Linked Resource Problem [message #307021] |
Fri, 11 August 2006 13:12  |
Originally posted by: optimator.cox.net
Ok, so I have a Project that is itself linked. Within the project is a
configuration folder which has a configuration file.
When I find that configuration file resource, the Path is wrong.
Ex:
AProject - (Linked)
- src
- config
- Config.txt
IFile theFile = aProject.getFile("Config.txt");
String path = theFile.getFullPath().toString();
The path is "/AProject/Config.txt"
Should I be finding the resource a differen way? Is this a bug?
Any information would be greatly appreciated.
Mike
Re: Linked Resource Problem [message #307195 is a reply to message #307021] |
Tue, 15 August 2006 13:29  |
Originally posted by: john.eclipsefaq.org
Although I don't know what you mean by a linked project, I suspect you
are looking for the file system location of the file, obtained via
IResource.getLocationURI(). The getFullPath() method just returns the
logical path of that resource within the workspace, i.e.,
"/ProjectName/FolderName/FileName", regardless of where the project,
folder, and file are stored on disk.
> Ex:
> AProject - (Linked)
> - src
> - config
> - Config.txt
> Mike
FUDForum. Page generated in 0.03705 seconds
