Home » Eclipse Projects » Equinox » p2 update mechanism broken after migrating to Helios
p2 update mechanism broken after migrating to Helios [message #544484] Fri, 02 July 2010 15:50 Go to previous message
After migrating from Eclipse 3.5 to 3.6 the p2-enabled update in our RCP application no longer works.
On start-up there is a warning that "the update checker service is not initialized".
Help > Check for Updates fails with this message:
Could not locate the running profile instance. The eclipse.p2.data.area and eclipse.p2.profile properties may not be set correctly in this application's config.ini file.
Even Help > About > Installation Details fails with:
at org.eclipse.equinox.internal.p2.ui.ProvUIActivator.addProvisioningListener(ProvUIActivator.java:106)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup.createViewer(InstalledIUGroup.java:75)
at org.eclipse.equinox.internal.p2.ui.dialogs.StructuredIUGroup.createGroupComposite(StructuredIUGroup.java:80)
at org.eclipse.equinox.internal.p2.ui.dialogs.InstalledIUGroup.<init>(InstalledIUGroup.java:51)
at org.eclipse.equinox.p2.ui.InstalledSoftwarePage.createControl(InstalledSoftwarePage.java:95)
at org.eclipse.ui.internal.about.InstallationDialog.tabSelected(InstallationDialog.java:274)
at org.eclipse.ui.internal.about.InstallationDialog.createContents(InstallationDialog.java:245)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.ui.internal.dialogs.AboutDialog$1.run(AboutDialog.java:126)
at org.eclipse.ui.internal.dialogs.AboutDialog.buttonPressed(AboutDialog.java:121)
at ...
and:
at org.eclipse.equinox.internal.p2.ui.model.ProfileElement.getQueryable(ProfileElement.java:55)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:54)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:102)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Any ideas? (Cross-posted from the RCP group, where p2 knowledge appears to be more scarce...)
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:SWT and Equinox product export problems
Next Topic:"dropins" folder in RCP application
Current Time: Sun Jul 20 03:04:58 EDT 2025
Powered by FUDForum. Page generated in 0.07671 seconds
