Announcement: Please use Eclipse OCL Discussions |
14774 |
Wed, 12 February 2025 08:59 By: Eclipse Webmaster  |
Issues Extending OCL Primitive Type String with Custom Operations in Ecore By: Eclipse User on Tue, 22 October 2024 |
1360 |
Tue, 22 October 2024 03:01 By: Eclipse User  |
OCL2QVTiTransformationTechnology [org.eclipse.qvtd.cs2as not available] By: Eclipse User on Sat, 24 August 2024 |
3042 |
Fri, 11 October 2024 09:18 By: Eclipse User  |
OCL import ecore model By: Eclipse User on Mon, 07 October 2024 |
1222 |
Tue, 08 October 2024 04:10 By: Eclipse User  |
UML-OCL ; specifying constraints in the context of an association / association class By: Eclipse User on Tue, 12 April 2016 |
191 |
35852 |
Sun, 25 August 2024 07:50 By: Eclipse User  |
Experiences from validation of CIMXML data Using OCL to validate CIMXML data By: Eclipse User on Sun, 14 July 2024 |
1604 |
Sun, 14 July 2024 02:30 By: Eclipse User  |
how to merge two collections By: Eclipse User on Sat, 24 November 2012 |
4768 |
Fri, 19 April 2024 11:51 By: Eclipse User  |
Migration of "Sequencer" dependencies Questions on migrating to newer OCL versions (from 2021 to 2024) By: Eclipse User on Fri, 15 March 2024 |
1284 |
Fri, 15 March 2024 11:13 By: Eclipse User  |
Drops and Updates are now Builds By: Eclipse User on Fri, 08 March 2024 |
1563 |
Fri, 08 March 2024 11:51 By: Eclipse User  |
IllegalStateException when editing Complete OCL file OCL causes a lot of problems, including spurious error dialogs and errors on editing file, usually with a message like "Cannot modify resource without a transaction" By: Eclipse User on Wed, 21 February 2024 |
2147 |
Mon, 26 February 2024 14:05 By: Eclipse User  |
Generating OCLinEcore Code By: Eclipse User on Mon, 19 February 2024 |
1344 |
Tue, 20 February 2024 08:48 By: Eclipse User  |
Does OCL 6.19 / SimRel 2023-12 disable OCL ValidityView? By: Eclipse User on Sat, 09 December 2023 |
1852 |
Thu, 15 February 2024 13:22 By: Eclipse User  |
LSP / Web based version of ValidityView By: Eclipse User on Thu, 01 February 2024 |
7074 |
Fri, 02 February 2024 09:31 By: Eclipse User  |
Unable to install OCL 6.19 Tests in 2023-12 By: Eclipse User on Mon, 11 December 2023 |
1904 |
Tue, 26 December 2023 11:54 By: Eclipse User  |
OCL syntax on association ends By: Eclipse User on Fri, 15 December 2023 |
1095 |
Sat, 16 December 2023 11:27 By: Eclipse User  |
Examples of def: taking OclLambda parameter? Are there examples of OCL def: that take an OclLambda as a parameter? By: Eclipse User on Tue, 03 October 2023 |
1995 |
Thu, 16 November 2023 10:44 By: Eclipse User  |
Current Maven/ Gradle Repository for OCL By: Eclipse User on Tue, 07 November 2023 |
13963 |
Tue, 14 November 2023 16:00 By: Eclipse User  |
Annotation error in OCL development environment By: Eclipse User on Thu, 02 November 2023 |
1853 |
Sat, 04 November 2023 05:50 By: Eclipse User  |
Non-deterministic error with OCL validation in Xtext project CompleteOCLEObjectValidator experiences semi-reproducible stack traces. Perhaps race condition during initialization? By: Eclipse User on Thu, 15 March 2018 |
9418 |
Tue, 03 October 2023 08:53 By: Eclipse User  |
Failed to evaluate 'OclElement::allInstances() : Set(OclSelf)' for ... By: Eclipse User on Tue, 29 August 2023 |
3182 |
Fri, 29 September 2023 14:57 By: Eclipse User  |
Retrieving EEnumLiteral attributes By: Eclipse User on Thu, 21 September 2023 |
1337 |
Fri, 22 September 2023 05:59 By: Eclipse User  |
Calling out from OCL to Java OCL to Java calls By: Eclipse User on Wed, 26 July 2023 |
2747 |
Mon, 28 August 2023 12:57 By: Eclipse User  |
Invariant both passes and fails ?? Same invariants both pass and fail on the same model at the same time By: Eclipse User on Thu, 03 August 2023 |
2484 |
Sun, 20 August 2023 12:05 By: Eclipse User  |
OCL with Xtext Artifacts By: Eclipse User on Tue, 03 May 2022 |
2932 |
Tue, 25 July 2023 16:01 By: Eclipse User  |
Validation Delegate noy found Looking for dynamic ecore example using validation delegate By: Eclipse User on Thu, 23 February 2023 |
3287 |
Fri, 24 February 2023 00:51 By: Eclipse User  |
OCLinEcore. How the set a attribute of type java.lang.Locale By: Eclipse User on Thu, 23 June 2022 |
3682 |
Fri, 24 June 2022 10:36 By: Eclipse User  |
Check stereotype applications via static profile Write a query that checks stereotype applications By: Eclipse User on Fri, 10 June 2022 |
5578 |
Sat, 18 June 2022 06:28 By: Eclipse User  |
How could I add org.eclipse.ocl as a dependency How could I add org.eclipse.ocl as a dependency By: Eclipse User on Tue, 29 March 2022 |
2764 |
Wed, 30 March 2022 05:22 By: Eclipse User  |
Get annotations from type rather than instance By: Eclipse User on Thu, 03 February 2022 |
3746 |
Fri, 04 February 2022 11:21 By: Eclipse User  |
Can not gen emf-gen from ecore file based on generator (.mwe) of OCL open source Can not gen emf-gen from ecore file based on generator (.mwe) of OCL open source By: Eclipse User on Mon, 06 December 2021 |
4775 |
Wed, 15 December 2021 03:44 By: Eclipse User  |
Getting invalid for the evaluation of OCL on XMI By: Eclipse User on Thu, 09 December 2021 |
1604 |
Thu, 09 December 2021 13:42 By: Eclipse User  |
Calling an EMF Java function from OCL constraint OCL invariant constraint fails to evaluate because it calls an EMF Java function By: Eclipse User on Mon, 15 November 2021 |
2323 |
Thu, 18 November 2021 22:57 By: Eclipse User  |
OCL expression not evaluated oclIsUndefined works in a loop but not in ->select(exp) or exists->select(exp) By: Eclipse User on Wed, 02 June 2021 |
2087 |
Wed, 02 June 2021 17:03 By: Eclipse User  |
Issue with mdt-ocl-Update sites By: Eclipse User on Tue, 02 February 2021 |
2827 |
Wed, 03 February 2021 01:02 By: Eclipse User  |
Generate Java code for generic classes By: Eclipse User on Mon, 01 February 2021 |
2711 |
Tue, 02 February 2021 23:25 By: Eclipse User  |
Missing Javadoc The Javadoc for several packages are missing but jar file is in plugins folder By: Eclipse User on Thu, 28 January 2021 |
2467 |
Fri, 29 January 2021 06:21 By: Eclipse User  |
Get the query result from OCL Java API in the format of XText OCL result By: Eclipse User on Wed, 13 January 2021 |
1488 |
Wed, 13 January 2021 14:02 By: Eclipse User  |
run OCL on models programmatically By: Eclipse User on Thu, 26 November 2020 |
2152 |
Fri, 27 November 2020 03:14 By: Eclipse User  |
Def expressions in OCLInEcore and the Interactive console. By: Eclipse User on Thu, 12 August 2010 |
4392 |
Fri, 16 October 2020 15:10 By: Eclipse User  |
Class CastException in OCLinEcore generated code By: Eclipse User on Thu, 15 October 2020 |
2662 |
Fri, 16 October 2020 06:27 By: Eclipse User  |
Looking for OCL Rules for BPMN By: Eclipse User on Wed, 26 August 2020 |
2296 |
Wed, 26 August 2020 11:56 By: Eclipse User  |
Noob To OCL needs Help with XMI Use OCL with XMI files By: Eclipse User on Mon, 29 June 2020 |
2558 |
Tue, 30 June 2020 16:25 By: Eclipse User  |
eAllContents() or closure of eContents() in OCL How to use eAllContents() in OCL, or create closure of eContents() By: Eclipse User on Mon, 08 June 2020 |
2030 |
Mon, 08 June 2020 11:42 By: Eclipse User  |
Reuse OCL - access Ecore metamodel entities in runtime By: Eclipse User on Thu, 27 February 2020 |
2924 |
Sun, 31 May 2020 03:38 By: Eclipse User  |
Problems with OCL validation and derived properties By: Eclipse User on Tue, 12 May 2020 |
5015 |
Sat, 16 May 2020 14:42 By: Eclipse User  |
OCL jars from Maven By: Eclipse User on Mon, 18 February 2019 |
24 |
13216 |
Mon, 11 May 2020 15:21 By: Eclipse User  |
Ignoring OCL during Ecore validation possible ? By: Eclipse User on Fri, 24 April 2020 |
3492 |
Sun, 26 April 2020 01:02 By: Eclipse User  |
CompleteOCL - Import URI By: Eclipse User on Mon, 20 April 2020 |
2641 |
Thu, 23 April 2020 06:49 By: Eclipse User  |
Generating code from ecore model How to generate code from ecore model with OCL expressions in the separate file? By: Eclipse User on Wed, 08 April 2020 |
5783 |
Sun, 12 April 2020 13:44 By: Eclipse User  |
OCLinEcore metamodel and allinstances is "allinstances " source of problems when creating a metamodel? By: Eclipse User on Mon, 02 March 2020 |
1930 |
Tue, 03 March 2020 01:13 By: Eclipse User  |
Announce OCL 6.10.1 By: Eclipse User on Fri, 21 February 2020 |
2867 |
Thu, 27 February 2020 11:16 By: Eclipse User  |
Saving a file in the OCLinEcore Editor deletes its content By: Eclipse User on Sat, 15 February 2020 |
3486 |
Tue, 25 February 2020 17:29 By: Eclipse User  |
CfP: 20th International Workshop on OCL and Textual Modeling (OCL'2020 @ STAF) By: Eclipse User on Fri, 21 February 2020 |
5727 |
Fri, 21 February 2020 08:27 By: Eclipse User  |
Parsing constraints having elements from differents packages When an OCL constraint points an element that does not belong to the same package as the rest of the constraint, it is not possible to parse the constraint By: Eclipse User on Tue, 03 December 2019 |
3075 |
Thu, 05 December 2019 05:56 By: Eclipse User  |
OCLinEcore: Custom validation messages not working By: Eclipse User on Mon, 06 July 2015 |
6269 |
Wed, 04 December 2019 01:28 By: Eclipse User  |
Problems with a loop By: Eclipse User on Fri, 22 November 2019 |
2392 |
Sat, 23 November 2019 03:09 By: Eclipse User  |
OCL XText Console not available in Eclipse 2019-09 By: Eclipse User on Tue, 29 October 2019 |
4014 |
Thu, 31 October 2019 08:45 By: Eclipse User  |
Problem with OCL code while comparing the same class attribute of two instances By: Eclipse User on Mon, 14 October 2019 |
2181 |
Mon, 14 October 2019 15:29 By: Eclipse User  |
OCL Classic vs OCL Pivot: IllegalArgumentException: Same projects but in Pivot invariant name == null By: Eclipse User on Thu, 08 August 2019 |
3701 |
Wed, 04 September 2019 17:34 By: Eclipse User  |
OCL editor exception in eclipse Thrown Exception when trying to open ecore file with OCL editor in eclipse By: Eclipse User on Sun, 30 June 2019 |
2412 |
Thu, 04 July 2019 12:41 By: Eclipse User  |
NPE while loading OCL file OCL Editor NPE Problem By: Eclipse User on Thu, 25 April 2019 |
2428 |
Tue, 07 May 2019 12:17 By: Eclipse User  |
Safe OCL By: Eclipse User on Thu, 14 March 2019 |
23 |
11302 |
Fri, 26 April 2019 12:22 By: Eclipse User  |
how to reach OCLMessage from OCL API? By: Eclipse User on Tue, 02 April 2019 |
2796 |
Tue, 02 April 2019 16:04 By: Eclipse User  |
Tuple type availability in Acceleo OCL By: Eclipse User on Tue, 02 April 2019 |
3667 |
Tue, 02 April 2019 15:46 By: Eclipse User  |
NPE due to null source By: Eclipse User on Sat, 30 March 2019 |
4238 |
Mon, 01 April 2019 01:48 By: Eclipse User  |
Announce OCL 6.7.0 By: Eclipse User on Wed, 20 March 2019 |
18762 |
Wed, 20 March 2019 11:22 By: Eclipse User  |
Complex query help complex query on the diamond problem By: Eclipse User on Thu, 28 February 2019 |
4651 |
Thu, 07 March 2019 12:56 By: Eclipse User  |
OCL query from file "Main" entry point for OCL document By: Eclipse User on Mon, 25 February 2019 |
32 |
10479 |
Fri, 01 March 2019 10:17 By: Eclipse User  |
Divide CompleteOCL document into different documents By: Eclipse User on Wed, 09 January 2019 |
3210 |
Tue, 15 January 2019 04:48 By: Eclipse User  |
Standalone compiled OCL Problem with GenModel when programatically invoking Java OCL code By: Eclipse User on Wed, 06 December 2017 |
28 |
15530 |
Mon, 14 January 2019 14:35 By: Eclipse User  |
import nested packages in CompleteOCL for use with XText OCL XText import By: Eclipse User on Thu, 10 January 2019 |
3008 |
Fri, 11 January 2019 01:18 By: Eclipse User  |
Use OCL to validate non-Ecore objects at runtime By: Eclipse User on Thu, 03 January 2019 |
3972 |
Fri, 04 January 2019 10:33 By: Eclipse User  |
Custom implementation of OCLstdlib Extending a subset of default standard library By: Eclipse User on Tue, 01 January 2019 |
3905 |
Wed, 02 January 2019 04:27 By: Eclipse User  |
Eclipse OCL latest P2 repos By: Eclipse User on Mon, 03 December 2018 |
3430 |
Mon, 03 December 2018 04:46 By: Eclipse User  |
Fail to correctly parse CompleteOCL constraints By: Eclipse User on Thu, 29 November 2018 |
3583 |
Fri, 30 November 2018 03:43 By: Eclipse User  |
a derived property how can we duplicate the content of a class (even its associations and composition) By: Eclipse User on Tue, 20 November 2018 |
4911 |
Wed, 28 November 2018 10:04 By: Eclipse User  |
Map type support in OCL? OCL language support for Map By: Eclipse User on Wed, 07 November 2018 |
3705 |
Wed, 21 November 2018 09:09 By: Eclipse User  |
Initialise Map in OCL By: Eclipse User on Fri, 09 November 2018 |
3662 |
Wed, 21 November 2018 09:06 By: Eclipse User  |
Specify Constraint for Parameter of a UML Operation By: Eclipse User on Sun, 11 November 2018 |
4128 |
Fri, 16 November 2018 06:02 By: Eclipse User  |
"Create Dynamic Instance" in OCLinEcore tutorial OCLinEcore tutorial By: Eclipse User on Sun, 04 November 2018 |
3790 |
Sun, 04 November 2018 13:48 By: Eclipse User  |
"Select DISTINCT" with OCL By: Eclipse User on Sun, 21 October 2018 |
4365 |
Mon, 22 October 2018 01:51 By: Eclipse User  |
Announce OCL 6.5.0 By: Eclipse User on Wed, 19 September 2018 |
6279 |
Wed, 19 September 2018 11:17 By: Eclipse User  |
Dynamic OCL Constraints How to approach creating dynamic ocl constraints By: Eclipse User on Thu, 21 June 2018 |
7318 |
Tue, 07 August 2018 01:12 By: Eclipse User  |
Evaluation of derived OCL Ecore attributes from Java By: Eclipse User on Wed, 04 July 2018 |
2880 |
Fri, 06 July 2018 16:36 By: Eclipse User  |
Announce OCL 6.4.0 By: Eclipse User on Sat, 30 June 2018 |
3714 |
Mon, 02 July 2018 04:22 By: Eclipse User  |
Pivot missing metamodel reference By: Eclipse User on Fri, 29 June 2018 |
3313 |
Sat, 30 June 2018 06:06 By: Eclipse User  |
Welcome to the eclipse.modeling.mdt.ocl group! |
28383 |
Wed, 30 May 2018 12:22 By: Eclipse User  |
OCL in Activity Diagram OCL constraint with UML Activity Diagram By: Eclipse User on Mon, 21 May 2018 |
3540 |
Fri, 25 May 2018 14:06 By: Eclipse User  |
OCL constraints on some properties of a dependency stereotype By: Eclipse User on Fri, 18 May 2018 |
3775 |
Fri, 18 May 2018 13:31 By: Eclipse User  |
detect the constraints conflict By: Eclipse User on Fri, 04 May 2018 |
3454 |
Sat, 05 May 2018 01:27 By: Eclipse User  |
OCL and SBVR OCL and SBVR By: Eclipse User on Mon, 16 April 2018 |
3180 |
Mon, 16 April 2018 05:16 By: Eclipse User  |
Failed to set 'self' context Failed to set 'self' context By: Eclipse User on Tue, 20 March 2018 |
6722 |
Mon, 16 April 2018 05:04 By: Eclipse User  |
Code Generation with external ocl document Code Generation with external ocl document By: Eclipse User on Thu, 22 March 2018 |
6862 |
Thu, 29 March 2018 14:26 By: Eclipse User  |
Validate OCL from ecore standalone => Exception java.lang.NullPointerException: null By: Eclipse User on Mon, 26 March 2018 |
5441 |
Wed, 28 March 2018 05:19 By: Eclipse User  |
Generic Enumeration Literal By: Eclipse User on Tue, 20 March 2018 |
3058 |
Thu, 22 March 2018 12:03 By: Eclipse User  |
def / derive in interactive OCL console Looking for a way to define an operation inside OCL interpreter By: Eclipse User on Mon, 12 March 2018 |
3877 |
Tue, 13 March 2018 10:54 By: Eclipse User  |
Bug in generated code? Compiled OCL issue By: Eclipse User on Thu, 22 February 2018 |
4260 |
Thu, 22 February 2018 10:14 By: Eclipse User  |
EMF reflection in completeOCL (Pivot) Cannot iterate over an object's references By: Eclipse User on Tue, 16 January 2018 |
5513 |
Wed, 17 January 2018 09:07 By: Eclipse User  |
2846 |
Tue, 16 January 2018 10:03 By: Eclipse User  |
OCLinEcore editor broken after update By: Eclipse User on Tue, 02 January 2018 |
4777 |
Fri, 05 January 2018 09:06 By: Eclipse User  |
Strange behavior on MS/Win with OCL By: Eclipse User on Wed, 03 January 2018 |
5409 |
Thu, 04 January 2018 09:33 By: Eclipse User  |
Migrating from CompleteOCL to OCLinEcore By: Eclipse User on Tue, 21 November 2017 |
19 |
13313 |
Fri, 22 December 2017 05:03 By: Eclipse User  |
Complete OCL for Xtext Validation Change in methods from the tutorials and documentation By: Eclipse User on Wed, 06 December 2017 |
6346 |
Wed, 13 December 2017 10:12 By: Eclipse User  |
Let expression in OCL without specifying type By: Eclipse User on Mon, 11 December 2017 |
5438 |
Tue, 12 December 2017 04:04 By: Eclipse User  |
maven emf ocl artifacts By: Eclipse User on Sun, 23 July 2017 |
11308 |
Sat, 18 November 2017 05:50 By: Eclipse User  |
Can we capture Exception/Error Message from console in Finish block? Exception Handling By: Eclipse User on Mon, 13 November 2017 |
3564 |
Tue, 14 November 2017 10:43 By: Eclipse User  |
Using OCL to create a M2M ATL to UML2 Need help about OCL and how to create UML2 elements from a model wicht is not an UML Model By: Eclipse User on Tue, 07 November 2017 |
3016 |
Wed, 08 November 2017 10:23 By: Eclipse User  |
Valid OCL constraint - Validation Error in Editor By: Eclipse User on Fri, 03 November 2017 |
6035 |
Sun, 05 November 2017 03:15 By: Eclipse User  |
Is is possible to install OCL without installing UML? By: Eclipse User on Thu, 26 October 2017 |
4162 |
Thu, 26 October 2017 04:49 By: Eclipse User  |
OCL generator and EMF super types By: Eclipse User on Sat, 14 October 2017 |
4092 |
Sat, 14 October 2017 13:44 By: Eclipse User  |
Programmatically run OCL queries with multiple meta-models produces unknown type errors By: Eclipse User on Wed, 04 October 2017 |
5085 |
Thu, 05 October 2017 05:50 By: Eclipse User  |
OCL with a profile applied to itself By: Eclipse User on Thu, 07 September 2017 |
17 |
22373 |
Thu, 21 September 2017 08:55 By: Eclipse User  |
OCL constraints on dependency Metaclass and enumeration issues By: Eclipse User on Wed, 13 September 2017 |
15117 |
Fri, 15 September 2017 08:18 By: Eclipse User  |
includesAll fails By: Eclipse User on Tue, 22 August 2017 |
18751 |
Thu, 31 August 2017 12:15 By: Eclipse User  |
How to run OCL in Eclipse? Beginner question By: Eclipse User on Mon, 21 August 2017 |
12416 |
Tue, 22 August 2017 10:35 By: Eclipse User  |
Defining helper operations in Java using Pivot OCL By: Eclipse User on Fri, 11 August 2017 |
14843 |
Tue, 15 August 2017 09:59 By: Eclipse User  |
checking against ecore based model By: Eclipse User on Sun, 30 July 2017 |
5577 |
Sun, 30 July 2017 10:24 By: Eclipse User  |
Announce OCL 6.3.0 By: Eclipse User on Wed, 28 June 2017 |
9687 |
Wed, 28 June 2017 12:51 By: Eclipse User  |
Simplifying OCL Expressions By: Eclipse User on Tue, 27 June 2017 |
6883 |
Tue, 27 June 2017 04:44 By: Eclipse User  |
check refernce is defined By: Eclipse User on Thu, 15 June 2017 |
12503 |
Sat, 17 June 2017 03:41 By: Eclipse User  |
ETL constraints to OCL By: Eclipse User on Wed, 14 June 2017 |
10225 |
Thu, 15 June 2017 11:23 By: Eclipse User  |
lots of errors in ocl file By: Eclipse User on Wed, 14 June 2017 |
8869 |
Wed, 14 June 2017 13:16 By: Eclipse User  |
Using Java APIs By: Eclipse User on Sun, 11 June 2017 |
20317 |
Tue, 13 June 2017 04:44 By: Eclipse User  |
Negation of OCL expressions By: Eclipse User on Fri, 09 June 2017 |
6633 |
Fri, 09 June 2017 08:46 By: Eclipse User  |
Possible problems with implicit properties of Stereotypes By: Eclipse User on Mon, 10 April 2017 |
8497 |
Wed, 17 May 2017 14:58 By: Eclipse User  |
IllegalStateException on plain vanilla install of OCL Eclipse CompleteOCL Editor throws with message "cannot modify resource set without a write transaction" By: Eclipse User on Mon, 08 May 2017 |
9836 |
Mon, 15 May 2017 03:08 By: Eclipse User  |
UML constraints context UML constraints context By: Eclipse User on Wed, 10 May 2017 |
52192 |
Sat, 13 May 2017 04:51 By: Eclipse User  |
Evaluation of transformations with OCL By: Eclipse User on Fri, 20 July 2007 |
51 |
26038 |
Fri, 12 May 2017 13:24 By: Eclipse User  |
Setting non-blank root/package URIs in Papyrus Need workaround for https://bugs.eclipse.org/bugs/show_bug.cgi?id=516285 By: Eclipse User on Sun, 07 May 2017 |
4891 |
Mon, 08 May 2017 10:29 By: Eclipse User  |
Generating Java code for OCL constraints By: Eclipse User on Thu, 28 March 2013 |
15601 |
Thu, 04 May 2017 16:18 By: Eclipse User  |
An Error when loading and OCL File for verification By: Eclipse User on Wed, 26 April 2017 |
4923 |
Wed, 26 April 2017 11:14 By: Eclipse User  |
Start/End position By: Eclipse User on Tue, 24 January 2017 |
23565 |
Tue, 11 April 2017 14:18 By: Eclipse User  |
Programmatical creation Building OCL constraints from Java By: Eclipse User on Tue, 11 April 2017 |
6210 |
Tue, 11 April 2017 13:35 By: Eclipse User  |
How to derive a collection of objects How to derive a collection of objects By: Eclipse User on Tue, 04 April 2017 |
6302 |
Wed, 05 April 2017 13:36 By: Eclipse User  |
limit OCL validation of an invariant By: Eclipse User on Sun, 02 April 2017 |
7194 |
Sun, 02 April 2017 10:47 By: Eclipse User  |
OCL Codegenerator By: Eclipse User on Fri, 31 March 2017 |
5248 |
Fri, 31 March 2017 12:54 By: Eclipse User  |
Operations from OCL StdLib have an EDataType instead of UMLPrimitiveType By: Eclipse User on Mon, 20 March 2017 |
61753 |
Tue, 21 March 2017 04:55 By: Eclipse User  |
[Announce] Impact Analyzer deprecation By: Eclipse User on Fri, 17 March 2017 |
41323 |
Fri, 17 March 2017 13:37 By: Eclipse User  |
Custom static operation By: Eclipse User on Wed, 22 February 2017 |
8366 |
Fri, 17 March 2017 05:42 By: Eclipse User  |
Changing invariants written in OCLinEcore needs Eclipse restart By: Eclipse User on Wed, 15 March 2017 |
4433 |
Wed, 15 March 2017 09:13 By: Eclipse User  |
Compare Eenum types By: Eclipse User on Fri, 10 March 2017 |
6828 |
Fri, 10 March 2017 12:33 By: Eclipse User  |
Validation problem with Dynamic Instance By: Eclipse User on Thu, 09 March 2017 |
7256 |
Fri, 10 March 2017 03:51 By: Eclipse User  |
Help with this example? By: Eclipse User on Sat, 04 March 2017 |
3502 |
Mon, 06 March 2017 12:28 By: Eclipse User  |
Validation Problems of OCL Constraints contained in a static UML Profile By: Eclipse User on Wed, 01 March 2017 |
9720 |
Fri, 03 March 2017 07:20 By: Eclipse User  |
The 'Property::CompatibleDefaultExpression' constraint is violated for xxxxx By: Eclipse User on Tue, 28 February 2017 |
3880 |
Tue, 28 February 2017 13:57 By: Eclipse User  |
How to integrating OCL expressions in DSL grammar (Xtext project ) ? By: Eclipse User on Tue, 28 February 2017 |
4591 |
Tue, 28 February 2017 08:08 By: Eclipse User  |
OCL AST - Editing, Parsing and Cloning Any pointers to doc and/or artefacts to use ? By: Eclipse User on Tue, 14 February 2017 |
8834 |
Fri, 24 February 2017 15:08 By: Eclipse User  |
Extend data types from the Standard Library in UML model By: Eclipse User on Fri, 17 February 2017 |
4520 |
Fri, 17 February 2017 03:28 By: Eclipse User  |
false or null = null? By: Eclipse User on Tue, 14 February 2017 |
11502 |
Thu, 16 February 2017 08:46 By: Eclipse User  |
Xtext and OCL references By: Eclipse User on Mon, 06 February 2017 |
7032 |
Tue, 07 February 2017 11:47 By: Eclipse User  |
Query to return Classes that use a given Enumeration By: Eclipse User on Fri, 03 February 2017 |
4035 |
Tue, 07 February 2017 11:03 By: Eclipse User  |
Problem in navigating references By: Eclipse User on Fri, 03 February 2017 |
6582 |
Sat, 04 February 2017 06:27 By: Eclipse User  |
collect equivalent for one element By: Eclipse User on Sat, 21 January 2017 |
5668 |
Mon, 23 January 2017 13:51 By: Eclipse User  |
Of surname propagation, another nest. By: Eclipse User on Mon, 16 January 2017 |
5585 |
Tue, 17 January 2017 05:14 By: Eclipse User  |
Nested forAlls By: Eclipse User on Tue, 10 January 2017 |
5532 |
Wed, 11 January 2017 11:47 By: Eclipse User  |
[Announce] OCL 6.1.2 and 6.2.2 for Neon By: Eclipse User on Wed, 21 December 2016 |
12541 |
Wed, 21 December 2016 11:27 By: Eclipse User  |
Complete OCL in Autogenerated Ecore editor By: Eclipse User on Mon, 19 December 2016 |
3653 |
Mon, 19 December 2016 09:27 By: Eclipse User  |
Complete ocl file in Ecore editor By: Eclipse User on Mon, 19 December 2016 |
17510 |
Mon, 19 December 2016 07:28 By: Eclipse User  |
OCL in Ecore metamodel By: Eclipse User on Mon, 19 December 2016 |
17505 |
Mon, 19 December 2016 07:27 By: Eclipse User  |
Loading oclxmi files By: Eclipse User on Tue, 06 December 2016 |
6769 |
Thu, 08 December 2016 14:46 By: Eclipse User  |
pre and post conditions in OCL metamodel By: Eclipse User on Thu, 24 November 2016 |
6144 |
Thu, 24 November 2016 10:14 By: Eclipse User  |
choosing "Property::CompatibleDefaultExpression" for programmatically defined pivot types By: Eclipse User on Wed, 23 November 2016 |
3165 |
Wed, 23 November 2016 11:38 By: Eclipse User  |
Performing queries in KDM with OCL By: Eclipse User on Tue, 22 November 2016 |
3647 |
Tue, 22 November 2016 13:12 By: Eclipse User  |
How should max,min handle null case ? By: Eclipse User on Fri, 18 November 2016 |
8404 |
Fri, 18 November 2016 10:10 By: Eclipse User  |
navigate from a UML class to a UML lifeline/message in an OCL constraint By: Eclipse User on Tue, 15 November 2016 |
4463 |
Tue, 15 November 2016 17:27 By: Eclipse User  |
Validation of property access in post-conditions of UML static operations By: Eclipse User on Tue, 15 November 2016 |
7351 |
Tue, 15 November 2016 11:47 By: Eclipse User  |
OCL in UML Profile By: Eclipse User on Thu, 10 November 2016 |
8637 |
Fri, 11 November 2016 12:50 By: Eclipse User  |
OCL JARs Where to find JARs By: Eclipse User on Thu, 10 November 2016 |
6530 |
Fri, 11 November 2016 12:36 By: Eclipse User  |
Validating a Model through Java OCL By: Eclipse User on Fri, 04 November 2016 |
4370 |
Tue, 08 November 2016 07:27 By: Eclipse User  |
problem string concat operation OclUndefined ? By: Eclipse User on Tue, 08 November 2016 |
3996 |
Tue, 08 November 2016 07:00 By: Eclipse User  |
UML2AS: Error when translating OpaqueExpression with multiple languages By: Eclipse User on Wed, 19 October 2016 |
4049 |
Wed, 19 October 2016 06:01 By: Eclipse User  |
evaluate new OCL constrains as I am drawing a UML model By: Eclipse User on Sat, 01 October 2016 |
9163 |
Fri, 07 October 2016 07:21 By: Eclipse User  |
[Announce] OCL 6.1.1 and 6.2.1 for Neon By: Eclipse User on Wed, 28 September 2016 |
6648 |
Wed, 28 September 2016 15:34 By: Eclipse User  |
Is Collection(T) covariant on T? By: Eclipse User on Tue, 27 September 2016 |
4124 |
Tue, 27 September 2016 08:29 By: Eclipse User  |
Unique Id Constraint does not validate By: Eclipse User on Sun, 25 September 2016 |
7505 |
Mon, 26 September 2016 01:15 By: Eclipse User  |
3420 |
Wed, 31 August 2016 14:44 By: Eclipse Webmaster  |
OCL Evaluation Basics By: Eclipse User on Wed, 24 August 2016 |
9409 |
Fri, 26 August 2016 15:07 By: Eclipse User  |
Need your help on a student assignment . By: Eclipse User on Thu, 04 August 2016 |
3404 |
Tue, 09 August 2016 01:55 By: Eclipse User  |
Quick fix for OCLinEcore Quick fix for OCLinEcore By: Eclipse User on Fri, 05 August 2016 |
3190 |
Fri, 05 August 2016 15:01 By: Eclipse User  |
NullPointerException after EMF Code Generation with OCL Constraints By: Eclipse User on Tue, 22 October 2013 |
10852 |
Tue, 26 July 2016 10:45 By: Eclipse User  |
Announce OCL 6.2.0 release By: Eclipse User on Sun, 24 July 2016 |
5424 |
Sun, 24 July 2016 04:40 By: Eclipse User  |
[Announce] Deadline Extension: 16th International Workshop in OCL and Textual Modelling By: Eclipse User on Tue, 19 July 2016 |
6258 |
Tue, 19 July 2016 05:35 By: Eclipse User  |
How to write OCL in a file and use it in a state machine? By: Eclipse User on Sun, 17 July 2016 |
5124 |
Sun, 17 July 2016 14:36 By: Eclipse User  |
Evaluate OCL constraints in an UML model programmatically By: Eclipse User on Fri, 27 May 2016 |
32 |
29019 |
Sat, 09 July 2016 13:00 By: Eclipse User  |
Clone Dict By: Eclipse User on Fri, 24 June 2016 |
3477 |
Fri, 24 June 2016 04:31 By: Eclipse User  |
Announcing OCL 6.1.0 (and 6.2.0) for Neon By: Eclipse User on Wed, 22 June 2016 |
5602 |
Wed, 22 June 2016 14:57 By: Eclipse User  |
Define allInstances() operation for Signals By: Eclipse User on Thu, 16 June 2016 |
3295 |
Thu, 16 June 2016 07:08 By: Eclipse User  |
[oclinecore] import statement gets rewritten By: Eclipse User on Tue, 31 May 2016 |
4382 |
Tue, 31 May 2016 08:47 By: Eclipse User  |
Unicode support By: Eclipse User on Mon, 30 May 2016 |
5308 |
Mon, 30 May 2016 07:56 By: Eclipse User  |
EMFtoCSP: Error in the ecl file EMFtoCSP: Error in the ecl file ("Missing EOF at :") By: Eclipse User on Mon, 23 May 2016 |
3234 |
Mon, 23 May 2016 17:46 By: Eclipse User  |
[oclinecore] unable to set EKeys By: Eclipse User on Wed, 04 May 2016 |
4176 |
Wed, 04 May 2016 04:44 By: Eclipse User  |
Invalid thread access exception while loading a Complete OCL file Unable to load a simple empty Complete OCL file on a SysML model with nested profiles. By: Eclipse User on Fri, 15 April 2016 |
11356 |
Mon, 02 May 2016 17:57 By: Eclipse User  |
OCL XText grammar By: Eclipse User on Mon, 25 April 2016 |
8066 |
Mon, 02 May 2016 08:52 By: Eclipse User  |
Native validation with custom OCL files Using plugin manifest to register custom CompleteOCL files for native validation By: Eclipse User on Fri, 29 April 2016 |
3857 |
Fri, 29 April 2016 16:20 By: Eclipse User  |
Standalone validation with CompleteOCL evaluates nothing Problem with running CompleteOCL standalone for JUnit tests By: Eclipse User on Fri, 15 April 2016 |
6387 |
Fri, 22 April 2016 08:10 By: Eclipse User  |
OCL git repository By: Eclipse User on Mon, 18 April 2016 |
5850 |
Mon, 18 April 2016 05:12 By: Eclipse User  |
Global operation for oclAny By: Eclipse User on Fri, 11 March 2016 |
9184 |
Fri, 08 April 2016 13:19 By: Eclipse User  |
Computing derived attribute values with dynamic EMF How to set SettingDelegates? By: Eclipse User on Fri, 25 March 2016 |
9546 |
Thu, 31 March 2016 13:02 By: Eclipse User  |
How to add power operation to the primitive type Integer? By: Eclipse User on Sat, 20 February 2016 |
10325 |
Sun, 21 February 2016 04:59 By: Eclipse User  |
Non documented dependency for OCLinEcore Problem using OCLinEcore through a metamodel API By: Eclipse User on Fri, 12 February 2016 |
6649 |
Mon, 15 February 2016 12:19 By: Eclipse User  |
