Home » Eclipse Projects » Eclipse Platform » Source Editor
Source Editor [message #306846] Mon, 07 August 2006 14:14 Go to next message
I have a very simple question about the Source Editor. On certain
platforms/JRE combinations (primarily Linux OS) - the source editor
behaves very differently. A simple case would be when you open the
preferences of the SourceEditor and check the show line numbers
checkbox. This should show the line numbers in the source editor.
This is shown on certain platform/os combination and not on all of them
and also you can see the line numbers in certain perspective and not on
others. Is there a way to force the editor to show the line number
information?
Re: Source Editor [message #306858 is a reply to message #306846] Tue, 08 August 2006 02:34 Go to previous messageGo to next message
Originally posted by: tom_eicher.ch.ibm.com
What editor do you refer to by "Source Editor"? The Java editor? It
should always respect the line number ruler preference.
If you are talking about your own editor implementation, it depends on
how you set it up. Generally, an editor subclassing
AbstractDecoratedTextEditor with a preferences store that contains
EditorsUI.getPreferenceStore should also respect the preference.
-tom
> information?
Re: Source Editor [message #306877 is a reply to message #306858] Tue, 08 August 2006 11:13 Go to previous messageGo to next message
> -tom
>> them and also you can see the line numbers in certain perspective and
>> not on others. Is there a way to force the editor to show the line
>> number information?
Tom,
I am referring to the Java Editor.
Re: Source Editor [message #306879 is a reply to message #306877] Tue, 08 August 2006 11:42 Go to previous messageGo to next message
>>> number information?
The Java editor should always respect the line number ruler preference.
Please file a bug against jdt-text if you have reproducible steps to
reproduce this problem.
thanks, tom
Re: Source Editor [message #306885 is a reply to message #306879] Tue, 08 August 2006 13:11 Go to previous message
>>>> and not on others. Is there a way to force the editor to show the
>>>> line number information?
> thanks, tom
Will do Thanks Tom.
Previous Topic:Product Configuration Files?
Next Topic:updates
Current Time: Wed Oct 22 20:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.34315 seconds
