Home » Language IDEs » Java Development Tools (JDT) » Find the IType for a class
Find the IType for a class [message #246497] Fri, 03 August 2007 00:20 Go to next message
Originally posted by: rupinder10.gmail.com
I am trying to write a plugin that needs its launcher to extend the
JUnitLaunchConfiguration. Unfortunately, the JUnitLaunchConfiguration uses
project.findType(className)
to the IType of the test class to be launched. In my case the test class
I want to launch is not a part of the project but is in the plugin jar.
Is there a way for me to get to the IType if the class file is in the
plugin and not the java project ?
Re: Find the IType for a class [message #246501 is a reply to message #246497] Fri, 03 August 2007 04:15 Go to previous messageGo to next message
The IJavaProject.findType(String) method should find any type which is on
the project classpath. So, if your jar is on your project classpath (it should
be the case, I guess), then you could use this method to find any type in it.
If you cannot find a type in your jar although it is on your classpath, then
first verify that the given name is well qualified or that it is not a secondary
type (see javadoc comment of the method). If the given parameter is correct
then open a bug against JDT/Core component with a detailed description of your
project configuration, the jar file containing the type you're trying to find
using this method, thanks
Re: Find the IType for a class [message #246521 is a reply to message #246501] Fri, 03 August 2007 18:23 Go to previous messageGo to next message
You are correct about the fact that project.findType does find the
classes in the project. But in my case, the class file is not on the
project's classpath but is in the plugins classpath.
The project just has an XML file. What I am trying to do is that when
the use right click's the file to run it (yes run an XML file) the
plugin should use the XML file to create test cases and run them. The
actual test class is on the plugin's classpath and I dont want the users
to have to unnecessarily include jar files in their project because they
are not writing java code.
> should
> in it.
> then
> secondary
> of your
> find
>> uses
>> class I want to launch is not a part of the project but is in the
>> plugin jar. Is there a way for me to get to the IType if the class
>> file is in the plugin and not the java project ?
Re: Find the IType for a class [message #246526 is a reply to message #246521] Sat, 04 August 2007 05:13 Go to previous messageGo to next message
If the class file is on the plugins classpath, then PDE should have put the
corresponding jar file on your project classpath through the PDE Container
and so, you should see this jar under the 'Plug-in Dependencies' folder in
the Package Explorer... Can you see it there?
If you do not see it, then I assume that the nature of your project is not
correct. What kind of nature did you intend to apply to your project:
Java, Plug-in, other?
>> (it should
>> in it.
>> classpath, then
>> secondary
>> correct
>> of your
>> to find
>>> uses
Re: Find the IType for a class [message #246745 is a reply to message #246526] Sat, 11 August 2007 22:51 Go to previous messageGo to next message
I do not see it on the Plug-in Dependencies folder. But I guess that is
because I am planning to use the Java nature.
>> users to have to unnecessarily include jar files in their project
>> because they are not writing java code.
>>> is on
>>> (it should
>>> type in it.
>>> classpath, then
>>> a secondary
>>> correct
>>> description of your
>>> to find
Re: Find the IType for a class [message #246749 is a reply to message #246745] Sun, 12 August 2007 05:08 Go to previous message
So if you are using a Java Nature, what did you mean by "The actual test class is on the plugin's classpath" ?
>> put the
>> Container
>> folder in
>> not
>>>> is on
>>>> (it should
>>>> type in it.
>>>> classpath, then
>>>> a secondary
>>>> correct
>>>> description of your
>>>> trying to find
Previous Topic:problems of resourcesplugin.getworkspace()
Next Topic:API for finding the plugin providing a given class?
Current Time: Wed Nov 05 02:28:23 EST 2025
Powered by FUDForum. Page generated in 0.05000 seconds
