Feature plugin will not export [message #308332] |
Tue, 19 September 2006 18:36  |
Originally posted by: miles.daffin.morganstanely.com
Esteemed Eclipse People,
I have a new feature project that includes a plugin which was manually
installed into the ide by dropping it into the plugins directory. This
plugin was not installed as part of another feature.
When I attempt to export the new feature all seems to go fine. No errors
reported or in the logs. But when I check the exported plugins dir only
the plugin base dir and plugin.xml have been exported. The lib and its
jars are nowhere to be seen. I have checked and, yes, the lib jars are all
there in the eclipse/plugins/myplugin/lib dir.
Can any one please tell me what may be the problem here? I need some sleep
Miles
Re: Feature plugin will not export [message #308351 is a reply to message #308332] |
Wed, 20 September 2006 08:14  |
> all there in the eclipse/plugins/myplugin/lib dir.
If you just export myplugin (Deployable plug-ins and fragments), does it
copy out the myplugin/lib dir? i.e. is it listed in your
build.properties file?
Later,
PW
Re: Feature plugin will not export [message #308362 is a reply to message #308351] |
Mon, 18 September 2006 10:41  |
Whether or not your myplugin is treated as a binary plug-in is
determined by whether or not it has a build.properties file.
If it does not have this file, then the whole plug-in should have been
copied. If it does have a build.properties, then, as Paul mentioned,
you need to specify in there which files are to be included in the plug-in.
-Andrew
>> errors reported or in the logs. But when I check the exported plugins
>> dir only the plugin base dir and plugin.xml have been exported. The
>> lib and its jars are nowhere to be seen. I have checked and, yes, the
>> lib jars are all there in the eclipse/plugins/myplugin/lib dir.
> Later,
> PW
FUDForum. Page generated in 0.03895 seconds
