| Getting Invalid Registry Object while uninstalling plugins programatically [message #1138544] |
Tue, 15 October 2013 02:45  |
When a specific condition is hit (while the user is trying to open our perspective), we uninstall the plugins using the below code:
Platform.getBundle(<Bundle name>).uninstall();
When we run this code on Juno 4.2.2, we are hitting the below exception. This same code was working well in Indigo and other earlier releases. Is there a possible step we need to perform before the uninstall? Any help soon will be appreciated.
org.eclipse.core.runtime.InvalidRegistryObjectException: Invalid registry object
at org.eclipse.core.internal.registry.RegistryObjectManager.basicGetObject(RegistryObjectManager.java:273)
at org.eclipse.core.internal.registry.RegistryObjectManager.getObject(RegistryObjectManager.java:263)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getConfigurationElement(ConfigurationElementHandle.java:26)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getParent(ConfigurationElementHandle.java:103)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getDeclaringExtension(ConfigurationElementHandle.java:93)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getNamespaceIdentifier(ConfigurationElementHandle.java:130)
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.getPluginId(PerspectiveDescriptor.java:153)
at org.eclipse.ui.activities.WorkbenchActivityHelper.createUnifiedId(WorkbenchActivityHelper.java:180)
at org.eclipse.ui.activities.WorkbenchActivityHelper.getIdentifier(WorkbenchActivityHelper.java:57)
at org.eclipse.ui.activities.WorkbenchActivityHelper.allowUseOf(WorkbenchActivityHelper.java:104)
at org.eclipse.ui.activities.WorkbenchActivityHelper.restrictUseOf(WorkbenchActivityHelper.java:122)
at org.eclipse.ui.internal.registry.PerspectiveRegistry.findPerspectiveWithId(PerspectiveRegistry.java:162)
at org.eclipse.ui.internal.registry.PerspectiveRegistry.findPerspectiveWithId(PerspectiveRegistry.java:156)
at org.eclipse.ui.internal.WorkbenchPage.getPerspectiveDesc(WorkbenchPage.java:2385)
at org.eclipse.ui.internal.WorkbenchPage.getPerspective(WorkbenchPage.java:2375)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:952)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
FUDForum. Page generated in 0.05716 seconds
