| How to set "priority" for my work item with OSLC? [message #1060286] |
Thu, 23 May 2013 17:28  |
Hi all.
I'm new with OSLC. I started from using the package org.eclipse.lyo.client.oslc.samples (RTCFormSample.java in particular) provided with the Lyo prject and I have developed a class by myself that relies on the OSLC4J client libraries to create and query work items (changerequests) on my Rational Team Concert) server.
I need now to make a pass further.
One of the attributes I need to set when I create a WI is the Priority, that can assume a predefined set of values (in a drop down menu).
When I display the RDF of a Work Item:
GET https:/X.XX.XXX.XX:9443/ccm/oslc/contexts/_ryl8MLbfEeK8JbTtKcHtwA/workitem/330
Response:
<rdf:rdf>
<oslc_cmx:priority rdf:resource="<A href='https:/x.xx.xx.xx:9443/ccm/oslc/enumerations/_ryl8MLbfEeK8JbTtKcHtwA/priority/priority.literal.l02" '="">https:/x.xx.xx.xx:9443/ccm/oslc/enumerations/_ryl8MLbfEeK8JbTtKcHtwA/priority/priority.literal.l02"/>
</rdf:rdf>
as you can see, Priority is a "oslc_cmx" type of attribute and its value is an enumeration (href='https:/x.xx.xx.xx:9443/ccm/oslc/enumerations/_ryl8MLbfEeK8JbTtKcHtwA/priority/priority.literal.l02)
So I did a GET from my REST Client on browser
(GET https:/X.XX.XXX.XX:9443/ccm/oslc/enumerations/_ryl8MLbfEeK8JbTtKcHtwA/priority)
and I get a response with all the "enumeration" available: this is an extract of the response, as for example:
<rdf:Description rdf:about="https:/X.XX.XXX.XX:9443/ccm/oslc/enumerations/_ryl8MLbfEeK8JbTtKcHtwA/priority/priority.literal.l11">
<rdf:type rdf:resource="http:/jazz.net/xmlns/prod/jazz/rtc/cm/1.0/Literal"/>
<rtc_cm:iconUrl rdf:resource="https:/X.XX.XXX.XX:9443/ccm/service/com.ibm.team.workitem.common.internal.model.IImageContentService/processattachment/_ryl8MLbfEeK8JbTtKcHtwA/enumeration/high.gif"/>
<dcterms:title rdf:datatype="http:/www.w3.org/2001/XMLSchema#string">High</dcterms:title>
<dcterms:identifier rdf:datatype="http:/www.w3.org/2001/XMLSchema#string">priority.literal.l11</dcterms:identifier>
</rdf:Description>
From this response, I know that to set my WI Priority to "High" I need to write a code like this:
//create a ChangeRequest object
ChangeRequest wi = new ChangeRequest();
//create QNAME
QName OSLC_PRIORITY = new QName("http:/jazz.net/xmlns/prod/jazz/rtc/ext/1.0/", "http:/jazz.net/xmlns/prod/jazz/rtc/cm/1.0/Literal", "oslc_cmx");
private Map<QName, Object> properties = new HashMap<QName, Object>();
properties.put(OSLC_PRIORITY, "https:/X.XX.XXX.XX:9443/ccm/oslc/enumerations /_ryl8MLbfEeK8JbTtKcHtwA/priority/priority.literal.l11");
//set extended properties for the changerequest
wi.setExtendedProperties(properties)
//then create the WI
This code works in some way, but of course, it is not fine.. I cannot use "hardcoded" values as I used in my sample.
What I need is to retrieve at runtime what are the valid pairs (value,URI) the attribute "priority" can assume. How should I do using the OSLC4J libraries? Is there any method I can use to simulate the execution of the GET I run on my browser, and to parse the response I should get back?
Hope I've not been too much confuse....
thanks in advance
piero m.
| Re: How to set "priority" for my work item with OSLC? [message #1060467 is a reply to message #1060456] |
Fri, 24 May 2013 17:02  |
Thank you Mike
"Hi, There's currently no Java resource in OSLC4J to represent that RTC-specific Literal resource. You could either
- create one that matches the predicates in Literal and have OSLC4J de-serialize to Java for you
- Use the OSLC client to do a get and don't de-serialize to java - just process the raw xml yourself (or with an RDF lib like Jena)"
I would learn both ways, starting from the latter.
Could you point me to some samples for both solutions?
Thanks in advance and for your patience
Piero M.
FUDForum. Page generated in 0.04638 seconds
