Home » Eclipse Projects » EclipseLink » Name collision when using super-type in moxy oxm.xml
Name collision when using super-type in moxy oxm.xml [message #1104289] Sun, 08 September 2013 01:08 Go to next message
my oxm.xml
<xml-bindings xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/oxm" xml-accessor-type="NONE" xml-mapping-metadata-complete="true" package-name="com.flexdms.flexims.model.generated">
   <java-types>
      <java-type name="TypedQuery">
         <xml-root-element name="TypedQuery"/>
         <java-attributes>
            <xml-element java-attribute="id" name="id" xml-id="true"/>
            <java-attribute java-attribute="Name" name="Name" required="true"/>
            <java-attribute java-attribute="Type" name="Type" required="true"/>
         </java-attributes>
      </java-type>
      <java-type name="ConditionQuery" super-type="TypedQuery">
         <xml-root-element name="ConditionQuery"/>
         <java-attributes/>
      </java-type>
      <java-type name="SingleInt">
         <xml-root-element name="SingleInt"/>
         <java-attributes>
            <java-attribute java-attribute="DateCreated" name="DateCreated" required="true"/>
            <java-attribute java-attribute="DateModified" name="DateModified" required="true"/>
            <java-attribute java-attribute="defaultCase" name="defaultCase"/>
            <java-attribute java-attribute="withdefault" name="withdefault"/>
            <java-attribute java-attribute="requiredAndAuto" name="requiredAndAuto" required="true"/>
            <java-attribute java-attribute="AutoButNotRequired" name="AutoButNotRequired"/>
            <java-attribute java-attribute="withminandmax" name="withminandmax"/>
            <java-attribute java-attribute="allowedValue" name="allowedValue"/>
            <java-attribute java-attribute="allowedWithDefault" name="allowedWithDefault"/>
         </java-attributes>
      </java-type>
   </java-types>
</xml-bindings>
The exception I got
Local Exception Stack:
Exception [EclipseLink-50007] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.JAXBException
Exception Description: Name collision.  Two classes have the XML type with uri  and name typedQuery.
	at org.eclipse.persistence.exceptions.JAXBException.nameCollision(JAXBException.java:215)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.processTypeQName(AnnotationsProcessor.java:1783)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildTypeInfo(AnnotationsProcessor.java:812)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.postBuildTypeInfo(AnnotationsProcessor.java:738)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildNewTypeInfo(AnnotationsProcessor.java:4668)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.postProcessXmlAccessorType(AnnotationsProcessor.java:1612)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildTypeInfo(AnnotationsProcessor.java:800)
	at org.eclipse.persistence.jaxb.compiler.XMLProcessor.processXML(XMLProcessor.java:363)
	at org.eclipse.persistence.jaxb.compiler.Generator.<init>(Generator.java:104)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContext$MetadataContextInput.createContextState(DynamicJAXBContext.java:236)
	at org.eclipse.persistence.jaxb.JAXBContext.<init>(JAXBContext.java:174)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContext.<init>(DynamicJAXBContext.java:71)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContextFactory.createContextFromOXM(DynamicJAXBContextFactory.java:347)
	at com.flexdms.flexims.test.unit.query.TestMoxy.setJaxbContext(TestMoxy.java:58)
My DynamicJaxbContext is created like this
Map<String, Object> properties = new HashMap<String, Object>(1);
		properties.put(JAXBContextProperties.OXM_METADATA_SOURCE, new MoxyMetaSource(types));
		ServerSession session = JpaHelper.getEntityManagerFactory(em).getServerSession();
		DynamicClassLoader dcl =DJPAHelper.getDcl(session);
		jaxbContext =
			    DynamicJAXBContextFactory.createContextFromOXM(dcl, properties);
The dynamicClassLoader is from DynamicJPA. The class loader is already has all the dynamicTypes. My XmlBinding is created from java code. The oxm.xml shown above is the dump of java object. I do not see any name collision in my oxm.xml. Did I do something wrong with super-type?
thanks
Re: Name collision when using super-type in moxy oxm.xml [message #1106830 is a reply to message #1104289] Wed, 11 September 2013 11:57 Go to previous messageGo to next message
I wasn't able to get the same exception as you, but I did notice some problems with your metadata file:
- You have java-attribute elements where you meant to have xml-attribute.
- You did not fully qualify the class name for the specified super-type.
- You did not specify the type for the xml-attribute mappings.
oxm.xml
Below is an updated version of your oxm.xml file.
   <java-types>
         <java-attributes>
            <xml-attribute java-attribute="Name" name="Name" required="true" type="java.lang.String"/>
            <xml-attribute java-attribute="Type" name="Type" required="true" type="java.lang.String"/>
         </java-attributes>
      </java-type>
      <java-type name="ConditionQuery" super-type="com.flexdms.flexims.model.generated.TypedQuery">
         <java-attributes/>
      </java-type>
         <java-attributes>
            <xml-attribute java-attribute="DateCreated" name="DateCreated" required="true" type="java.util.Date"/>
            <xml-attribute java-attribute="DateModified" name="DateModified" required="true" type="java.util.Date"/>
            <xml-attribute java-attribute="defaultCase" name="defaultCase" type="java.lang.String"/>
            <xml-attribute java-attribute="withdefault" name="withdefault" type="java.lang.Boolean"/>
            <xml-attribute java-attribute="requiredAndAuto" name="requiredAndAuto" required="true" type="java.lang.Boolean"/>
            <xml-attribute java-attribute="AutoButNotRequired" name="AutoButNotRequired" type="java.lang.Boolean"/>
            <xml-attribute java-attribute="withminandmax" name="withminandmax" type="java.lang.Boolean"/>
            <xml-attribute java-attribute="allowedValue" name="allowedValue" type="java.lang.Boolean"/>
            <xml-attribute java-attribute="allowedWithDefault" name="allowedWithDefault" type="java.lang.Boolean"/>
         </java-attributes>
      </java-type>
   </java-types>
</xml-bindings>
Demo
Below is a simplified version of the bootstrap code:
package el520540;
import java.util.*;
import org.eclipse.persistence.jaxb.JAXBContextProperties;
import org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContextFactory;
public class Demo {
    public static void main(String[] args) throws Exception {
        Map<String, Object> properties = new HashMap<String, Object>();
        properties.put(JAXBContextProperties.OXM_METADATA_SOURCE, "el520540/oxm.xml");
        DynamicJAXBContextFactory.createContextFromOXM(Demo.class.getClassLoader(), properties);
Re: Name collision when using super-type in moxy oxm.xml [message #1106863 is a reply to message #1106830] Wed, 11 September 2013 12:47 Go to previous message
I get it worked following your instruction. I guess the cause is the super-type is not fully qualified.
Thanks, Blaise.
Previous Topic:Name collision when using super-type in moxy oxm.xml
Next Topic:how to control marshaller conditionally?
Current Time: Wed Oct 15 02:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.04827 seconds
