| How to exclude Groovy plugin jars from Tomcat classpath [message #1210470] |
Mon, 25 November 2013 20:48  |
I have a Spring MVC project that uses Maven imported into Eclipse Kepler SR1 JEE and deployed to Tomcat 7 within Eclipse. Everything was fine until I recently added elasticsearch as a dependency to the Maven pom file and now when I start Tomcat I get an exception
java.lang.ClassCastException: org.springframework.web.servlet.DispatcherServlet cannot be cast to javax.servlet.Servlet
Launching the server in verbose mode, I see that its because the servlet API is now being loaded from 2 places:
the Tomcat installation folder where it normally comes from
Loaded javax.servlet.Servlet from file:/C:/ProgramFiles/apache-tomcat-7.0.33/lib/servlet-api.jar
but also from the Groovy plugin I have installed
Loaded javax.servlet.Servlet from file:/C:/ProgramFiles/eclipse/plugins/org.codehaus.groovy_1.8.6.xx-20130703-1600-e43-RELEASE/lib/servlet-api-2.4.jar
I can't figure out why this is happening. If I rename the servlet jar file in the plugin's lib folder (i.e. change the extension from .jar to something else so that its not recognized), Tomcat starts up without an exception but that's a hack and so I'd like to know what the cause is and if I'm missing some WTP configuration to exclude plugin library jars from the Tomcat classpath.
Thanks.
| Re: How to exclude Groovy plugin jars from Tomcat classpath [message #1220439 is a reply to message #1220138] |
Wed, 11 December 2013 12:51   |
On 12/9/2013 11:34 PM, steve B wrote:
> Downloaded the latest Tomcat and created a new runtime and server config
> in WTP but I got the LinkageError for "javax/servlet/ServletResponse".
> It seems that Maven/m2e is somehow involved in this because I don't get
> the error if I remove the elasticsearch dependency from the pom, this
> started happening only after adding that dependency. Looking at the
> dependency hierarchy when I view the pom in Eclipse, elasticsearch
> doesn't have a dependency on anything other than Lucene so its unclear
> why it has an effect on the server classpath.
> Steve
If you look at the published webapp under
"<workspace>/.metadata/.plugins/org.eclipse.wst.server.core/tmp?/wtpwebapps",
do you see "servlet-api" jar(s) included in its "WEB-INF/lib"?
While it is technically not correct to include a servlet-api jar in
WEB-INF/lib of a webapp, Tomcat tries to help out by ignoring the jar.
If this is occurring, you would see an INFO message in the console log
like the following:
INFO: validateJarFile(<path to jar>) - jar not loaded. See Servlet Spec
2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
Are you seeing this?
Larry
FUDForum. Page generated in 0.50726 seconds
