Home » Eclipse Projects » Eclipse Platform » JavaFileEditorInput vs IEditorInput
JavaFileEditorInput vs IEditorInput [message #308712] Mon, 02 October 2006 11:30 Go to next message
Originally posted by: diebosto.fi.vupv.es
Hi!
i want to change my JavaFileEditorInput references on my code (because it
has discouraged access). I have read that i should change it for
IEditorInput. Is that correct?
Do I have to make my own editor or there is already one already created?
Thanks!
Re: JavaFileEditorInput vs IEditorInput [message #308760 is a reply to message #308712] Mon, 02 October 2006 20:27 Go to previous messageGo to next message
Diego Bosca wrote:
> Hi!
> Thanks!
For IFiles, there's already a FileEditorInput that's public API (in
org.eclipse.ui.ide)
Later,
PW
Re: JavaFileEditorInput vs IEditorInput [message #308772 is a reply to message #308760] Tue, 03 October 2006 03:30 Go to previous messageGo to next message
On 03 oct 2006, you wrote in eclipse.platform:
> Diego Bosca wrote:
>> Hi!
>> (because it has discouraged access). I have read that i should change
>> it for IEditorInput. Is that correct?
>> created? Thanks!
> org.eclipse.ui.ide)
> Later,
> PW
Thanks for your reply
I did this, but the FileEditorInput needs an IFile and with
" org.eclipse.core.filesystem.EFS.getLocalFileSystem().getStor e(path) "
I get a IFileStore...
is there any way to get an IFile from the filesystem?
thanks!
Re: JavaFileEditorInput vs IEditorInput [message #308826 is a reply to message #308772] Wed, 04 October 2006 13:18 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
>> Diego Bosca wrote:
>>> Hi!
>>> change it for IEditorInput. Is that correct?
>>> created? Thanks!
>> org.eclipse.ui.ide)
>> Later,
>> PW
> thanks!
You cannot get an IFile for a file which is not part of the workspace.
For such cases, either you bite the bullet and use JavaFileEditorInput or
create a local copy of it which you can call whatever you want.
Sunil
Re: JavaFileEditorInput vs IEditorInput [message #308840 is a reply to message #308826] Thu, 05 October 2006 03:55 Go to previous messageGo to next message
"Sunil Kamath" <sunil_kamath@nohotspammail.com> wrote in
news:eg0qco$vrg$1@utils.eclipse.org:
>>> Diego Bosca wrote:
>>>> Hi!
>>>> created? Thanks!
>>> org.eclipse.ui.ide)
>>> Later,
>>> PW
>> thanks!
> or create a local copy of it which you can call whatever you want.
JavaFileEditor input has discouraged access so it won't let me access it
.. But no problem, i have created a ficticious project and file so i can
link the external file to it and then all goes right
Thanks all!!
Re: JavaFileEditorInput vs IEditorInput [message #308927 is a reply to message #308772] Tue, 10 October 2006 04:32 Go to previous message
>>Diego Bosca wrote:
>>>Hi!
>>>created? Thanks!
>>org.eclipse.ui.ide)
>>Later,
>>PW
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=111887
No.
Dani
>thanks!
Previous Topic:TextEditor File Saving
Next Topic:Having trouble opening java editor on file
Current Time: Thu Jul 17 13:26:58 EDT 2025
Powered by FUDForum. Page generated in 0.36438 seconds
