Home » Eclipse Projects » Eclipse Platform » Cannot load the language pack in my RCP application
Cannot load the language pack in my RCP application [message #308018] Fri, 08 September 2006 16:08 Go to next message
Originally posted by: bnegrao.gmail.com
Hi guys,
I'm trying to make the RCP application I'm developing to run in my
language (pt_br). When i run my application, all the dialogs continue to
show english strings like OK, CANCEL, APPLY, RESTORE DEFAULTS,
PREFERENCES, etc.
I think I installed the language packs on my classpath, as I should, but
it's not working.
What I did until now is, I downloaded the language packs for RCP SDK for
linux and windows:
http://download.eclipse.org/eclipse/downloads/drops/L-3.2_La nguage_Packs-200607121700/download.php?dropFile=NLpack1-ecli pse-RCP-SDK-3.2-win32.zip
http://download.eclipse.org/eclipse/downloads/drops/L-3.2_La nguage_Packs-200607121700/download.php?dropFile=NLpack1-ecli pse-RCP-SDK-3.2-gtk.zip
I extracted them, put installed them on my PDE target directory. Reloaded
the PDE to find those fragments.
I even imported the *nl1* jars to my rcp project and added them to my
plugin's classpath by following the hints given by PW on his post at:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg48 366.html
But it's still not working. Any idea of how can I get this to work?
thank you,
bruno.
Re: Cannot load the language pack in my RCP application [message #308040 is a reply to message #308018] Mon, 11 September 2006 05:42 Go to previous messageGo to next message
did you try to start you application with the -nl attribute ?
ex. in Windows : "eclipse.exe -nl fr" will start your eclipse in French
Nicolas
Bruno Negrao a écrit :
> Hi guys,
> PREFERENCES, etc.
> it's not working.
> linux and windows:
> Reloaded the PDE to find those fragments.
> thank you,
> bruno.
Re: Cannot load the language pack in my RCP application [message #308054 is a reply to message #308040] Mon, 11 September 2006 10:54 Go to previous message
Nicolas Bihan wrote:
> Hello,
Hi Nicolas, I just discovered what was going wrong.
The *nl1* fragments were not being exported to the RCP product ZIP file.
To set them to be exported I had to go on the Package Explorer -> Click on
the "XXX.product" file -> Configuration tab. There is a "Plugins and
Fragments" box where I had to add each language pack fragment
individually. Save the configuration.
After that, the language packs were exported and everything worked.
thank you,
bruno
Previous Topic:Eclipse logging and debugoptions
Next Topic:accessing an image file in plugin.xml
Current Time: Fri Nov 21 11:07:57 EST 2025
Powered by FUDForum. Page generated in 0.04898 seconds
