Home » Modeling » Epsilon » [HUTN] Problem Linux with property "upper" of the UML.ecore
[HUTN] Problem Linux with property "upper" of the UML.ecore [message #501872] |
Fri, 04 December 2009 08:57 |
Raul Messages: 14 Registered: November 2009 |
Junior Member |
Hi, I am working with epsilon_0.8.8 in linux and I am using eclipse Ganymede 3.4.0.
I have problem with property "upper" of the model "UML.ecore".
I test the same file in Windows XP and I have not any problem.
Thanks!
This file HUTN shows this error: Reason: Expected UnlimitedNatural for: upper.
@Spec {
metamodel "UML" {
nsUri: "http://www.eclipse.org/uml2/2.1.0/UML"
uml {
Model "Model1"{
nestedPackage: Package "Package1"
Package "Package1"{
packagedElement: Class "Class1" {name : "Class1"},
Class "Class2" {name : "Class2"},
Association "Association1" {
ownedEnd: Property "src1" {
type : Class "Class1"
upper : -1
lower : 1
Property "dst1"{
type : Class "Class2"
upper : -1 // FAILS HERE
lower : 1
memberEnd: Property "src2", Property "dst2"
Property "scr2",
Property "dst2"
Property "src2"{
upper : -1
lower : 1
Property "dst2"{
upper : 1
lower : 1
[Updated on: Fri, 04 December 2009 09:03] Report message to a moderator
Current Time: Thu Apr 25 12:50:51 GMT 2024
Powered by FUDForum. Page generated in 0.02850 seconds
