Announcement: XSD has been merged into EMF By: Eclipse User on Thu, 12 January 2023 |
3765 |
Thu, 12 January 2023 14:13 By: Eclipse User  |
try to use xsd By: Eclipse User on Sat, 22 January 2022 |
7146 |
Sun, 23 January 2022 00:33 By: Eclipse User  |
XML Schema Editor black text on dark background By: Eclipse User on Sun, 07 June 2020 |
3100 |
Fri, 29 January 2021 19:51 By: Eclipse User  |
Schema not referenceable in namespace By: Eclipse User on Tue, 27 October 2020 |
4987 |
Wed, 28 October 2020 02:35 By: Eclipse User  |
validation markers now permanent By: Eclipse User on Fri, 28 August 2020 |
1276 |
Fri, 28 August 2020 13:09 By: Eclipse User  |
XSD file - Restriction from imported namespace XSD file - Restriction from imported namespace By: Eclipse User on Mon, 20 April 2020 |
2719 |
Tue, 21 April 2020 01:02 By: Eclipse User  |
XSD with a variable subtree definition Define an XSD to validate an XMLs with a subtree which you cannot predict in advance its structure By: Eclipse User on Mon, 20 January 2020 |
6327 |
Tue, 21 January 2020 01:45 By: Eclipse User  |
XML By: Eclipse User on Mon, 11 November 2019 |
2076 |
Wed, 13 November 2019 03:59 By: Eclipse User  |
The {max occurs} of an element in an 'all' model group must be 0 or 1 Eclispe and XMLSpy don't agree By: Eclipse User on Tue, 17 September 2019 |
6334 |
Fri, 20 September 2019 13:53 By: Eclipse User  |
Creating new xml schema file example ? By: Eclipse User on Tue, 24 September 2002 |
26153 |
Wed, 30 May 2018 12:17 By: Eclipse User  |
set annotation to schema object By: Eclipse User on Tue, 01 October 2002 |
31743 |
XSD assert error on assert By: Eclipse User on Thu, 19 April 2018 |
5051 |
Thu, 19 April 2018 14:45 By: Eclipse User  |
Get cvc-complex-type.3.2.2 error in some, but not all, maven POM files By: Eclipse User on Tue, 22 August 2017 |
8262 |
Tue, 22 August 2017 11:42 By: Eclipse User  |
XSD Error Error during Import XSD By: Eclipse User on Wed, 19 July 2017 |
7897 |
Wed, 19 July 2017 11:07 By: Eclipse User  |
XML Schema question By: Eclipse User on Tue, 20 September 2016 |
3011 |
Wed, 21 September 2016 09:44 By: Eclipse User  |
2694 |
Wed, 31 August 2016 14:44 By: Eclipse Webmaster  |
Cloning annotations By: Eclipse User on Fri, 08 May 2009 |
6444 |
Thu, 30 June 2016 05:31 By: Eclipse User  |
Generate XML instance from XML schema [programmatically] By: Eclipse User on Fri, 26 February 2016 |
6929 |
Sat, 27 February 2016 05:00 By: Eclipse User  |
Problem unmarshalling to Java object javax.xml.bind.UnmarshalException: unexpected element. Expected elements are (none) By: Eclipse User on Tue, 17 March 2015 |
10421 |
Tue, 17 March 2015 11:32 By: Eclipse User  |
Xsd to Ecore Mapping: attributes with simple types By: Eclipse User on Thu, 19 February 2015 |
3682 |
Wed, 25 February 2015 09:59 By: Eclipse User  |
Problem with an XML schema Error message By: Eclipse User on Thu, 12 February 2015 |
4041 |
Thu, 12 February 2015 16:50 By: Eclipse User  |
XSD Validation Error By: Eclipse User on Fri, 06 February 2015 |
8842 |
Tue, 10 February 2015 16:37 By: Eclipse User  |
Help needed Creating XSD for source XML By: Eclipse User on Wed, 14 January 2015 |
4318 |
Wed, 14 January 2015 10:53 By: Eclipse User  |
how to validate dataTime with xsd By: Eclipse User on Tue, 04 November 2014 |
3764 |
Tue, 04 November 2014 08:09 By: Eclipse User  |
A diagram of XMI See a XMI By: Eclipse User on Mon, 15 September 2014 |
4287 |
Tue, 16 September 2014 01:23 By: Eclipse User  |
Empty Closed Element Eclipse - XML Editor - How to get Empty Closed Element By: Eclipse User on Wed, 23 April 2014 |
4180 |
Wed, 23 April 2014 09:48 By: Eclipse User  |
XSD Help The type attribute cannot be present with either simpleType or complexType. By: Eclipse User on Fri, 11 April 2014 |
3730 |
Sat, 12 April 2014 10:59 By: Eclipse User  |
XSD Schema Editor Question XSD Schema Editor Question By: Eclipse User on Wed, 19 March 2014 |
4538 |
Fri, 21 March 2014 11:46 By: Eclipse User  |
How do we make integer datatype behave like String data type in XML/XSD? XML Type Redefinition By: Eclipse User on Thu, 09 January 2014 |
6963 |
Fri, 10 January 2014 12:53 By: Eclipse User  |
Eclipse Validator Shows False errors Eclipse Validator Showing False errors By: Eclipse User on Tue, 17 December 2013 |
28127 |
Thu, 19 December 2013 12:43 By: Eclipse User  |
Validate XML file using XSD Schema and parsing in DOM parser Validating XML file using xsd schema By: Eclipse User on Mon, 05 August 2013 |
4556 |
Mon, 05 August 2013 10:01 By: Eclipse User  |
XSD publicId and schemaLocation key are different. By: Eclipse User on Wed, 17 July 2013 |
5334 |
Wed, 17 July 2013 03:17 By: Eclipse User  |
Stack overflow on XSD Resource save By: Eclipse User on Sun, 30 June 2013 |
5371 |
Mon, 15 July 2013 13:49 By: Eclipse User  |
src-resolve.4.2 error resolving component it was detected that is in namespace I get this error when I validate my xsd in ecclipse By: Eclipse User on Thu, 27 June 2013 |
13033 |
Thu, 27 June 2013 11:34 By: Eclipse User  |
Extending xsd.edit Extending xsd.edit By: Eclipse User on Fri, 21 June 2013 |
7558 |
Tue, 25 June 2013 05:20 By: Eclipse User  |
Problems with complexType Problems with complexType By: Eclipse User on Mon, 10 June 2013 |
6816 |
Tue, 11 June 2013 09:08 By: Eclipse User  |
Eclipse wsdl validator doesn't show exact error By: Eclipse User on Sat, 18 May 2013 |
6373 |
Sat, 18 May 2013 02:46 By: Eclipse User  |
Calling XSD with different namespaces Calling XSD with different namespaces By: Eclipse User on Thu, 07 February 2013 |
10123 |
Fri, 03 May 2013 07:12 By: Eclipse User  |
How to find XML structures directly from the XSD Straight forward way to search for XML structures By: Eclipse User on Mon, 04 February 2013 |
4562 |
Mon, 04 February 2013 10:01 By: Eclipse User  |
choice child under all By: Eclipse User on Wed, 09 January 2013 |
5988 |
Thu, 10 January 2013 01:48 By: Eclipse User  |
The 'no duplicates' constraint is violated By: Eclipse User on Wed, 17 December 2003 |
18798 |
Thu, 03 January 2013 05:40 By: Eclipse User  |
Digram Editor loses focus on closing of MessageDialog in Graphiti By: Eclipse User on Fri, 28 December 2012 |
4663 |
Fri, 28 December 2012 03:29 By: Eclipse User  |
XSD url not being cached A certain schema url refuses to enter cache, causes serious validation lag By: Eclipse User on Wed, 21 November 2012 |
9946 |
Wed, 21 November 2012 16:59 By: Eclipse User  |
Question on Type reference is unresolved in XSD By: Eclipse User on Tue, 13 November 2012 |
6913 |
Wed, 14 November 2012 00:37 By: Eclipse User  |
create XML document based on XSDElementDeclaration By: Eclipse User on Sun, 04 November 2012 |
5030 |
Sun, 04 November 2012 08:39 By: Eclipse User  |
Declare a default attribute By: Eclipse User on Mon, 17 September 2012 |
6145 |
Mon, 17 September 2012 01:13 By: Eclipse User  |
Schema default value not honored for complex type By: Eclipse User on Sat, 01 September 2012 |
6099 |
Sat, 01 September 2012 17:31 By: Eclipse User  |
one XML element value as other xml element value XML element value By: Eclipse User on Fri, 31 August 2012 |
5856 |
Fri, 31 August 2012 07:00 By: Eclipse User  |
How to generate XSD from XML, by restricting all the values ? How can i create XSD from XML, by restricting all the values in XSD to the ones in the XML? By: Eclipse User on Wed, 22 August 2012 |
20487 |
Fri, 24 August 2012 02:03 By: Eclipse User  |
Maven properties and XML in Eclipse Making valid XML files when using Maven By: Eclipse User on Wed, 22 August 2012 |
4736 |
Wed, 22 August 2012 10:29 By: Eclipse User  |
Adding XSD to Catalog which includes and imports XSD By: Eclipse User on Tue, 14 August 2012 |
12179 |
Wed, 15 August 2012 07:38 By: Eclipse User  |
org.eclipse.xsd.XSDSchema By: Eclipse User on Sun, 15 July 2012 |
17039 |
Wed, 01 August 2012 14:41 By: Eclipse User  |
schema error xs:complexType positioning problem By: Eclipse User on Wed, 11 July 2012 |
5843 |
Wed, 11 July 2012 06:48 By: Eclipse User  |
Defining type for specific Occrrance of the element. By: Eclipse User on Tue, 05 June 2012 |
6550 |
Wed, 06 June 2012 06:11 By: Eclipse User  |
Inline embedded Schema Inline embedded Schema By: Eclipse User on Mon, 04 June 2012 |
8011 |
Tue, 05 June 2012 10:53 By: Eclipse User  |
Include several XSD files By: Eclipse User on Mon, 19 March 2012 |
6914 |
Mon, 02 April 2012 12:33 By: Eclipse User  |
Problem with xsd and xml validation using JAXB InvalidRegex:Pattern value '([a-zA-Z0-9\_\.\*\%\-]){1,28}' is not a valid regular expression. The reported error was: 'This expression is not supported in the current option setting.' By: Eclipse User on Tue, 28 February 2012 |
9421 |
Tue, 28 February 2012 11:04 By: Eclipse User  |
xpath error By: Eclipse User on Thu, 05 January 2012 |
7635 |
Fri, 06 January 2012 09:15 By: Eclipse User  |
Being introduced to XSDs I am struggling at the first hurdle! By: Eclipse User on Mon, 19 December 2011 |
34290 |
Mon, 19 December 2011 11:57 By: Eclipse User  |
Serialize XSD Object Serialize XSD Object having <xs:include> tags By: Eclipse User on Tue, 13 December 2011 |
7330 |
Tue, 13 December 2011 06:50 By: Eclipse User  |
Resolving schema import "http://www.w3.org/2000/09/xmldsig" By: Eclipse User on Mon, 31 October 2011 |
9782 |
Wed, 02 November 2011 12:59 By: Eclipse User  |
XML Validation against DTD Validate an XML file against a dtd file where dtd extension has to be case insensitive By: Eclipse User on Wed, 19 October 2011 |
7945 |
Wed, 19 October 2011 10:08 By: Eclipse User  |
Exclude files/folders from validation programmatically By: Eclipse User on Fri, 23 September 2011 |
5971 |
Fri, 23 September 2011 18:45 By: Eclipse User  |
some kind of restriction restricing a group of elements By: Eclipse User on Mon, 12 September 2011 |
6051 |
Mon, 12 September 2011 10:52 By: Eclipse User  |
NewXMLGenerator.createCMDocument() returns null By: Eclipse User on Wed, 07 September 2011 |
7626 |
Thu, 08 September 2011 12:21 By: Eclipse User  |
CVC-complex-type.5.2 error message that nobody seems to be able to understand... I'm getting an error in Eclipse Indigo when trying to import a WSDL file: cvc-complex-type.5.2: In element 'wsp:Policy', attribute 'Id' is a Wild ID. But there is already an attribute 'Id' derived fro By: Eclipse User on Wed, 31 August 2011 |
32683 |
Sun, 04 September 2011 12:09 By: Eclipse User  |
reading inside a xml reading in xml from xsd By: Eclipse User on Fri, 12 August 2011 |
13079 |
Tue, 16 August 2011 04:23 By: Eclipse User  |
Simple type restriction just in need of a small hint By: Eclipse User on Thu, 11 August 2011 |
25911 |
Tue, 16 August 2011 02:14 By: Eclipse User  |
Simple type restriction being a complete noob i feel i am close but need just a small hint By: Eclipse User on Thu, 11 August 2011 |
12283 |
Thu, 11 August 2011 08:47 By: Eclipse User  |
XML editor Finding the right plugin By: Eclipse User on Wed, 03 August 2011 |
6500 |
Wed, 03 August 2011 05:12 By: Eclipse User  |
creating XPATH 2.0 expressions while navigating schema By: Eclipse User on Wed, 16 July 2003 |
8584 |
Tue, 02 August 2011 11:18 By: Eclipse User  |
mistake By: Eclipse User on Wed, 08 June 2011 |
4807 |
Wed, 08 June 2011 11:49 By: Eclipse User  |
xsd:string vs. xsd:NMTOKENS what are the differences By: Eclipse User on Tue, 31 May 2011 |
5693 |
Tue, 31 May 2011 21:11 By: Eclipse User  |
xml autocomplete from schema By: Eclipse User on Wed, 25 May 2011 |
8873 |
Wed, 25 May 2011 22:18 By: Eclipse User  |
specifying .xsd namespace inside XML file proper way of specifying location of .xsd namespace inside eclipse plugin By: Eclipse User on Tue, 26 April 2011 |
10132 |
Thu, 28 April 2011 05:50 By: Eclipse User  |
view xml file with internal web browser By: Eclipse User on Wed, 13 April 2011 |
6681 |
Wed, 13 April 2011 20:42 By: Eclipse User  |
Can we use list of user data structure as an element By: Eclipse User on Fri, 08 April 2011 |
5230 |
Sat, 09 April 2011 13:05 By: Eclipse User  |
Is it possible to manually specify schema to use for XML for wst xml editor? By: Eclipse User on Tue, 15 March 2011 |
5570 |
Tue, 15 March 2011 15:16 By: Eclipse User  |
XSD Graphic editor What plugin is this available in? By: Eclipse User on Thu, 10 March 2011 |
6939 |
Thu, 10 March 2011 09:20 By: Eclipse User  |
Auto Completion Classes for XSD By: Eclipse User on Sat, 19 February 2011 |
6415 |
Mon, 21 February 2011 22:21 By: Eclipse User  |
NPE when running XSD Sample XSDGenerateHTML By: Eclipse User on Tue, 15 February 2011 |
6634 |
Wed, 16 February 2011 08:39 By: Eclipse User  |
XSD comparer By: Eclipse User on Wed, 27 October 2010 |
8777 |
Thu, 28 October 2010 17:40 By: Eclipse User  |
Ant Problem - failed to create task or type project By: Eclipse User on Sun, 24 October 2010 |
8087 |
Sun, 24 October 2010 13:10 By: Eclipse User  |
Cross-referencing namespaces & schemas By: Eclipse User on Sat, 23 October 2010 |
9179 |
Sat, 23 October 2010 20:09 By: Eclipse User  |
Querying parents of element declarations By: Eclipse User on Mon, 04 October 2010 |
6566 |
Tue, 05 October 2010 10:46 By: Eclipse User  |
XML parsers By: Eclipse User on Tue, 20 July 2010 |
10647 |
Wed, 21 July 2010 06:10 By: Eclipse User  |
13860 |
Tue, 20 July 2010 05:29 By: Eclipse User  |
QName validation QName attributes are not validated By: Eclipse User on Wed, 07 July 2010 |
7777 |
Wed, 07 July 2010 11:08 By: Eclipse User  |
QName validation By: Eclipse User on Wed, 07 July 2010 |
5314 |
Wed, 07 July 2010 08:53 By: Eclipse User  |
Missing element in XML editor autocompletion substitutionGroup element defined in 2nd xsd aren't proposed in autocompleted By: Eclipse User on Thu, 06 May 2010 |
13011 |
Thu, 06 May 2010 10:48 By: Eclipse User  |
Missing element in XML editor autocompletion By: Eclipse User on Thu, 06 May 2010 |
5969 |
Thu, 06 May 2010 05:23 By: Eclipse User  |
Incorrect validation (Possibly) incorrect validation of imported schema By: Eclipse User on Wed, 28 April 2010 |
7433 |
Wed, 28 April 2010 09:52 By: Eclipse User  |
Incorrect validation By: Eclipse User on Wed, 28 April 2010 |
5463 |
Wed, 28 April 2010 08:55 By: Eclipse User  |
Can I use .xsd2ecore to specify class names to generate By: Eclipse User on Fri, 23 April 2010 |
5727 |
Fri, 23 April 2010 13:01 By: Eclipse User  |
5695 |
C++ XML Parser By: Eclipse User on Wed, 21 April 2010 |
5403 |
Wed, 21 April 2010 09:01 By: Eclipse User  |
C++ XML Parser Using a C++ XML Parser in my program By: Eclipse User on Wed, 21 April 2010 |
5280 |
12252 |
Wed, 21 April 2010 07:13 By: Eclipse User  |
13345 |
i miss the old schema viewer who's idea was it to change it?? By: Eclipse User on Thu, 08 April 2010 |
7305 |
Thu, 08 April 2010 11:04 By: Eclipse User  |
i miss the old schema viewer By: Eclipse User on Thu, 08 April 2010 |
4690 |
Thu, 08 April 2010 06:35 By: Eclipse User  |
[Announce] MoDELS 2010 Call for Papers By: Eclipse User on Tue, 06 April 2010 |
13209 |
Tue, 06 April 2010 13:18 By: Eclipse User  |
13828 |
Tue, 06 April 2010 08:36 By: Eclipse User  |
XMPP Building an Instant Messaging Application Using Jabber/XMPP By: Eclipse User on Mon, 29 March 2010 |
6058 |
Mon, 29 March 2010 17:07 By: Eclipse User  |
4229 |
Mon, 29 March 2010 14:01 By: Eclipse User  |
how to add enumerations, one per line in schema editor By: Eclipse User on Mon, 22 March 2010 |
8076 |
Sat, 27 March 2010 03:07 By: Eclipse User  |
12191 |
Mon, 22 March 2010 12:10 By: Eclipse User  |
Event Publish XSD By: Eclipse User on Fri, 12 March 2010 |
5691 |
Fri, 12 March 2010 08:35 By: Eclipse User  |
11999 |
Fri, 12 March 2010 01:36 By: Eclipse User  |
XSD->Ecore->XSD and anonymous types By: Eclipse User on Wed, 10 March 2010 |
5054 |
Wed, 10 March 2010 11:42 By: Eclipse User  |
8078 |
Handling of duplicate type definition from included XSD What happens when the XSD pulled in using xsd:include has a duplicate type definition By: Eclipse User on Mon, 01 March 2010 |
17123 |
Tue, 02 March 2010 09:54 By: Eclipse User  |
Handling of duplicate type definition from included XSD By: Eclipse User on Mon, 01 March 2010 |
4497 |
Mon, 01 March 2010 16:02 By: Eclipse User  |
Trace in Medini QVT By: Eclipse User on Fri, 26 February 2010 |
10502 |
Fri, 26 February 2010 14:36 By: Eclipse User  |
Re: Trace in Medini QVT By: Eclipse User on Fri, 26 February 2010 |
4998 |
Fri, 26 February 2010 13:49 By: Eclipse User  |
12218 |
Fri, 26 February 2010 12:22 By: Eclipse User  |
xmi Models By: Eclipse User on Mon, 22 February 2010 |
8092 |
Fri, 26 February 2010 10:26 By: Eclipse User  |
4206 |
Mon, 22 February 2010 09:54 By: Eclipse User  |
[Announce] Eclipse/OMG Symposium 2010 By: Eclipse User on Mon, 09 November 2009 |
8621 |
Wed, 10 February 2010 13:17 By: Eclipse User  |
How to indent/reformat XML/XSD tags according to their hierarchy level? By: Eclipse User on Fri, 22 January 2010 |
8829 |
Fri, 22 January 2010 09:41 By: Eclipse User  |
4556 |
Fri, 22 January 2010 08:43 By: Eclipse User  |
How to create sample XML doc from XSD schema? By: Eclipse User on Fri, 22 January 2010 |
5610 |
Fri, 22 January 2010 08:41 By: Eclipse User  |
5265 |
Create XSD programmatically By: Eclipse User on Thu, 21 January 2010 |
6687 |
Thu, 21 January 2010 06:52 By: Eclipse User  |
6323 |
XML generation from XSD puts "token" in attributes By: Eclipse User on Wed, 18 November 2009 |
12950 |
Fri, 11 December 2009 11:03 By: Eclipse User  |
Does XML Schema editor work with CCRC? XML Schema editor By: Eclipse User on Wed, 09 December 2009 |
8629 |
Wed, 09 December 2009 14:07 By: Eclipse User  |
Does XML Schema editor work with CCRC? By: Eclipse User on Wed, 09 December 2009 |
5712 |
Wed, 09 December 2009 11:26 By: Eclipse User  |
4030 |
Wed, 18 November 2009 14:53 By: Eclipse User  |
11773 |
Mon, 09 November 2009 13:35 By: Eclipse User  |
Create new DOM document from XSD schema By: Eclipse User on Tue, 04 March 2008 |
14399 |
Fri, 23 October 2009 08:49 By: Eclipse User  |
Resolving XSD includes By: Eclipse User on Fri, 09 October 2009 |
5988 |
Fri, 09 October 2009 14:15 By: Eclipse User  |
3803 |
Fri, 09 October 2009 13:16 By: Eclipse User  |
Displaying selected content from XSD file By: Eclipse User on Wed, 30 September 2009 |
8642 |
Fri, 02 October 2009 05:07 By: Eclipse User  |
11431 |
Wed, 30 September 2009 16:55 By: Eclipse User  |
Unable to load mixed content when loading an ecore model derived from an xml schema By: Eclipse User on Tue, 22 September 2009 |
7666 |
Tue, 22 September 2009 14:30 By: Eclipse User  |
12333 |
Tue, 22 September 2009 13:44 By: Eclipse User  |
key/keyref does not validate with recursion? By: Eclipse User on Thu, 10 September 2009 |
13657 |
Fri, 11 September 2009 10:15 By: Eclipse User  |
12734 |
Thu, 10 September 2009 11:22 By: Eclipse User  |
Parse XSD from the WTP plugins. By: Eclipse User on Tue, 18 August 2009 |
26 |
22694 |
Thu, 10 September 2009 02:15 By: Eclipse User  |
12135 |
Tue, 18 August 2009 08:34 By: Eclipse User  |
Relax NG? By: Eclipse User on Thu, 06 August 2009 |
15574 |
Mon, 10 August 2009 13:31 By: Eclipse User  |
12036 |
Thu, 06 August 2009 13:37 By: Eclipse User  |
XSDSimpleTypeDefinition::facetContents not sortable? By: Eclipse User on Wed, 22 July 2009 |
6999 |
Thu, 23 July 2009 12:20 By: Eclipse User  |
How to access the ID of a XSDComponent By: Eclipse User on Thu, 02 April 2009 |
7262 |
Wed, 22 July 2009 07:56 By: Eclipse User  |
11792 |
Wed, 22 July 2009 07:55 By: Eclipse User  |
How to copy XSDSchema object By: Eclipse User on Wed, 01 July 2009 |
7398 |
Thu, 02 July 2009 08:59 By: Eclipse User  |
11940 |
Wed, 01 July 2009 16:06 By: Eclipse User  |
WSDL Validator issue By: Eclipse User on Mon, 29 June 2009 |
9755 |
Tue, 30 June 2009 11:24 By: Eclipse User  |
11713 |
Mon, 29 June 2009 08:23 By: Eclipse User  |
UML to XSD By: Eclipse User on Fri, 26 June 2009 |
12774 |
Fri, 26 June 2009 08:31 By: Eclipse User  |
14295 |
Defining mulitple persistency for EMF Model from one xsd By: Eclipse User on Fri, 19 June 2009 |
6154 |
Fri, 19 June 2009 03:23 By: Eclipse User  |
11860 |
Fri, 19 June 2009 00:13 By: Eclipse User  |
Problem with EMF generation from 2 XSDs By: Eclipse User on Mon, 08 June 2009 |
7926 |
Tue, 09 June 2009 05:29 By: Eclipse User  |
12193 |
Mon, 08 June 2009 13:07 By: Eclipse User  |
Question Regarding Schemas in WSDL By: Eclipse User on Wed, 25 February 2009 |
8638 |
Wed, 03 June 2009 08:47 By: Eclipse User  |
Is xsd validator cannot validate an xpath with character [ or ] ? By: Eclipse User on Thu, 28 May 2009 |
7837 |
Thu, 28 May 2009 13:08 By: Eclipse User  |
11982 |
Thu, 28 May 2009 12:02 By: Eclipse User  |
escaping chars in XSD By: Eclipse User on Thu, 28 May 2009 |
6609 |
Thu, 28 May 2009 09:42 By: Eclipse User  |
11677 |
Thu, 28 May 2009 07:36 By: Eclipse User  |
Problem during replacing element from one schema to another schema using DOM By: Eclipse User on Fri, 15 May 2009 |
8685 |
Sat, 16 May 2009 09:59 By: Eclipse User  |
12116 |
Fri, 15 May 2009 00:29 By: Eclipse User  |
11829 |
Fri, 08 May 2009 01:50 By: Eclipse User  |
How to clone annotations By: Eclipse User on Tue, 23 December 2008 |
66 |
44057 |
Thu, 16 April 2009 10:55 By: Eclipse User  |
EMF/XSD Activities Example By: Eclipse User on Tue, 07 April 2009 |
11802 |
Tue, 07 April 2009 11:58 By: Eclipse User  |
14332 |
11737 |
Thu, 02 April 2009 12:04 By: Eclipse User  |
No targetnamespace set for local elements inside complextype By: Eclipse User on Thu, 19 March 2009 |
8609 |
Thu, 19 March 2009 08:17 By: Eclipse User  |
12096 |
Thu, 19 March 2009 07:33 By: Eclipse User  |
11996 |
Wed, 25 February 2009 00:57 By: Eclipse User  |
Foregrownd color issue at "=" sign By: Eclipse User on Sun, 15 February 2009 |
12589 |
Thu, 19 February 2009 12:35 By: Eclipse User  |
copy xsd type definition from one schema to another By: Eclipse User on Wed, 18 February 2009 |
6164 |
Thu, 19 February 2009 04:16 By: Eclipse User  |
11797 |
Wed, 18 February 2009 12:08 By: Eclipse User  |
11738 |
Sun, 15 February 2009 09:15 By: Eclipse User  |
Generate XML File option missing By: Eclipse User on Fri, 30 January 2009 |
11185 |
Sat, 31 January 2009 13:40 By: Eclipse User  |
12107 |
Fri, 30 January 2009 23:28 By: Eclipse User  |
XMI to XSD? By: Eclipse User on Mon, 26 January 2009 |
9663 |
Mon, 26 January 2009 07:01 By: Eclipse User  |
10872 |
Mon, 26 January 2009 04:06 By: Eclipse User  |
XSDRedefinableComponent By: Eclipse User on Fri, 09 January 2009 |
5774 |
Fri, 09 January 2009 09:16 By: Eclipse User  |
10753 |
Fri, 09 January 2009 04:22 By: Eclipse User  |
XSDSimpleTypeDef validation By: Eclipse User on Thu, 08 January 2009 |
6101 |
Thu, 08 January 2009 18:31 By: Eclipse User  |
10660 |
Thu, 08 January 2009 17:41 By: Eclipse User  |
EMF model from XML Schema fails if duration has default value By: Eclipse User on Sat, 27 December 2008 |
11712 |
Tue, 30 December 2008 12:05 By: Eclipse User  |
10659 |
Sat, 27 December 2008 15:23 By: Eclipse User  |
Only relative path is accepted by XSD Validator By: Eclipse User on Wed, 24 December 2008 |
6933 |
Wed, 24 December 2008 04:40 By: Eclipse User  |
10885 |
Wed, 24 December 2008 01:29 By: Eclipse User  |
How to use xsd2ecore By: Eclipse User on Tue, 23 December 2008 |
6212 |
Tue, 23 December 2008 17:55 By: Eclipse User  |
10602 |
Tue, 23 December 2008 17:20 By: Eclipse User  |
4183 |
Tue, 23 December 2008 07:36 By: Eclipse User  |
SOAP schema not considered by XSD Validator by default By: Eclipse User on Wed, 03 December 2008 |
6463 |
Wed, 03 December 2008 10:38 By: Eclipse User  |
3800 |
Wed, 03 December 2008 10:02 By: Eclipse User  |
xsd to xmi By: Eclipse User on Thu, 20 November 2008 |
5991 |
Fri, 21 November 2008 00:31 By: Eclipse User  |
3627 |
Thu, 20 November 2008 23:58 By: Eclipse User  |
Dealing with a set of large XML schemas By: Eclipse User on Tue, 11 November 2008 |
12638 |
Tue, 18 November 2008 16:20 By: Eclipse User  |
Generated EObjectValidator class By: Eclipse User on Thu, 13 November 2008 |
9032 |
Thu, 13 November 2008 16:55 By: Eclipse User  |
TODO: The default literal value "EnumMemberA" is invalid By: Eclipse User on Thu, 13 November 2008 |
6627 |
Thu, 13 November 2008 12:59 By: Eclipse User  |
3740 |
Thu, 13 November 2008 11:57 By: Eclipse User  |
3830 |
Thu, 13 November 2008 11:52 By: Eclipse User  |
XML schema "fixed" attribute and static final fields By: Eclipse User on Tue, 11 November 2008 |
6801 |
Tue, 11 November 2008 15:23 By: Eclipse User  |
