Home » Eclipse Projects » GEF » How to change (Target)Anchor dynamicly?
How to change (Target)Anchor dynamicly? [message #227805] Mon, 11 December 2006 09:00 Go to next message
Originally posted by: js-ttn.jomisch.de
i have implemented my own anchorclass to handel alignments and offsets. the target-editpart of the connection has two incomming anchors. if the sourcefigur is left of the targetfigur the method getTargetConnectionAnchor() (calls getConnectionAnchor) return the left Anchor, otherwise the Anchor on the right side.
private ConnectionAnchor getConnectionAnchor(ConnectionEditPart connection) {
if (connection.getTarget() == this) {
PathEditPart sourcePathPart = (PathEditPart)connection.getSource().getParent();
if (sourcePathPart.getFigure().getBounds().x >= this.getFigure().getBounds().x)
return incomingAnchorRight;
else
return incomingAnchorLeft;
The Problem is that getTargetConnectionAnchor() is called before layouting is done. I have try to calculate the position in OffsetAnchor.getLocation() and set always a new anchor.
TargetEditPart =>
public ConnectionAnchor getTargetConnectionAnchor(ConnectionEditPart connection) {
OffsetAnchor anchor = new OffsetAnchor(getFigure(), connection);
anchor.setXAlign(OffsetAnchor.Align.auto);
return anchor;
But it has very strange results with the ShortestPathRouter (zigzag). How can i set the Anchor dynamicly? Please, step by step - i'm a beginner.
thx
josch
Re: How to change (Target)Anchor dynamicly? [message #228174 is a reply to message #227805] Sat, 16 December 2006 16:50 Go to previous messageGo to next message
Originally posted by: none.unknown.com
How about you only have one anchor that returns a different point based on
the figure's location? That's kinda like the ChopboxAnchor (see Shapes
example if you don't know how it behaves), but returns a point from a finite
set of points (in your case, a set of 2 points).
"josch" <js-ttn@jomisch.de> wrote in message
news:13539704.1165845645433.JavaMail.root@cp1.javalobby.org...
> Hello,
> connection) {
> else
> TargetEditPart =>
> connection) {
> return anchor;
> thx
> josch
Re: How to change (Target)Anchor dynamicly? [message #228183 is a reply to message #228174] Sun, 17 December 2006 15:25 Go to previous message
Hi Patrik,
&gt; How about you only have one anchor that returns a
&gt; different point based on
&gt; the figure's location?
i have tried this before. Now i look at my solution again - and found my error.
thanks
josch
Previous Topic:DragAndDrop between two view
Next Topic:restore diagram problem
Current Time: Sat Sep 13 19:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.04056 seconds
