Announcement: FORUM MOVED TO GITHUB By: Eclipse User on Thu, 25 November 2021 |
5065 |
Thu, 25 November 2021 15:24 By: Eclipse User  |
Getting Wrong long description Font Size in work order details report Getting Wrong long description Font Size in work order details report By: Eclipse User on Wed, 21 August 2024 |
4138 |
Wed, 21 August 2024 08:45 By: Eclipse User  |
Unable to open BIRT generated xls file in MS Excel The file format and extension of 'Statement.xls' don't match. The file could be corrupted or unsafe. Unless you trust its source, don't open it. Do you want to open it anyway? By: Eclipse User on Mon, 27 November 2023 |
1936 |
Mon, 27 November 2023 21:56 By: Eclipse User  |
Unable to view postgres table columns or data form BIRT 3.7.1 Unable to view postgres table columns or data form BIRT 3.7.1 By: Eclipse User on Thu, 03 August 2023 |
2436 |
Thu, 03 August 2023 01:54 By: Eclipse User  |
Birt designer All-in-one Disable default sorting in crosstab columns By: Eclipse User on Mon, 26 June 2023 |
1820 |
Mon, 26 June 2023 07:55 By: Eclipse User  |
Issue: Birt migration from 2.5.2 to 4.9.0 (Master page repeating in header on all pages) Trying to create report with two different master pages. One that will only aply on very first page. Second one will apply from second page and repeat till the end of all pages. We are trying to migra By: Eclipse User on Mon, 08 May 2023 |
1808 |
Mon, 08 May 2023 05:32 By: Eclipse User  |
Eclipse not working on my MacBook need a working version of eclipse to do BIRT report By: Eclipse User on Sun, 09 October 2022 |
3235 |
Wed, 26 April 2023 11:29 By: Eclipse User  |
Birt page number Birt page number not working By: Eclipse User on Wed, 26 April 2023 |
1640 |
Wed, 26 April 2023 05:50 By: Eclipse User  |
Printing masterpage Printing masterpage By: Eclipse User on Tue, 24 January 2023 |
1815 |
Tue, 24 January 2023 12:51 By: Eclipse User  |
birt report generation using eclipse[Maximo] Generate the report just like in the pm forecast By: Eclipse User on Fri, 04 November 2022 |
3072 |
Fri, 04 November 2022 01:39 By: Eclipse User  |
BIRT Report exported to Word BIRT Report exported to MS Word distorts HTML content By: Eclipse User on Mon, 19 September 2022 |
1835 |
Mon, 19 September 2022 09:17 By: Eclipse User  |
Date format in Birt 4.9 is coming out like this "20 de set. de 2022" in reports problem encountered while migrating from birt 4.4 to 4.9 By: Eclipse User on Thu, 15 September 2022 |
2816 |
Thu, 15 September 2022 15:10 By: Eclipse User  |
how to make pagination in birt report with java By: Eclipse User on Thu, 01 September 2022 |
3270 |
Thu, 01 September 2022 03:04 By: Eclipse User  |
Cross Tab Report I want to sum the items as they are getting separted by month By: Eclipse User on Fri, 12 August 2022 |
3067 |
Fri, 12 August 2022 05:52 By: Eclipse User  |
Basic BIRT Install instructions and downloads for beginners? Get started with BIRT, downloads, installation By: Eclipse User on Thu, 04 August 2022 |
2956 |
Thu, 04 August 2022 14:18 By: Eclipse User  |
BIRT.WAR in Birt Runtime gives Error Birt.war gives error in Birt Runtime By: Eclipse User on Fri, 15 July 2022 |
2415 |
Mon, 18 July 2022 13:20 By: Eclipse User  |
BIRT - Sorting a grid How to sort a grid in BIRT By: Eclipse User on Mon, 18 July 2022 |
3301 |
Mon, 18 July 2022 10:56 By: Eclipse User  |
Is BIRT supports Time Series database or can we create ODA for the same? BIRT database connection By: Eclipse User on Mon, 04 July 2022 |
4103 |
Mon, 04 July 2022 11:35 By: Eclipse User  |
Page Break Issue Issuing in PDF output. By: Eclipse User on Tue, 21 June 2022 |
18938 |
Tue, 21 June 2022 10:33 By: Eclipse User  |
Eclipse -BIRT Latest version of Eclipse with BIRT report designer (All-in-One) By: Eclipse User on Fri, 10 June 2022 |
4920 |
Fri, 10 June 2022 04:55 By: Eclipse User  |
Birt: Background image doesn't work in word file but it is working in PDF background image in a grid By: Eclipse User on Tue, 08 March 2022 |
6009 |
Tue, 08 March 2022 04:58 By: Eclipse User  |
Data Truncation while exporting rptdesign file to PDF Data Truncation while exporting rptdesign file to PDF By: Eclipse User on Tue, 15 February 2022 |
3059 |
Tue, 15 February 2022 22:56 By: Eclipse User  |
BIRT Install Install BIRT on Eclipse - BIRT Framework not installed By: Eclipse User on Tue, 11 January 2022 |
3713 |
Tue, 11 January 2022 16:12 By: Eclipse User  |
Update Sql table with Birt aggregation value after report run I want to insert or update the sql table when I will run the report and whatever the output of aggregation is . By: Eclipse User on Tue, 14 December 2021 |
3527 |
Tue, 14 December 2021 10:00 By: Eclipse User  |
Error while deploying birt.war file on weblogic 12c Deployment of birt.war file on weblogic 12c failed with an error By: Eclipse User on Thu, 23 May 2019 |
7443 |
Tue, 07 December 2021 11:11 By: Eclipse User  |
Problem with character encoding (?) [in app & in designer] [Solved] By: Eclipse User on Fri, 29 June 2018 |
6854 |
Thu, 02 December 2021 15:35 By: Eclipse User  |
BIRT 4.8.0 / 4.9.0 - Red Hat Enterprise Linux 8 By: Eclipse User on Thu, 02 December 2021 |
3719 |
Thu, 02 December 2021 09:40 By: Eclipse User  |
How to upgrade poi jar for birt-runtime jar? By: Eclipse User on Tue, 30 November 2021 |
4197 |
Tue, 30 November 2021 01:42 By: Eclipse User  |
BIRT 4.9.0 released? By: Eclipse User on Fri, 15 October 2021 |
4765 |
Mon, 29 November 2021 08:46 By: Eclipse User  |
Null type when creating a bulk report By: Eclipse User on Wed, 10 November 2021 |
4273 |
Mon, 29 November 2021 08:45 By: Eclipse User  |
Report will not generate By: Eclipse User on Mon, 08 November 2021 |
3951 |
Mon, 29 November 2021 08:42 By: Eclipse User  |
Will Birt 4.9 support Java 11 Will birt be kept alive? By: Eclipse User on Wed, 03 November 2021 |
5682 |
Sun, 28 November 2021 06:33 By: Eclipse User  |
Force report onto one page? BIRT - How to force a report to display on one page By: Eclipse User on Wed, 17 November 2021 |
3647 |
Sat, 27 November 2021 08:07 By: Eclipse User  |
How to create a tag in xml while generating the pdf from rptdesign How to create a tag in xml while generating the pdf from rptdesign By: Eclipse User on Fri, 26 November 2021 |
2064 |
Sat, 27 November 2021 06:49 By: Eclipse User  |
Birt 4.7 / Tomcat 9 / MySQL / JVM 11 / Debian Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc. By: Eclipse User on Tue, 23 November 2021 |
2198 |
Thu, 25 November 2021 15:23 By: Eclipse User  |
How to calculate xlsx columns width from page coordinates? By: Eclipse User on Tue, 09 November 2021 |
3369 |
Tue, 09 November 2021 01:53 By: Eclipse User  |
BIRT 2.5.1: IReportDocument.getPageNumber(bookMark) returns wrong page number? By: Eclipse User on Wed, 10 February 2010 |
11388 |
Mon, 08 November 2021 23:21 By: Eclipse User  |
Excluding Holidays By: Eclipse User on Fri, 22 October 2021 |
3445 |
Fri, 22 October 2021 21:55 By: Eclipse User  |
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report. Error occurring reason By: Eclipse User on Fri, 15 October 2021 |
5560 |
Fri, 22 October 2021 21:48 By: Eclipse User  |
Show Checkbox image or unchecked image from result show an image depending on if the column result equals 1 or 0? By: Eclipse User on Tue, 19 October 2021 |
2517 |
Fri, 22 October 2021 07:11 By: Eclipse User  |
Request for help passing an application parameter in Maximo BIRT By: Eclipse User on Fri, 15 October 2021 |
3362 |
Fri, 15 October 2021 14:14 By: Eclipse User  |
BIRT and ORM By: Eclipse User on Tue, 02 November 2004 |
100773 |
Fri, 08 October 2021 20:47 By: Eclipse User  |
report middleware standard and something By: Eclipse User on Thu, 02 September 2004 |
19 |
418964 |
Question By: Eclipse User on Wed, 25 August 2004 |
30 |
423431 |
Meta-data By: Eclipse User on Wed, 08 September 2004 |
116361 |
Fri, 08 October 2021 20:46 By: Eclipse User  |
Introducing Certive By: Eclipse User on Thu, 26 August 2004 |
29 |
423580 |
SVG support in charting engine By: Eclipse User on Tue, 24 August 2004 |
39 |
425217 |
Fri, 08 October 2021 20:45 By: Eclipse User  |
EMF and things By: Eclipse User on Thu, 26 August 2004 |
30 |
436447 |
Fri, 08 October 2021 20:42 By: Eclipse User  |
Welcome to eclipse.birt |
486657 |
Fri, 08 October 2021 20:41 By: Eclipse User  |
Inital thoughts on proposal By: Eclipse User on Wed, 25 August 2004 |
22 |
418777 |
Fri, 08 October 2021 20:39 By: Eclipse User  |
Welcome to the Business Intelligence and Reporting Tools Newsgroup! By: Eclipse User on Tue, 24 August 2004 |
22 |
413342 |
Set a XML DataSource Programmatically ( ... 2 3 4 5 6) By: Eclipse User on Tue, 29 January 2008 |
1036 |
56112 |
Fri, 08 October 2021 18:30 By: Eclipse User  |
crosstab refresh data cube ( 1 2 3) By: Eclipse User on Fri, 25 January 2008 |
561 |
45487 |
Fri, 08 October 2021 18:22 By: Eclipse User  |
Allow user to dynamically select report's columns By: Eclipse User on Mon, 04 October 2021 |
28996 |
Mon, 04 October 2021 05:51 By: Eclipse User  |
Features of birt 4.9 By: Eclipse User on Wed, 29 September 2021 |
3373 |
Wed, 29 September 2021 04:35 By: Eclipse User  |
Eclipse not build correct new project, always build project old , pleasy help. eclipse build old project in memory By: Eclipse User on Mon, 20 September 2021 |
1555 |
Mon, 20 September 2021 12:17 By: Eclipse User  |
Unable to install BIRT 4.9 Problem installing BIRT 4.9 on eclipse 2021-06 or 2021-03 By: Eclipse User on Mon, 26 July 2021 |
5478 |
Sat, 18 September 2021 17:37 By: Eclipse User  |
BIRT with Latest Eclipse Verion By: Eclipse User on Wed, 13 January 2021 |
3355 |
Sat, 18 September 2021 17:36 By: Eclipse User  |
Replacing one column with another column if null How to replace column result if null with another column result By: Eclipse User on Fri, 17 September 2021 |
1918 |
Fri, 17 September 2021 12:30 By: Eclipse User  |
2 FIlters with OR not AND filters, multivalue, parameters By: Eclipse User on Wed, 15 September 2021 |
3406 |
Wed, 15 September 2021 04:25 By: Eclipse User  |
Concurrently not able to open birtreport When I tried to open same report concurretly getting below IO exception By: Eclipse User on Fri, 10 September 2021 |
3058 |
Fri, 10 September 2021 13:51 By: Eclipse User  |
PDF export cut off from the right. By: Eclipse User on Thu, 27 March 2008 |
4634 |
Fri, 10 September 2021 11:01 By: Eclipse User  |
Handle URL in BIRT runtime Handle URL in BIRT runtime By: Eclipse User on Thu, 02 September 2021 |
3257 |
Fri, 10 September 2021 10:54 By: Eclipse User  |
Group : Drop [All | Detail] and PageBreak Height of group column with Drop All/Detail is more than detail By: Eclipse User on Fri, 10 September 2021 |
3235 |
Fri, 10 September 2021 08:45 By: Eclipse User  |
Error with Image generating for PDF report Error with Image generating for PDF report By: Eclipse User on Wed, 23 June 2021 |
3112 |
Thu, 09 September 2021 20:48 By: Eclipse User  |
In Remedy the report output is different when it is run by the reports console and Planning By: Eclipse User on Tue, 07 September 2021 |
2823 |
Tue, 07 September 2021 15:41 By: Eclipse User  |
pdf format not rendering properly By: Eclipse User on Mon, 06 September 2021 |
2888 |
Mon, 06 September 2021 06:35 By: Eclipse User  |
Download automatic report (xlsx) Download automatic report (xlsx) - BIRT By: Eclipse User on Tue, 24 August 2021 |
3626 |
Thu, 26 August 2021 12:54 By: Eclipse User  |
Group Row Number By: Eclipse User on Wed, 07 February 2007 |
19 |
7868 |
Thu, 26 August 2021 01:17 By: Eclipse User  |
birt runningsum on group i want to display the serial number in a table of row group By: Eclipse User on Wed, 25 August 2021 |
2396 |
Wed, 25 August 2021 04:00 By: Eclipse User  |
Create Multiple Filters in an SQL Query - Connecting via JDBC Create Multiple Filters in an SQL Query - Connecting via JDBC By: Eclipse User on Fri, 20 August 2021 |
1862 |
Mon, 23 August 2021 10:08 By: Eclipse User  |
NULL issue NULLS By: Eclipse User on Wed, 28 July 2021 |
2196 |
Fri, 30 July 2021 00:58 By: Eclipse User  |
Will vulnerability be addressed in v4.9? Security Question By: Eclipse User on Wed, 28 July 2021 |
2831 |
Wed, 28 July 2021 11:28 By: Eclipse User  |
Change display text on parameter By: Eclipse User on Mon, 12 July 2021 |
3906 |
Mon, 26 July 2021 20:02 By: Eclipse User  |
NullPointerException in GroupInformationUtil.getStartingGroupLevel By: Eclipse User on Thu, 22 July 2021 |
2169 |
Thu, 22 July 2021 16:59 By: Eclipse User  |
NO DISPLAY IN CROSSTAB NOT RUNNING CROSSTAB NO DISPLAY By: Eclipse User on Fri, 16 July 2021 |
2271 |
Fri, 16 July 2021 03:39 By: Eclipse User  |
CSV file comma is replaced by space issue CSV file comma is replaced by space issue By: Eclipse User on Wed, 07 July 2021 |
2649 |
Wed, 07 July 2021 01:36 By: Eclipse User  |
GC Overhead Limit Exceeded Memory Error for Tables with more than 100 rows By: Eclipse User on Tue, 06 July 2021 |
2841 |
Tue, 06 July 2021 14:35 By: Eclipse User  |
Birt 4.9 on Maven! Is going to be on maven? By: Eclipse User on Fri, 02 July 2021 |
2691 |
Fri, 02 July 2021 08:25 By: Eclipse User  |
Second table data is missing in the BIRT report Second table data is missing in the BIRT report By: Eclipse User on Fri, 02 July 2021 |
2642 |
Fri, 02 July 2021 06:39 By: Eclipse User  |
Cannot open properties and property manager By: Eclipse User on Fri, 02 July 2021 |
4051 |
Fri, 02 July 2021 04:51 By: Eclipse User  |
Hide table based on sub datasets By: Eclipse User on Thu, 01 July 2021 |
2862 |
Thu, 01 July 2021 20:41 By: Eclipse User  |
Unable to Find Eclipse IDE for BIRT Installation Unable to Find Eclipse IDE for BIRT Installation By: Eclipse User on Fri, 25 June 2021 |
1877 |
Fri, 25 June 2021 08:09 By: Eclipse User  |
BIRT 4.3.2 version download By: Eclipse User on Mon, 24 May 2021 |
7938 |
Fri, 25 June 2021 01:28 By: Eclipse User  |
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc. By: Eclipse User on Thu, 24 June 2021 |
2764 |
Thu, 24 June 2021 09:11 By: Eclipse User  |
Can you have a parameter (filter) on a computed column Computed column parameter By: Eclipse User on Thu, 13 May 2021 |
2265 |
Thu, 24 June 2021 06:51 By: Eclipse User  |
image in text field - or how high is 1.3 cm? By: Eclipse User on Tue, 22 June 2021 |
2784 |
Tue, 22 June 2021 14:21 By: Eclipse User  |
red circle with a white cross red circle with a white cross Even if the connection to the BDD is successful By: Eclipse User on Tue, 22 June 2021 |
2904 |
Tue, 22 June 2021 05:29 By: Eclipse User  |
BIRT - version may be negative or may be greater than 255 Getting error when upgrading to jdk version By: Eclipse User on Fri, 04 December 2020 |
6236 |
Wed, 16 June 2021 16:05 By: Eclipse User  |
AWS for BIRT How do I retrieve images from our AWS to put dynamically onto BIRT report? By: Eclipse User on Tue, 15 June 2021 |
1990 |
Wed, 16 June 2021 00:13 By: Eclipse User  |
BIRT report to create the csv file and report generation Using BIRT report to create the csv file and normal process to run the report By: Eclipse User on Thu, 10 June 2021 |
3527 |
Thu, 10 June 2021 14:09 By: Eclipse User  |
Error 500: java.lang.NoClassDefFoundError com.ibm.icu.impl.ICUResourceBundle(initialization failure) Caused by: java.lang.IllegalArgumentException: Invalid version number: Version number may be negative or greater than 255 By: Eclipse User on Thu, 20 May 2021 |
8682 |
Wed, 09 June 2021 06:29 By: Eclipse User  |
Difference between BIRT Designer & Runtime using Excel emitter By: Eclipse User on Wed, 22 August 2018 |
6053 |
Mon, 07 June 2021 19:21 By: Eclipse User  |
create multiple sheets in Excel report create multiple sheets in Excel report where only grids are used in .rpt design By: Eclipse User on Mon, 10 April 2017 |
13517 |
Mon, 07 June 2021 04:19 By: Eclipse User  |
Problem Deploying Birt Viewer from latest Runtime Missing org.eclipse.birt.report.listener.ViewerServletContextListener By: Eclipse User on Tue, 23 February 2021 |
4217 |
Fri, 04 June 2021 14:29 By: Eclipse User  |
Avoid word cutting by automatic line break Avoid word cutting by automatic line break By: Eclipse User on Fri, 04 June 2021 |
2465 |
Fri, 04 June 2021 09:16 By: Eclipse User  |
Report with Birt Help Birt By: Eclipse User on Wed, 02 June 2021 |
2207 |
Wed, 02 June 2021 13:04 By: Eclipse User  |
Report greater than margin Report greater than margin By: Eclipse User on Tue, 01 June 2021 |
2200 |
Tue, 01 June 2021 13:22 By: Eclipse User  |
Birt report table with dynamic column widths Looking for a way to make the column widths dependent on a parameter By: Eclipse User on Mon, 31 May 2021 |
2360 |
Mon, 31 May 2021 02:32 By: Eclipse User  |
Bulk modify fields Looking for a way to quickly decrease all top/bottom padding values to zero. By: Eclipse User on Wed, 26 May 2021 |
2599 |
Wed, 26 May 2021 10:23 By: Eclipse User  |
Want to add group, section headers along with header and footers Want to add group, section headers along with header and footers By: Eclipse User on Tue, 25 May 2021 |
2673 |
Tue, 25 May 2021 12:57 By: Eclipse User  |
No response when attempting to view BIRT report (all options) Unable to view a BIRT report preview in web viewer, XLSX, PDF or any other option available. By: Eclipse User on Fri, 12 February 2021 |
6512 |
Mon, 24 May 2021 15:12 By: Eclipse User  |
Survey as part of my bachelor thesis topic: Diffusion rate of open source business software By: Eclipse User on Sat, 22 May 2021 |
2710 |
Sat, 22 May 2021 15:45 By: Eclipse User  |
Profit shows NaN instead of result Nan result calculating profit using a computed column By: Eclipse User on Tue, 28 January 2020 |
2399 |
Thu, 20 May 2021 07:14 By: Eclipse User  |
Page footer displays in wrong place when preview in Web Viewer/print the report Page footer displays in wrong place when preview in Web Viewer/print the report By: Eclipse User on Wed, 12 May 2021 |
2579 |
Wed, 12 May 2021 09:03 By: Eclipse User  |
Configure wildcard symbol in report parameter By: Eclipse User on Fri, 07 May 2021 |
2720 |
Mon, 10 May 2021 00:54 By: Eclipse User  |
The sound in my device cannot work. By: Eclipse User on Mon, 10 May 2021 |
2540 |
Mon, 10 May 2021 00:51 By: Eclipse User  |
Create Report By: Eclipse User on Fri, 07 May 2021 |
2601 |
Fri, 07 May 2021 11:55 By: Eclipse User  |
Footer is floating in web viewer/HTML footer "floats" after the last content, how to get it in fixed position? By: Eclipse User on Fri, 07 May 2021 |
2641 |
Fri, 07 May 2021 08:50 By: Eclipse User  |
Birt Export Birt export from copied Link By: Eclipse User on Wed, 05 May 2021 |
2701 |
Wed, 05 May 2021 11:37 By: Eclipse User  |
Get value from chart + count in Data Cube Get value from chart in report to use in it in other place of report By: Eclipse User on Wed, 05 May 2021 |
2892 |
Wed, 05 May 2021 07:09 By: Eclipse User  |
push in array object replace all values birt reporte By: Eclipse User on Mon, 03 May 2021 |
2549 |
Mon, 03 May 2021 16:24 By: Eclipse User  |
Automatically open print-dialog with generated PDF By: Eclipse User on Fri, 30 April 2021 |
2895 |
Fri, 30 April 2021 02:47 By: Eclipse User  |
Testing BIRT report Testing BIRT report 127.0.0.1 Error By: Eclipse User on Wed, 21 April 2021 |
2908 |
Tue, 27 April 2021 15:07 By: Eclipse User  |
Optional Grouping By: Eclipse User on Mon, 26 April 2021 |
2203 |
Tue, 27 April 2021 01:58 By: Eclipse User  |
Invalid version number: Version number may be negative or greater than 255 Invalid version number: Version number may be negative or greater than 255 By: Eclipse User on Mon, 22 February 2021 |
8895 |
Thu, 22 April 2021 02:33 By: Eclipse User  |
BIRT 4.3.2 Migration issue Unable to see the data in the output file as expected right after the upgrade By: Eclipse User on Wed, 21 April 2021 |
2669 |
Wed, 21 April 2021 09:49 By: Eclipse User  |
Using Records from other Dataset as parameter By: Eclipse User on Sun, 18 April 2021 |
2446 |
Sun, 18 April 2021 14:22 By: Eclipse User  |
Null Pointer in 4.2.2 Developer Null Pointer in 4.2.2 Developer when editing a rather larger dataset By: Eclipse User on Thu, 15 April 2021 |
2145 |
Thu, 15 April 2021 14:15 By: Eclipse User  |
Run-time parameter no longer defaults to "Null Value" By: Eclipse User on Mon, 12 April 2021 |
2401 |
Mon, 12 April 2021 12:35 By: Eclipse User  |
Neon Expression Builder - IF statement Syntax how to format an if condition in BIRT chart expression builder By: Eclipse User on Fri, 09 April 2021 |
1862 |
Fri, 09 April 2021 20:54 By: Eclipse User  |
Format Value in Chart Legend Format Value in Chart Legend as currency amount By: Eclipse User on Thu, 25 March 2021 |
2361 |
Fri, 09 April 2021 10:33 By: Eclipse User  |
BIRT Support for JavaScript Timers/Intervals Setting A Timer/Interval By: Eclipse User on Fri, 09 April 2021 |
2454 |
Fri, 09 April 2021 10:26 By: Eclipse User  |
Blank Page Insertion Blank Page Insertion at group level By: Eclipse User on Thu, 08 April 2021 |
2386 |
Thu, 08 April 2021 01:09 By: Eclipse User  |
How to change default width to <table> html How to change default width to <table> html By: Eclipse User on Tue, 30 March 2021 |
2332 |
Tue, 30 March 2021 14:32 By: Eclipse User  |
Editing Reports (Running Linux on QNAP) By: Eclipse User on Sun, 28 March 2021 |
2279 |
Sun, 28 March 2021 05:00 By: Eclipse User  |
How to download BIRT excel report programmatically with specific page range Downloading BIRT report with specific page range. By: Eclipse User on Fri, 26 March 2021 |
2480 |
Fri, 26 March 2021 02:14 By: Eclipse User  |
birt report to print Birt print By: Eclipse User on Thu, 25 March 2021 |
2607 |
Thu, 25 March 2021 00:34 By: Eclipse User  |
XML Source Script Overwritten By: Eclipse User on Wed, 24 March 2021 |
2501 |
Wed, 24 March 2021 05:24 By: Eclipse User  |
Cannot Find Companion Shared Library By: Eclipse User on Thu, 19 March 2020 |
4281 |
Wed, 24 March 2021 04:12 By: Eclipse User  |
Error happened while running the report. when I export Report as Xlxs By: Eclipse User on Tue, 23 March 2021 |
2631 |
Tue, 23 March 2021 22:13 By: Eclipse User  |
Reports not updated with changes to shared library By: Eclipse User on Fri, 21 August 2009 |
5283 |
Fri, 19 March 2021 12:18 By: Eclipse User  |
How to repeat a row on each new page ? By: Eclipse User on Tue, 18 October 2011 |
13603 |
Wed, 17 March 2021 07:48 By: Eclipse User  |
Asset Hierarchy in BIRT Asset Hierarchy in BIRT By: Eclipse User on Wed, 17 March 2021 |
2661 |
Wed, 17 March 2021 07:35 By: Eclipse User  |
How to repeat one row in birt How to repeat one row in birt By: Eclipse User on Wed, 17 March 2021 |
2584 |
Wed, 17 March 2021 06:31 By: Eclipse User  |
Eclipse RCP and Birt together Not able to find the compatible versions of RCP and Birt together By: Eclipse User on Wed, 17 March 2021 |
2554 |
Wed, 17 March 2021 06:29 By: Eclipse User  |
How to reformat a computed column on csv export? Modify output data on CSV export By: Eclipse User on Mon, 15 March 2021 |
2462 |
Mon, 15 March 2021 11:13 By: Eclipse User  |
There is no way to add a parameter to the data set (flat file), for use in the child table There is no way to add a parameter to the data set (flat file), for use in the child table By: Eclipse User on Wed, 10 March 2021 |
2423 |
Mon, 15 March 2021 05:46 By: Eclipse User  |
MANIFEST.MF missing in Eclipse BIRT designer Error Log indicates MANIFEST.MF (The system cannot find the path specified) By: Eclipse User on Sat, 13 March 2021 |
3093 |
Sat, 13 March 2021 18:56 By: Eclipse User  |
Chart Legend Change Legend Series Dynamically By: Eclipse User on Wed, 10 March 2021 |
3860 |
Wed, 10 March 2021 12:17 By: Eclipse User  |
Help with Eclipse/BIRT install Help with The library with the namespace "xyz" is not found. error By: Eclipse User on Wed, 10 March 2021 |
2777 |
Wed, 10 March 2021 11:27 By: Eclipse User  |
BIRT report issue using wildcard % with SQL BIRT report issue using wildcard % with SQL By: Eclipse User on Wed, 10 March 2021 |
2632 |
Wed, 10 March 2021 03:38 By: Eclipse User  |
BIRT: Combining results from two tables or cubes By: Eclipse User on Tue, 09 March 2021 |
2505 |
Tue, 09 March 2021 03:00 By: Eclipse User  |
Can a MAX Function serve as a Search Parameter Can a MAX Function serve as a Search Parameter By: Eclipse User on Fri, 05 March 2021 |
2438 |
Fri, 05 March 2021 13:56 By: Eclipse User  |
Customize Viewerexception when i want to create custome error for org.eclipse.birt.report.exception.ViewerException By: Eclipse User on Thu, 04 March 2021 |
2639 |
Thu, 04 March 2021 04:01 By: Eclipse User  |
[Resolved] Generate pdf/html with rptdesign By: Eclipse User on Wed, 06 May 2015 |
8618 |
Thu, 04 March 2021 02:53 By: Eclipse User  |
Birt Sorting Sorting by date, conditioncode, ascending, descending By: Eclipse User on Thu, 11 February 2021 |
7507 |
Wed, 03 March 2021 17:05 By: Eclipse User  |
Localization with SubString How to combine SubString with localized content By: Eclipse User on Mon, 01 March 2021 |
2688 |
Wed, 03 March 2021 09:10 By: Eclipse User  |
Unable to Pass Parameter in URL Passing Dataset Parameter in URL ignores value By: Eclipse User on Mon, 01 March 2021 |
2664 |
Mon, 01 March 2021 16:32 By: Eclipse User  |
Denormalizing Data in a Report Adding data to one report column based on value from other column By: Eclipse User on Mon, 15 April 2019 |
37594 |
Sat, 27 February 2021 04:20 By: Eclipse User  |
ROTATED IMAGES IN PDF OUTPUT - MAXIMO MAXIMO - WHEN INSERTING A VERTICAL PHOTO, THIS PHOTO IS ROTATED OF 90° By: Eclipse User on Tue, 23 February 2021 |
2438 |
Tue, 23 February 2021 03:31 By: Eclipse User  |
genReport.bat event handler class not found By: Eclipse User on Fri, 19 February 2021 |
2301 |
Fri, 19 February 2021 09:13 By: Eclipse User  |
Duplicate class definition in Birt runtime 4.2 By: Eclipse User on Tue, 31 July 2012 |
17357 |
Tue, 09 February 2021 10:35 By: Eclipse User  |
Showing data from a shift that covers two days By: Eclipse User on Mon, 08 February 2021 |
14925 |
Mon, 08 February 2021 06:16 By: Eclipse User  |
EXCELRenderOption exported xls file cannot open in MS Excel EXCELRenderOption exported xls file cannot open in MS Excel By: Eclipse User on Mon, 21 December 2015 |
8297 |
Thu, 04 February 2021 01:24 By: Eclipse User  |
How to create an aggregate from an aggregate in a sub-group? Trying to average a list of standard deviations By: Eclipse User on Thu, 04 February 2021 |
12432 |
Thu, 04 February 2021 01:03 By: Eclipse User  |
Unable to add new columns Unable to view reports results by adding new columns internally via PRD due to following errors By: Eclipse User on Wed, 03 February 2021 |
7309 |
Wed, 03 February 2021 07:21 By: Eclipse User  |
Reports Run Multiple Times Every time you run a report it gots the DB 5 times or more. By: Eclipse User on Thu, 15 July 2010 |
10130 |
Thu, 28 January 2021 07:47 By: Eclipse User  |
Birt 4.4 Excel Emitter to single sheet excel export Excel Emitter is creating multiple sheets based on the page break, this is different from how it was in 3.7 emitter By: Eclipse User on Thu, 28 August 2014 |
33758 |
Thu, 28 January 2021 06:19 By: Eclipse User  |
Export BIRT report to xlsx format in single page Tririga BIRT report export to xlsx genearated in multiple pages By: Eclipse User on Wed, 27 January 2021 |
8038 |
Wed, 27 January 2021 07:58 By: Eclipse User  |
Birt Designer on macOS Big Sur By: Eclipse User on Wed, 25 November 2020 |
5131 |
Wed, 27 January 2021 05:16 By: Eclipse User  |
Drop down list in the report By: Eclipse User on Tue, 26 January 2021 |
5549 |
Tue, 26 January 2021 02:12 By: Eclipse User  |
Debug error DB2 SQL Error: SQLCODE=-811, SQLSTATE=21000, SQLERRMC=null, DRIVER=3.69.71 By: Eclipse User on Fri, 22 January 2021 |
5096 |
Fri, 22 January 2021 09:01 By: Eclipse User  |
BIRT Excel export issue with half a million records By: Eclipse User on Mon, 18 January 2021 |
4214 |
Mon, 18 January 2021 05:54 By: Eclipse User  |
[SOLVED] "Java heap space" OutOfMemory error in renderTask BIRT By: Eclipse User on Thu, 21 March 2019 |
23180 |
Mon, 18 January 2021 05:45 By: Eclipse User  |
Nobody has tries to use Birt with Scriptcase Php framework ? By: Eclipse User on Mon, 11 January 2021 |
2669 |
Mon, 11 January 2021 10:48 By: Eclipse User  |
Data Sets -> Generate SQL Views By: Eclipse User on Tue, 29 December 2020 |
2594 |
Fri, 01 January 2021 10:03 By: Eclipse User  |
birt sql add hour birt sql add hour By: Eclipse User on Tue, 22 December 2020 |
1759 |
Thu, 24 December 2020 11:10 By: Eclipse User  |
Data Set Troubles Can't Preview a Data Set with Report Parameters By: Eclipse User on Thu, 17 December 2020 |
2113 |
Tue, 22 December 2020 10:30 By: Eclipse User  |
Restart page number from 1 when work order number changes in BIRT Restart page number from 1 when work order number changes in BIRT By: Eclipse User on Tue, 22 December 2020 |
2474 |
Tue, 22 December 2020 03:12 By: Eclipse User  |
BIRT 431 Crosstab Unable to get 0 displayed in excel By: Eclipse User on Sun, 20 December 2020 |
3463 |
Sun, 20 December 2020 13:20 By: Eclipse User  |
<BR> tags are not resulting in linefeeds in Text element set to Dynamic Text and HTML Text box does not parse HTML tags properly By: Eclipse User on Fri, 11 December 2020 |
2357 |
Mon, 14 December 2020 03:28 By: Eclipse User  |
blank excel When the report format is XLS, always the report is completely empty. By: Eclipse User on Wed, 25 August 2010 |
13248 |
Tue, 08 December 2020 23:30 By: Eclipse User  |
Max File Size pdf Technical Question By: Eclipse User on Sun, 15 April 2018 |
20451 |
Tue, 08 December 2020 04:23 By: Eclipse User  |
Merging Similar Data of multiple rows and showing as one Merging Similar Data of multiple rows and showing as one By: Eclipse User on Tue, 20 November 2018 |
5152 |
Mon, 07 December 2020 09:53 By: Eclipse User  |
How do I display MIN date of a field in BIRT How do I display MIN date of a field By: Eclipse User on Mon, 07 December 2020 |
2068 |
Mon, 07 December 2020 09:46 By: Eclipse User  |
Selecting MIN/MAX date from a Scripted Data source By: Eclipse User on Tue, 07 March 2017 |
9791 |
Sun, 06 December 2020 06:30 By: Eclipse User  |
page break in data cube By: Eclipse User on Thu, 03 December 2020 |
1525 |
Thu, 03 December 2020 09:00 By: Eclipse User  |
Grouping data in a table Grouping data in a table By: Eclipse User on Wed, 02 December 2020 |
2467 |
Wed, 02 December 2020 10:52 By: Eclipse User  |
birt presto jdbc connexion birt presto jdbc connexion By: Eclipse User on Wed, 02 December 2020 |
2801 |
Wed, 02 December 2020 07:51 By: Eclipse User  |
Conditional formatting Conditional formatting By: Eclipse User on Thu, 26 November 2020 |
4830 |
Tue, 01 December 2020 08:39 By: Eclipse User  |
BIRT - Hide extra header cells when using drop detail Hide extra header cells when using drop detail By: Eclipse User on Tue, 10 November 2020 |
2425 |
Thu, 19 November 2020 05:25 By: Eclipse User  |
Cells Function similar By: Eclipse User on Wed, 11 November 2020 |
2614 |
Thu, 19 November 2020 05:07 By: Eclipse User  |
Get the index of the cell in Birt - Any function? A way to get the index of a cell in a table By: Eclipse User on Tue, 13 October 2020 |
5062 |
Thu, 19 November 2020 04:53 By: Eclipse User  |
BIRT: Tables inside cells of another table in excel Tables insider cells of another table - Output in excel not correct By: Eclipse User on Tue, 10 November 2020 |
3374 |
Thu, 19 November 2020 04:19 By: Eclipse User  |
Export rptdocument as JSON By: Eclipse User on Mon, 16 November 2020 |
10629 |
Mon, 16 November 2020 11:41 By: Eclipse User  |
Calculating percentage in data cube By: Eclipse User on Mon, 09 November 2020 |
2222 |
Tue, 10 November 2020 13:17 By: Eclipse User  |
Birt - Insert Dynamic text box with script Birt Scripting By: Eclipse User on Sun, 08 November 2020 |
2784 |
Tue, 10 November 2020 05:41 By: Eclipse User  |
BIRT 2.1.2 and MAXIMO 7.1.4 : org.xml.sax.SAXParseException: Premature end of file. By: Eclipse User on Wed, 16 April 2014 |
66521 |
Fri, 06 November 2020 03:01 By: Eclipse User  |
Expression always returns true By: Eclipse User on Thu, 05 November 2020 |
3468 |
Thu, 05 November 2020 06:21 By: Eclipse User  |
birt 2.1.2 问题 maximo7.1 By: Eclipse User on Thu, 05 November 2020 |
3051 |
Thu, 05 November 2020 06:02 By: Eclipse User  |
Page Numbers within Groups for PDF Restart page numbers for each subgroup By: Eclipse User on Tue, 20 October 2020 |
3520 |
Wed, 04 November 2020 05:32 By: Eclipse User  |
How to clear the value when press delete and set to blank value from the dropdown list How to clear the value when press delete and set to blank value from the dropdown list By: Eclipse User on Tue, 18 August 2020 |
3370 |
Wed, 04 November 2020 04:22 By: Eclipse User  |
Text rotation in Birt Designer Text rotation in Birt Designer By: Eclipse User on Tue, 03 November 2020 |
4069 |
Wed, 04 November 2020 04:18 By: Eclipse User  |
Costing for BIRT Reporting Costing for BIRT Reporting By: Eclipse User on Mon, 10 August 2020 |
3734 |
Thu, 29 October 2020 14:27 By: Eclipse User  |
genReport on Linux using Oracle jdbc - Unable to open a connection with the database connection prof By: Eclipse User on Thu, 01 October 2020 |
2651 |
Wed, 28 October 2020 20:48 By: Eclipse User  |
New Page Output per unique ID/Column By: Eclipse User on Tue, 27 October 2020 |
1640 |
Wed, 28 October 2020 19:04 By: Eclipse User  |
onCreate error onCreate error By: Eclipse User on Wed, 26 August 2020 |
4613 |
Wed, 28 October 2020 15:17 By: Eclipse User  |
Date parameter not working Date=any date Unable to set Date parameter as Date= Oct 1, 2019 By: Eclipse User on Thu, 01 October 2020 |
3215 |
Tue, 20 October 2020 15:28 By: Eclipse User  |
X-Axis Interactivity By: Eclipse User on Fri, 16 October 2020 |
2612 |
Tue, 20 October 2020 15:10 By: Eclipse User  |
