Announcement: Project is being archived By: Eclipse User on Fri, 13 October 2023 |
1550 |
Fri, 13 October 2023 10:34 By: Eclipse User  |
sticky: READ THIS FIRST before posting General information about using this forum By: Eclipse User on Fri, 14 October 2011 |
21614 |
Fri, 14 October 2011 09:21 By: Eclipse User  |
Can jubula tool is able to work on desktop-based application on Linux machine i want to know the assessibility of jubula for POC with my s/w By: Eclipse User on Thu, 07 December 2023 |
3401 |
Thu, 07 December 2023 07:51 By: Eclipse User  |
Jubula with JDK17 By: Eclipse User on Tue, 18 October 2022 |
2543 |
Thu, 10 August 2023 08:25 By: Eclipse User  |
Wrong Button clicked Test Case clicks different button than mapped By: Eclipse User on Tue, 14 February 2023 |
3178 |
Fri, 05 May 2023 02:28 By: Eclipse User  |
Unable to install Jubula and getting and getting Error Unable to install Jubula and getting and getting Error "An error occurred: java.lang.NoClassDefFoundError: com/mercury/ftjadin/hooks/interfaces/EventListenerListHookQTJA Error log: C:\Users\manhv By: Eclipse User on Wed, 01 February 2023 |
2085 |
Wed, 01 February 2023 07:52 By: Eclipse User  |
unable to find table specific method for swing table(graphicscomponents) unable to find table specific method for swing table(graphicscomponents) By: Eclipse User on Wed, 13 January 2016 |
9821 |
Mon, 30 January 2023 09:46 By: Eclipse User  |
Mouse moving slow when executing tests with OpenJDK17 By: Eclipse User on Wed, 08 December 2021 |
7122 |
Wed, 21 December 2022 07:33 By: Eclipse User  |
Building Jubula Error whilst building Jubula By: Eclipse User on Wed, 23 November 2022 |
2011 |
Wed, 23 November 2022 03:38 By: Eclipse User  |
Unable to launch AUT with OpenJDK17 By: Eclipse User on Tue, 23 November 2021 |
9883 |
Thu, 10 November 2022 03:49 By: Eclipse User  |
Stuck after selecting value from combobox By: Eclipse User on Fri, 26 July 2013 |
3931 |
Thu, 15 September 2022 07:10 By: Eclipse User  |
java.lang.NoClassDefFoundError: org/eclipse/jubula/client/launch/AUTConfiguration Not able to execute sample code with jubla .I am using testNg and agent is started By: Eclipse User on Tue, 13 September 2022 |
3301 |
Tue, 13 September 2022 01:09 By: Eclipse User  |
Javafx ComboBox Selection slow Selecting an entry from a Combobox is slow By: Eclipse User on Mon, 05 September 2022 |
2299 |
Mon, 05 September 2022 11:01 By: Eclipse User  |
Not able to toggle checkbox in treetable I'm recording one test case by observation mode but it is not recording the checkbox toggle step. I tried to toggle checkbox by adding ub_tbl_toggleCheckboxAtMouseposition but it is throwing error &am By: Eclipse User on Fri, 05 August 2022 |
1999 |
Fri, 05 August 2022 02:45 By: Eclipse User  |
Jubula Client API - Require Help! By: Eclipse User on Wed, 06 July 2022 |
4333 |
Mon, 11 July 2022 09:51 By: Eclipse User  |
ConnectException on consecutive execution executing Jubula repeatedly frequently causes ConnectException By: Eclipse User on Mon, 18 March 2019 |
5795 |
Mon, 11 July 2022 09:38 By: Eclipse User  |
Jubula Client API tutorial By: Eclipse User on Tue, 14 June 2016 |
5642 |
Tue, 05 July 2022 02:16 By: Eclipse User  |
Unable to connect to my AUT agent 5009 Aut start failed error By: Eclipse User on Mon, 12 October 2020 |
5861 |
Fri, 24 June 2022 02:56 By: Eclipse User  |
Testing Javafx Selected Node(s) Testing selected nodes when extended select used By: Eclipse User on Thu, 09 June 2022 |
3425 |
Thu, 09 June 2022 10:33 By: Eclipse User  |
Cannot start AUT with Jubula 8.7.1.046 Cannot start AUT with Jubula 8.7.1.046 - our application crashes By: Eclipse User on Mon, 17 June 2019 |
9920 |
Sat, 04 June 2022 05:53 By: Eclipse User  |
Testing Javafx Properties Is it possible to test a property within a Javafx control By: Eclipse User on Mon, 23 May 2022 |
3111 |
Thu, 26 May 2022 09:12 By: Eclipse User  |
Selecting Panes Need to select AnchorPane in Javafx By: Eclipse User on Tue, 05 April 2022 |
4921 |
Thu, 19 May 2022 06:50 By: Eclipse User  |
Jubula versions Which version is most current By: Eclipse User on Wed, 06 May 2020 |
5908 |
Wed, 18 May 2022 05:59 By: Eclipse User  |
execute linux command from jubula By: Eclipse User on Wed, 06 December 2017 |
4282 |
Mon, 25 April 2022 04:19 By: Eclipse User  |
check textIn ClipBoard check Text InClipBoard By: Eclipse User on Mon, 18 April 2022 |
1165 |
Mon, 18 April 2022 05:42 By: Eclipse User  |
Extension Wizard no toolkits No toolkits are shown when creating a new extension project By: Eclipse User on Wed, 06 April 2022 |
4034 |
Wed, 06 April 2022 08:15 By: Eclipse User  |
Check clipboard value By: Eclipse User on Wed, 21 January 2015 |
2441 |
Tue, 05 April 2022 09:20 By: Eclipse User  |
Embedded agent test with API: Application won´t start By: Eclipse User on Wed, 05 January 2022 |
3004 |
Wed, 30 March 2022 09:55 By: Eclipse User  |
Database error after install Version conflict on h2 database By: Eclipse User on Sat, 12 March 2022 |
1486 |
Sat, 12 March 2022 07:59 By: Eclipse User  |
Building from source Sequence for building By: Eclipse User on Fri, 11 March 2022 |
4681 |
Fri, 11 March 2022 06:27 By: Eclipse User  |
BeforeTest, AfterTest hooks not present in Jubula By: Eclipse User on Tue, 25 January 2022 |
4083 |
Fri, 04 March 2022 04:01 By: Eclipse User  |
Connection to AUT could not be established Mapping do not start in Jubula By: Eclipse User on Wed, 26 January 2022 |
4487 |
Tue, 08 February 2022 07:37 By: Eclipse User  |
Extension wizard throw exception about JAXB By: Eclipse User on Wed, 02 February 2022 |
3772 |
Wed, 02 February 2022 10:02 By: Eclipse User  |
Custom Component using client API By: Eclipse User on Thu, 20 January 2022 |
3483 |
Thu, 20 January 2022 08:24 By: Eclipse User  |
(how) can I use env vars in a test? By: Eclipse User on Tue, 30 August 2011 |
4446 |
Tue, 02 November 2021 09:26 By: Eclipse User  |
Jubula is not displaying teststeps in the testsuite editor Jubula is not displaying teststeps in the testsuite editor By: Eclipse User on Mon, 27 September 2021 |
3399 |
Tue, 02 November 2021 06:01 By: Eclipse User  |
Please fight the drift TIL what content drift means By: Eclipse User on Mon, 01 November 2021 |
1403 |
Mon, 01 November 2021 08:07 By: Eclipse User  |
How can I find an old version of Jubula I want to install an old version of Jubula ( e.g. 8.7) By: Eclipse User on Mon, 23 August 2021 |
2986 |
Thu, 28 October 2021 07:45 By: Eclipse User  |
Debugging for beginners? By: Eclipse User on Thu, 18 March 2021 |
2843 |
Wed, 08 September 2021 08:30 By: Eclipse User  |
Sharing common test cases across projects. Share common flows to be used across projects By: Eclipse User on Wed, 24 March 2021 |
3574 |
Wed, 08 September 2021 07:30 By: Eclipse User  |
Headless Mode By: Eclipse User on Fri, 09 July 2021 |
2783 |
Fri, 06 August 2021 12:54 By: Eclipse User  |
Object Mapping of the existing components getting changed after an update in the UI By: Eclipse User on Wed, 28 April 2021 |
4370 |
Fri, 06 August 2021 04:42 By: Eclipse User  |
Performance drop in Jubula 8.8 test of javafx 16 application After application migration from javafx 11 to javafx 16 dropped test performance terribly By: Eclipse User on Thu, 29 April 2021 |
8187 |
Fri, 06 August 2021 04:36 By: Eclipse User  |
scroll to invisible Component By: Eclipse User on Thu, 14 March 2013 |
3769 |
Tue, 06 July 2021 08:01 By: Eclipse User  |
Jubula - Referenced Parameter - Ignore case sensitivity and spacing Jubula - Check text via referenced parameter - Ignore case sensitivity and spacing By: Eclipse User on Fri, 11 June 2021 |
2386 |
Fri, 11 June 2021 12:42 By: Eclipse User  |
How to get Column Header name of Table in Swing Application By: Eclipse User on Thu, 15 April 2021 |
2306 |
Thu, 15 April 2021 03:16 By: Eclipse User  |
Autagent.exe not working on Linux After launching autagent.exe on Linux, the agent never gets connected. By: Eclipse User on Fri, 05 February 2021 |
13770 |
Fri, 19 February 2021 10:51 By: Eclipse User  |
Will jubula work for windows forms and c# application Will jubula work for windows forms and c# By: Eclipse User on Fri, 08 January 2021 |
3721 |
Mon, 01 February 2021 05:09 By: Eclipse User  |
Getting Actions Exception on same Component Intermitantly, when Component is already enabled By: Eclipse User on Sun, 10 January 2021 |
3963 |
Mon, 18 January 2021 04:41 By: Eclipse User  |
How to get result of aut.execute(Component.checkEnablement(true/false),"check comp") in B By: Eclipse User on Tue, 10 November 2020 |
3391 |
Fri, 08 January 2021 03:41 By: Eclipse User  |
What are different techniques to get object mapping in Jubula By: Eclipse User on Wed, 18 November 2020 |
11318 |
Fri, 08 January 2021 03:21 By: Eclipse User  |
Test result not showing X and V By: Eclipse User on Sun, 22 November 2020 |
10765 |
Sat, 28 November 2020 08:41 By: Eclipse User  |
Bugzilla List of changes for 8.8.0 By: Eclipse User on Fri, 06 November 2020 |
3647 |
Fri, 06 November 2020 09:37 By: Eclipse User  |
Where are the maven release artifacts published? By: Eclipse User on Thu, 05 November 2020 |
3318 |
Thu, 05 November 2020 23:03 By: Eclipse User  |
JavaFX Combobox unable to detect By: Eclipse User on Mon, 02 November 2020 |
3990 |
Mon, 02 November 2020 04:03 By: Eclipse User  |
Jubula is unable to identify object mapping of table column name By: Eclipse User on Mon, 19 October 2020 |
1829 |
Fri, 23 October 2020 05:17 By: Eclipse User  |
Start AUT button produces "AUT start failed" message Launching AUT from Jubula By: Eclipse User on Tue, 20 October 2020 |
1983 |
Fri, 23 October 2020 04:59 By: Eclipse User  |
Facing issue on Java swing application can not identify Object mapping Jubula test script on Java swing application can not identify Object mapping . By: Eclipse User on Wed, 16 September 2020 |
3676 |
Fri, 23 October 2020 04:48 By: Eclipse User  |
Sorting in OM Table View? Clicking column headings seems to randomize By: Eclipse User on Wed, 14 May 2014 |
12956 |
Wed, 21 October 2020 08:54 By: Eclipse User  |
How to run 2 AUT (Swing and JavaFX) for 1 application? 1 application: part of JavaFX, part of Swing developed By: Eclipse User on Mon, 19 October 2020 |
2119 |
Mon, 19 October 2020 04:28 By: Eclipse User  |
Need Jubula 8.7.1.046 for Unix By: Eclipse User on Mon, 12 October 2020 |
1905 |
Mon, 12 October 2020 18:57 By: Eclipse User  |
Error 7009 since Java 11 Test Execution Error after migrating AUT to Java 11. By: Eclipse User on Tue, 16 June 2020 |
4154 |
Mon, 12 October 2020 04:37 By: Eclipse User  |
Test for GEF 5.x graphics Element with Jubula By: Eclipse User on Tue, 29 September 2020 |
2000 |
Mon, 12 October 2020 04:25 By: Eclipse User  |
External key combination for downloading a file in API External key combination for downloading a file By: Eclipse User on Mon, 21 September 2020 |
3002 |
Mon, 12 October 2020 04:18 By: Eclipse User  |
Test result By: Eclipse User on Thu, 08 October 2020 |
1803 |
Mon, 12 October 2020 04:17 By: Eclipse User  |
How to get a particular text from a Swing application using Jubula's Java API Java Getter to get a text value from a Swing Application using Jubula By: Eclipse User on Fri, 12 July 2019 |
12277 |
Thu, 10 September 2020 03:13 By: Eclipse User  |
External Command Ubuntu By: Eclipse User on Mon, 07 September 2020 |
1810 |
Thu, 10 September 2020 03:08 By: Eclipse User  |
Selenium Webdriver Unable to locate element By: Eclipse User on Tue, 20 May 2014 |
3919 |
Mon, 24 August 2020 15:31 By: Eclipse User  |
How to press any key by Jubula's Java API By: Eclipse User on Wed, 17 July 2019 |
6387 |
Fri, 21 August 2020 08:28 By: Eclipse User  |
Creating Test Framework and writing test cases in Java in Jubula By: Eclipse User on Mon, 17 August 2020 |
2142 |
Fri, 21 August 2020 03:09 By: Eclipse User  |
Test Reports in Jubula How to generate report in html format(Extent Report, emailable report) in jubula By: Eclipse User on Mon, 10 August 2020 |
2167 |
Mon, 17 August 2020 10:15 By: Eclipse User  |
How to maximize swing application By: Eclipse User on Thu, 13 August 2020 |
1714 |
Mon, 17 August 2020 05:27 By: Eclipse User  |
Test case with multiple inputs By: Eclipse User on Wed, 29 July 2020 |
2827 |
Thu, 13 August 2020 06:48 By: Eclipse User  |
JavaFX Object Mapping not possible - Jubula limitations By: Eclipse User on Tue, 30 June 2020 |
5139 |
Wed, 22 July 2020 03:38 By: Eclipse User  |
Toolkit extension Jubula By: Eclipse User on Mon, 13 July 2020 |
2125 |
Wed, 15 July 2020 03:26 By: Eclipse User  |
Establishing Connection to AUT failed 5009: AUT Start Failed By: Eclipse User on Thu, 09 July 2020 |
2863 |
Mon, 13 July 2020 22:31 By: Eclipse User  |
Object Mappping not working for JavaFX AUT using javax.swing By: Eclipse User on Mon, 06 July 2020 |
3116 |
Mon, 13 July 2020 09:46 By: Eclipse User  |
Abstract Test Cases By: Eclipse User on Thu, 02 July 2020 |
3335 |
Mon, 13 July 2020 05:40 By: Eclipse User  |
Parameter dependent Object Mapping / Conditional Clicks By: Eclipse User on Thu, 02 July 2020 |
3216 |
Mon, 13 July 2020 05:14 By: Eclipse User  |
Which object mapping profile would find my object at runtime By: Eclipse User on Fri, 10 July 2020 |
2798 |
Fri, 10 July 2020 08:15 By: Eclipse User  |
Jubula not recognising AUT window while running test case By: Eclipse User on Thu, 25 June 2020 |
2856 |
Wed, 01 July 2020 05:07 By: Eclipse User  |
Specific Xstream version in rcp plugin Why we still use this specific version of Xstream in jubula rcp plugin By: Eclipse User on Wed, 13 May 2020 |
2867 |
Wed, 03 June 2020 06:20 By: Eclipse User  |
Automate installation of plugin for Jubula software By: Eclipse User on Sat, 16 May 2020 |
2890 |
Sat, 16 May 2020 04:35 By: Eclipse User  |
Plugins for Jubula in silently Install plugins for jubula in silent mode By: Eclipse User on Thu, 14 May 2020 |
2294 |
Thu, 14 May 2020 14:55 By: Eclipse User  |
Developing plugins Problems with plugin wizard By: Eclipse User on Fri, 24 April 2020 |
6078 |
Thu, 07 May 2020 01:48 By: Eclipse User  |
Jubula Connecting to backend database Jubula Connecting to backend database By: Eclipse User on Fri, 24 April 2020 |
5138 |
Mon, 04 May 2020 02:28 By: Eclipse User  |
Unable to run a Java based unit test example Trying to run a Java Unit test for Jubula and it wont work By: Eclipse User on Fri, 10 April 2020 |
6265 |
Mon, 04 May 2020 01:57 By: Eclipse User  |
Executing Javafx 11 Execution error By: Eclipse User on Sun, 19 April 2020 |
3332 |
Mon, 20 April 2020 10:15 By: Eclipse User  |
Help in converting the existing Jubula project to Junit By: Eclipse User on Fri, 10 April 2020 |
10432 |
Mon, 20 April 2020 07:37 By: Eclipse User  |
Many Configuration Errors on random locations Many Configuration Errors on random locations By: Eclipse User on Wed, 04 March 2020 |
8363 |
Mon, 20 April 2020 02:27 By: Eclipse User  |
Error starting org.eclipse.jubula.app.autagent.product project from Eclipse Run autagent with -javaagent from Eclipse By: Eclipse User on Tue, 14 April 2020 |
8561 |
Tue, 14 April 2020 13:12 By: Eclipse User  |
Jubula not recognising buttons Get component not found when screen compacted By: Eclipse User on Tue, 25 February 2020 |
4973 |
Wed, 08 April 2020 08:33 By: Eclipse User  |
Problem with testing various components Observation mode fails on menu components, cannot test more complex components such as checkboxes etc. By: Eclipse User on Thu, 19 March 2020 |
1938 |
Mon, 30 March 2020 04:30 By: Eclipse User  |
Can extracted tests from lean FT and UFT be exported to Jubula? Can extracted tests from lean FT and UFT be exported to Jubula? By: Eclipse User on Fri, 20 March 2020 |
2553 |
Mon, 30 March 2020 04:12 By: Eclipse User  |
Jubula test in Exclipse By: Eclipse User on Fri, 24 January 2020 |
1875 |
Fri, 21 February 2020 01:03 By: Eclipse User  |
Testing SAP How to test SAP GUI with Jubula By: Eclipse User on Fri, 29 November 2019 |
4163 |
Tue, 10 December 2019 02:35 By: Eclipse User  |
How to convert get text in the jubula tool without coding for swing application By: Eclipse User on Wed, 20 November 2019 |
3625 |
Tue, 26 November 2019 01:49 By: Eclipse User  |
Jubula problem ocurred. Start working with test suite By: Eclipse User on Thu, 04 April 2019 |
31404 |
Tue, 12 November 2019 01:42 By: Eclipse User  |
Unable to select and click on a row in a table for an RCP application Receiving Error - "Operation not supported by the selected toolkit" when we are trying to select and click on a row in a table for an RCP application By: Eclipse User on Thu, 10 October 2019 |
2748 |
Wed, 23 October 2019 02:17 By: Eclipse User  |
Testing of AUT launched from another AUT By: Eclipse User on Tue, 08 October 2019 |
16333 |
Tue, 08 October 2019 16:17 By: Eclipse User  |
Autagent does not clean temp files Autagent does not clean temp files By: Eclipse User on Tue, 03 September 2019 |
10961 |
Tue, 08 October 2019 09:03 By: Eclipse User  |
JAVA Swing UI automate the application testing How to test java swing client UI lunch through server By: Eclipse User on Tue, 01 October 2019 |
19377 |
Tue, 08 October 2019 01:37 By: Eclipse User  |
Cannot connet to AUT through rcp plugin By: Eclipse User on Wed, 25 September 2019 |
13640 |
Tue, 08 October 2019 01:29 By: Eclipse User  |
Error while running under embedded AUT agent Javafx error generated by embedded AUT Agent By: Eclipse User on Thu, 05 September 2019 |
12915 |
Thu, 12 September 2019 00:59 By: Eclipse User  |
Error is coming on RCP AUT integration for Jubula By: Eclipse User on Wed, 21 August 2019 |
8702 |
Tue, 10 September 2019 03:16 By: Eclipse User  |
problems with checktextwithcellspec in Jubula 8.7.1.046 problems with checktextwithcellspec in Jubula 8.7.1.046 By: Eclipse User on Wed, 21 August 2019 |
4964 |
Wed, 28 August 2019 01:02 By: Eclipse User  |
Close swing application using Jubula client api in java close a swing application using java By: Eclipse User on Tue, 20 August 2019 |
2110 |
Wed, 21 August 2019 02:05 By: Eclipse User  |
Jubula throws Component not found exception before launching AUT Jubula throws Component not found exception and after that AUT is launched. By: Eclipse User on Tue, 06 August 2019 |
6321 |
Tue, 20 August 2019 06:38 By: Eclipse User  |
How to setup Junit and Jacoco for remote AUT? How to setup Junit and Jacoco for remote AUT? By: Eclipse User on Mon, 12 August 2019 |
3402 |
Tue, 20 August 2019 02:27 By: Eclipse User  |
How to set object recognition profile by jubula's java swing api? By: Eclipse User on Wed, 24 July 2019 |
25853 |
Tue, 13 August 2019 07:54 By: Eclipse User  |
Jubula ITE Won't Launch Installation Help By: Eclipse User on Fri, 26 July 2019 |
1824 |
Tue, 13 August 2019 07:45 By: Eclipse User  |
Jubula Closes on Drag & Drop Bug By: Eclipse User on Tue, 06 August 2019 |
2150 |
Tue, 13 August 2019 07:42 By: Eclipse User  |
Resolving Custom Extension dependencies By: Eclipse User on Tue, 06 August 2019 |
2881 |
Tue, 13 August 2019 05:42 By: Eclipse User  |
Migrate Jubula from 8.4.0 to 8.7.1 By: Eclipse User on Tue, 06 August 2019 |
2189 |
Tue, 13 August 2019 05:34 By: Eclipse User  |
OpenJDK 11 support By: Eclipse User on Thu, 18 April 2019 |
39746 |
Tue, 30 July 2019 04:48 By: Eclipse User  |
Can't install Jubula extension wizard - Eclipse 2019-06 (4.12.0) By: Eclipse User on Tue, 23 July 2019 |
27084 |
Tue, 30 July 2019 04:26 By: Eclipse User  |
Position to click on the button By: Eclipse User on Thu, 25 July 2019 |
17404 |
Tue, 30 July 2019 03:39 By: Eclipse User  |
wait for component before input, but still cant't find component to input By: Eclipse User on Thu, 25 July 2019 |
22241 |
Tue, 30 July 2019 02:45 By: Eclipse User  |
can't install Jubula on windows xp32 By: Eclipse User on Wed, 24 July 2019 |
23532 |
Tue, 30 July 2019 02:40 By: Eclipse User  |
Issues setting up AUT By: Eclipse User on Wed, 24 July 2019 |
3913 |
Tue, 30 July 2019 02:04 By: Eclipse User  |
Adobe AEM (Adobe Experience Manager) HTL2HTML for components Adobe AEM (Adobe Experience Manager) HTL2HTML compile and test (AEM 6.1 soon to be moving to 6.3) By: Eclipse User on Fri, 26 July 2019 |
31252 |
Fri, 26 July 2019 04:58 By: Eclipse User  |
Version 8.221 Java breaks Jubuila Object mapping and test execution disabled By: Eclipse User on Mon, 22 July 2019 |
27401 |
Mon, 22 July 2019 03:56 By: Eclipse User  |
Object Mapping Menu Bar Object Menu not recognising JavaFX MenuBar By: Eclipse User on Tue, 16 July 2019 |
2233 |
Tue, 16 July 2019 09:05 By: Eclipse User  |
Cannot start AutAgent on MAC By: Eclipse User on Wed, 10 July 2019 |
10009 |
Tue, 16 July 2019 03:18 By: Eclipse User  |
Formatting values read into a variable By: Eclipse User on Thu, 11 July 2019 |
8011 |
Tue, 16 July 2019 01:11 By: Eclipse User  |
Setting heuristic match value Recognizing a difficult component By: Eclipse User on Tue, 02 July 2019 |
31308 |
Tue, 09 July 2019 02:35 By: Eclipse User  |
Start Mapping with AUT agent Cant start mapping from the server side By: Eclipse User on Mon, 01 July 2019 |
16108 |
Tue, 09 July 2019 02:32 By: Eclipse User  |
java.io.SreamCorruptedException on a recorded test observed recorded swing By: Eclipse User on Mon, 01 July 2019 |
10662 |
Tue, 02 July 2019 02:03 By: Eclipse User  |
Stuck at the Starting Line Test Cases launch AUT but nothing else By: Eclipse User on Tue, 25 June 2019 |
5317 |
Wed, 26 June 2019 10:17 By: Eclipse User  |
Modal Windows Javafx Can not switch windows By: Eclipse User on Thu, 20 June 2019 |
6670 |
Tue, 25 June 2019 02:14 By: Eclipse User  |
Extending Jubula Adding Extension using Extension Wizard By: Eclipse User on Fri, 31 May 2019 |
54321 |
Tue, 18 June 2019 05:22 By: Eclipse User  |
Checking Border color Testing validation By: Eclipse User on Mon, 17 June 2019 |
5640 |
Tue, 18 June 2019 04:29 By: Eclipse User  |
Test Jobs Test Job Results By: Eclipse User on Wed, 12 June 2019 |
8895 |
Thu, 13 June 2019 04:01 By: Eclipse User  |
Error Replace_Test jubula By: Eclipse User on Thu, 30 May 2019 |
5515 |
Tue, 11 June 2019 08:56 By: Eclipse User  |
importing (xml) project in Jubula 8.7.1 By: Eclipse User on Wed, 29 May 2019 |
56499 |
Tue, 11 June 2019 08:46 By: Eclipse User  |
how to download older version By: Eclipse User on Thu, 30 May 2019 |
51988 |
Thu, 30 May 2019 10:19 By: Eclipse User  |
Exception with running Jubula-core on Eclipse By: Eclipse User on Thu, 23 May 2019 |
30637 |
Wed, 29 May 2019 05:30 By: Eclipse User  |
"Error occurred" closing a window By: Eclipse User on Wed, 22 May 2019 |
24722 |
Tue, 28 May 2019 11:56 By: Eclipse User  |
CZ keyboard - mapping of certain characters does not work CZ keyboard - mapping of certain characters does not work By: Eclipse User on Thu, 14 March 2019 |
11983 |
Tue, 28 May 2019 07:03 By: Eclipse User  |
Working with tables Selecting components in a table By: Eclipse User on Sat, 18 May 2019 |
20736 |
Tue, 21 May 2019 08:35 By: Eclipse User  |
Button Check existence Checking non existence of button By: Eclipse User on Sun, 19 May 2019 |
3403 |
Tue, 21 May 2019 06:23 By: Eclipse User  |
Libraries Creating your own library By: Eclipse User on Sun, 19 May 2019 |
3466 |
Tue, 21 May 2019 06:22 By: Eclipse User  |
Selecting javafx tableview row Mapping tests to Javafx app By: Eclipse User on Sat, 11 May 2019 |
16734 |
Mon, 13 May 2019 08:29 By: Eclipse User  |
Add/develop new Action By: Eclipse User on Wed, 08 May 2019 |
31189 |
Mon, 13 May 2019 02:31 By: Eclipse User  |
AUT stuck 'in progress' AUT not moving to running By: Eclipse User on Wed, 08 May 2019 |
8358 |
Sat, 11 May 2019 06:59 By: Eclipse User  |
Jubula with .bat AUT Object mapper can not connect to running .bat AUT By: Eclipse User on Fri, 03 May 2019 |
5032 |
Wed, 08 May 2019 05:30 By: Eclipse User  |
Can the jubula project be managed by GIT By: Eclipse User on Tue, 23 April 2019 |
2235 |
Wed, 08 May 2019 05:19 By: Eclipse User  |
What is exactly Jubula license ? By: Eclipse User on Fri, 19 April 2019 |
24334 |
Tue, 23 April 2019 01:10 By: Eclipse User  |
AUT with Java 11 By: Eclipse User on Mon, 25 March 2019 |
6114 |
Tue, 02 April 2019 01:39 By: Eclipse User  |
JCommandButton cannot be mapped JCommandButton cannot be mapped By: Eclipse User on Mon, 25 March 2019 |
4436 |
Tue, 26 March 2019 03:58 By: Eclipse User  |
How to manage control of Jubula test execution By: Eclipse User on Wed, 20 March 2019 |
5611 |
Tue, 26 March 2019 02:30 By: Eclipse User  |
HTML testing How to proceed when Jubula HTML toolkit retires By: Eclipse User on Tue, 19 March 2019 |
18122 |
Tue, 19 March 2019 13:16 By: Eclipse User  |
AUT connection failed and object mapping tool is disabled AUT connection failed and object mapping tool is disabled By: Eclipse User on Thu, 21 February 2019 |
4746 |
Tue, 26 February 2019 01:26 By: Eclipse User  |
AUT connection failed when Cisco VPN is running By: Eclipse User on Fri, 08 February 2019 |
6652 |
Tue, 12 February 2019 05:28 By: Eclipse User  |
AUT connection failed Jubula AUT connection By: Eclipse User on Wed, 30 January 2019 |
4067 |
Mon, 04 February 2019 01:28 By: Eclipse User  |
Unable to connect to AUT By: Eclipse User on Tue, 22 January 2019 |
3907 |
Mon, 04 February 2019 01:27 By: Eclipse User  |
Dear Jubula User, I would like to inform you that as every year the Jubula Team says goodbye during By: Eclipse User on Fri, 14 December 2018 |
3991 |
Fri, 14 December 2018 01:12 By: Eclipse User  |
Test support for applications combining SWT/Swing By: Eclipse User on Thu, 10 April 2014 |
6619 |
Mon, 03 December 2018 06:05 By: Eclipse User  |
User defined functions: external methods HowTo By: Eclipse User on Thu, 02 August 2018 |
5508 |
Tue, 06 November 2018 04:48 By: Eclipse User  |
Can't install jubula for committers using oomph By: Eclipse User on Thu, 25 October 2018 |
4128 |
Tue, 06 November 2018 04:38 By: Eclipse User  |
Error when exporting project By: Eclipse User on Tue, 23 October 2018 |
4224 |
Tue, 06 November 2018 04:19 By: Eclipse User  |
Jubula evaluation I can't get any tutorial or example anywhere to work on Windows 10 or Linux. By: Eclipse User on Wed, 24 October 2018 |
3003 |
Tue, 06 November 2018 04:14 By: Eclipse User  |
Creating a custom JFace based extension Questions on how to create a custom extension based on a custom jface.Viewer implementation By: Eclipse User on Mon, 27 November 2017 |
7270 |
Wed, 24 October 2018 07:29 By: Eclipse User  |
Second time running automation, Not able to click on OK button By: Eclipse User on Mon, 19 January 2015 |
9645 |
Thu, 27 September 2018 07:56 By: Eclipse User  |
Unable to start AUT which is a JNLP successfully By: Eclipse User on Mon, 24 September 2018 |
3697 |
Tue, 25 September 2018 02:40 By: Eclipse User  |
Starting SWT AUT Error when starting SWT Application as AUT By: Eclipse User on Tue, 28 June 2011 |
22 |
24852 |
Mon, 24 September 2018 05:47 By: Eclipse User  |
3754 |
Mon, 24 September 2018 05:37 By: Eclipse User  |
Given names for components defined by e4xmi How to use the createCIWithGivenName-Method to map components defined by the e4xmi By: Eclipse User on Tue, 04 September 2018 |
5191 |
Wed, 19 September 2018 02:10 By: Eclipse User  |
AUT Server can't connect to client when testexec started from jenkins AUT agent ocassionaly gets into zombie state in 8.6 standalone, can be connected to but won't behave By: Eclipse User on Tue, 28 August 2018 |
5599 |
Fri, 07 September 2018 09:53 By: Eclipse User  |
Object Mapping in a Swing+Jide Application with JDesktopPanes By: Eclipse User on Tue, 21 August 2018 |
2714 |
Tue, 28 August 2018 04:07 By: Eclipse User  |
new line characters in input text - need help need help By: Eclipse User on Mon, 27 August 2018 |
3570 |
Tue, 28 August 2018 01:39 By: Eclipse User  |
General special characters General special characters misinterpret in Editor By: Eclipse User on Mon, 16 April 2012 |
8354 |
Mon, 27 August 2018 11:37 By: Eclipse User  |
User defined functions: extension functions 1 HowTo By: Eclipse User on Tue, 14 August 2018 |
3827 |
Tue, 14 August 2018 18:08 By: Eclipse User  |
Tree Table input text in specific cells? Tree Table input text in specific cells By: Eclipse User on Tue, 31 July 2018 |
3441 |
Tue, 14 August 2018 06:51 By: Eclipse User  |
Static functions in Jubula - HowTo By: Eclipse User on Wed, 01 August 2018 |
4151 |
Wed, 01 August 2018 15:54 By: Eclipse User  |
Testing GUI in different languages - HowTo By: Eclipse User on Tue, 31 July 2018 |
3895 |
Tue, 31 July 2018 17:55 By: Eclipse User  |
Test an Eclipse RCP application having JavaFX views Creation of a Jubula project for mixed RCP applications By: Eclipse User on Wed, 25 July 2018 |
4197 |
Mon, 30 July 2018 03:28 By: Eclipse User  |
Jubula 8.6.0 is released By: Eclipse User on Fri, 02 March 2018 |
7774 |
Thu, 26 July 2018 04:39 By: Eclipse User  |
Entry to application via Citrix By: Eclipse User on Thu, 05 July 2018 |
3834 |
Tue, 24 July 2018 01:49 By: Eclipse User  |
Problem with object mapping Mapping By: Eclipse User on Fri, 06 July 2018 |
2943 |
Mon, 16 July 2018 07:42 By: Eclipse User  |
Testing content of SwingNode in JavaFX application By: Eclipse User on Wed, 02 May 2018 |
4117 |
Fri, 04 May 2018 05:19 By: Eclipse User  |
Web Automation - HTML web automation - HTML By: Eclipse User on Tue, 10 April 2018 |
6531 |
Mon, 16 April 2018 02:08 By: Eclipse User  |
Jubula can not map objects on the installer that built by InstallAnywhere2015 Jubula can not map objects on the installer that built by InstallAnywhere2015 By: Eclipse User on Tue, 20 March 2018 |
5528 |
Wed, 04 April 2018 03:24 By: Eclipse User  |
Internal error 3003: Unexpected error occurred - NullPointerException Get this error when I copied an existing Test case to an existing test suite By: Eclipse User on Wed, 19 July 2017 |
9988 |
Tue, 27 March 2018 02:49 By: Eclipse User  |
GEF inspector lost AUTconnection Click on the GEF inspector, AUT connection is lost. By: Eclipse User on Wed, 14 March 2018 |
3764 |
Wed, 21 March 2018 16:13 By: Eclipse User  |
Jubula 8.6 can't catpute controls in Ubuntu 16.04 By: Eclipse User on Mon, 19 March 2018 |
3082 |
Tue, 20 March 2018 08:51 By: Eclipse User  |
Store my own data relating to a TestSuite I would like to store some data relevant to a single Testsuite By: Eclipse User on Fri, 16 March 2018 |
4897 |
Tue, 20 March 2018 08:50 By: Eclipse User  |
Query Jubula Database I would like to poke the db for information regarding currently running tests and other things By: Eclipse User on Fri, 16 March 2018 |
4769 |
Tue, 20 March 2018 08:48 By: Eclipse User  |
New to Extending Rootkits I try to extend Jubula with my own Rootkit but just can't find step by step tutorials By: Eclipse User on Mon, 05 February 2018 |
6710 |
Thu, 22 February 2018 03:27 By: Eclipse User  |
"Point to click is outside of component" When select "File" menu by texpath on U "Point to click is outside of component" When select "File" menu by texpath on Ubuntu platform By: Eclipse User on Wed, 13 September 2017 |
24360 |
Thu, 22 February 2018 01:59 By: Eclipse User  |
How to ensure the correct application is tested By: Eclipse User on Mon, 05 September 2011 |
10778 |
Thu, 22 February 2018 00:44 By: Eclipse User  |
Want to extend Jubula to work with KTable KTable is a simple SWT Canvas extension but is not recognised in Jubula By: Eclipse User on Thu, 11 January 2018 |
9006 |
Tue, 13 February 2018 03:11 By: Eclipse User  |
how to check multiple lines in clipboard I want to check 100 lines of data which is in clipboard By: Eclipse User on Thu, 08 February 2018 |
5131 |
Mon, 12 February 2018 23:03 By: Eclipse User  |
Unable to perform Object mapping operation on eclipse based IDE Jubula Object mapping causes the Ubuntu UI to stop working. By: Eclipse User on Mon, 05 February 2018 |
6015 |
Mon, 12 February 2018 05:15 By: Eclipse User  |
SimpleAdder test execution doesn't start on remote AUTagent By: Eclipse User on Wed, 27 December 2017 |
6559 |
Mon, 12 February 2018 05:09 By: Eclipse User  |
Problem with hidden Menus in MenuBar for JavaFX AUT Action Exception when trying to select Menus from MenuBar with hidden Menus By: Eclipse User on Wed, 10 January 2018 |
4480 |
Tue, 16 January 2018 05:54 By: Eclipse User  |
Jubula 8.5, no main class in swing aut config Jubula 8.5, no main class in aut config By: Eclipse User on Thu, 21 December 2017 |
8138 |
Wed, 10 January 2018 07:35 By: Eclipse User  |
Poll: Jubula 8.5 can't catpute controls in Ubuntu 16.04 Jubula 8.5 can't catpute controls in Ubuntu 16.04 By: Eclipse User on Wed, 06 December 2017 |
12196 |
Thu, 28 December 2017 21:37 By: Eclipse User  |
Jubula Christmas Time By: Eclipse User on Mon, 18 December 2017 |
5177 |
Mon, 18 December 2017 09:45 By: Eclipse User  |
foreground window change - ub_ Tbc_checkExistenceOfTab_byValueOrString By: Eclipse User on Wed, 13 December 2017 |
4030 |
Wed, 13 December 2017 14:59 By: Eclipse User  |
