Home » Language IDEs » Java Development Tools (JDT) » Refactoring Listener?
Refactoring Listener? [message #224299] Thu, 16 February 2006 16:32 Go to next message
Is is possible to listen to refactoring changes in the Java model? I know I
can listen to resource changes, but those IResourceDeltas don't contain any
Java-specific information. I need to know if someone renamed an IField or an
inner class represented as an IType, and I don't see how this would be
available from an IResourceDelta.
Re: Refactoring Listener? [message #224307 is a reply to message #224299] Thu, 16 February 2006 17:21 Go to previous messageGo to next message
Never mind, I found the refactoring extension points.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dt2r28$t4b$1@utils.eclipse.org...
> I can listen to resource changes, but those IResourceDeltas don't contain
> any Java-specific information. I need to know if someone renamed an IField
> or an inner class represented as an IType, and I don't see how this would
> be available from an IResourceDelta.
Re: Refactoring Listener? [message #224323 is a reply to message #224299] Fri, 17 February 2006 03:20 Go to previous messageGo to next message
There has been introduce new API to listen to refactoring changes. Have
a look at the interface IRefactoringHistoryService.
Cheers
Toby
Re: Refactoring Listener? [message #224367 is a reply to message #224323] Fri, 17 February 2006 11:47 Go to previous messageGo to next message
Sounds interesting, but in which Eclipse version is that? I can't find it in
3.1.1.
"Tobias Widmer" <tobias_widmer@ch.ibm.com> wrote in message
news:dt40vl$43c$1@utils.eclipse.org...
>> IField or an inner class represented as an IType, and I don't see how
>> this would be available from an IResourceDelta.
> There has been introduce new API to listen to refactoring changes. Have a
> Cheers
> Toby
Re: Refactoring Listener? [message #224413 is a reply to message #224367] Mon, 20 February 2006 10:59 Go to previous message
> 3.1.1.
>> Cheers
>> Toby
It is in Eclipse 3.2 greater than M4
Cheers
Toby
Previous Topic:Setting breakpoint in classes loaded through reflection
Next Topic:Refactoring Support for Move Refactoring
Current Time: Sat Sep 13 21:57:17 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
