next message
Originally posted by: Andrew.Morrow.cityofhenderson.com
Every indication that I can pull up - including sun's site at
http://java.com/en/download/help/testvm.xml are saying that I'm running
1.5.0_06. I try running the eclipse IDE and I get the following error:
Version 1.3.1_01 of the JVM is not suitable for this product. Version
1.4.1 or greater is needed.
I have uninstalled and reintalled Java SE as well as doing a registry
search for JAVA, JVM and 1.3.1 and turned up no likely culprits.
I am running Windows XP SP2 in a corporate environment with administrator
priv's.
Advice?
Re: Eclipse Misreading Installed JVM Version [message #309338 is a reply to message #309337] Tue, 24 October 2006 19:22 Go to previous messageGo to next message
Answer found myself moments after posting. I added the following to my
environment variables in the path and it worked instantly:
C:\Program Files\Java\jre1.5.0_06\bin
Hope this helps someone else
Re: Eclipse Misreading Installed JVM Version [message #309354 is a reply to message #309338] Wed, 25 October 2006 04:29 Go to previous messageGo to next message
> my environment variables in the path and it worked instantly:
This is a bad idea. Use -vm C:\Program
Files\Java\jre1.5.0_06\bin\java.exe when starting eclipse.
Dani
Re: Eclipse Misreading Installed JVM Version [message #309370 is a reply to message #309354] Wed, 25 October 2006 09:32 Go to previous messageGo to next message
Originally posted by: jay.askren.com
What's wrong with that? It just means that Andrew is using Java 1.5 by
default for everything. There's nothing wrong with that.
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:ehn796$r8u$2@utils.eclipse.org...
> This is a bad idea. Use -vm C:\Program Files\Java\jre1.5.0_06\bin\java.exe
> Dani
Re: Eclipse Misreading Installed JVM Version [message #309376 is a reply to message #309370] Wed, 25 October 2006 11:26 Go to previous message
There is. Assume that there was also a 1.3 (or whatever) VM on the path
and the tool that installed it expect 1.3. It is always best to
explicitly specify the VM if possible.
Dani
>>Dani
Previous Topic:bugzila help missing one severity level
Next Topic:possible wordrule memory usage bug
Current Time: Sat Nov 01 19:42:27 EDT 2025
Powered by FUDForum. Page generated in 0.03538 seconds
