Home » Modeling » TMF (Xtext) » restriction/clear of index
restriction/clear of index [message #1065938] Fri, 28 June 2013 08:21 Go to next message
in my xtext project I'm using ResourceDescriptions for accesing EObjects. Therefor I implemented a ResourceDesciption where the computeExportedObjects method returns the desired objects. Also I've an according ResourceDescriptionManager and ServiceProvider which works so far.
But I observed the following behaviour. When I've several files, for example:
default1.pld: ObjectA, ObjectB, ObjectC
default2.pld: ObjectD, ObjectE
When I work in the default1.pld file, the computeExportedObjects returns the objetcs A,B,C and default2.pld accordingly D and E which is what I expected.
What I expected is that in default1.pld I can only acces the objects A,B,C and in default2.pld only D and E. But rather it is possible to acces all objects in both files (e.g. default1 can see A,B,C,D,E instead of A,B,C).
I'm not really familiar how this is working in xtext, but I reckon all returns of the computeExportedObjects method will be stored in an index?
So is there a way to clear the index before computeExportedObjects is called or even a better solution?
Re: restriction/clear of index [message #1065944 is a reply to message #1065938] Fri, 28 June 2013 08:36 Go to previous messageGo to next message
the restriction is ususally done by scoping. (have a look at org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider and subclasses)
~Christian
Re: restriction/clear of index [message #1065957 is a reply to message #1065944] Fri, 28 June 2013 09:24 Go to previous messageGo to next message
I'm already using scoping in another context which works great so far...
But for this context, scoping isn't possible because I'm using Xtext in GMF..maybe restriction isn't the right word to describe what I'm meaning..
What I want is simply an index for every file and not an index for all files..is this possible? Or how can I access the index?
Re: restriction/clear of index [message #1065959 is a reply to message #1065957] Fri, 28 June 2013 09:27 Go to previous messageGo to next message
the index gives you a complete overview.
what you get depends on how you ask it.
if you want to see what a specific resource has to offer you have
to ask for it. org.eclipse.xtext.resource.IResourceDescriptions.getResourceDescription(URI)
Re: restriction/clear of index [message #1065971 is a reply to message #1065959] Fri, 28 June 2013 10:20 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 28 June 2013 15:27
So there is an index for every project? And every object in every file in one project is in the same index?
But where will the index be asked? For example I'm using the content assistant, it shows me all objects. Have I to customize this?
Re: restriction/clear of index [message #1065974 is a reply to message #1065971] Fri, 28 June 2013 10:41 Go to previous messageGo to next message
No,
there is one index for the whole workspace. It contains a IResourceDescription for every resource (file). (you can imaging this as map of maps)
the org.eclipse.xtext.resource.IContainer.Manager takes care of visibility.
So here is what happens in default setup
Your Local Scopeprovider (AbstractDeclarativeScopeProvider)
delegates to ImportedNamespaceAwareLocalScopeProvider (AbstractGlobalScopeDelegatingScopeProvider)
delegates to DefaultGlobalScopeProvider (IGlobalScopeProvider)
delegates to visisible Conainers via IContainer.Manager)
so depending on your needs you have multiple places to hook in.
e.g. by saying org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider.getGlobalScope(Resource, EReference, Predicate<IEObjectDescription>)
returns null.
Re: restriction/clear of index [message #1065995 is a reply to message #1065974] Fri, 28 June 2013 13:28 Go to previous messageGo to next message
Thank you for your explanations. I think that I've understand it now a little bit more (though it's only a little bit I know about xtext). Are there maybe some examples?
But what I quite don't understand is how to hook in. Have I got to define my own implementation somewhere in my xtext project like this:
public class MyAbstractGlobalScopeDelegatingScopeProvider extends AbstractGlobalScopeDelegatingScopeProvider{
	public IScope getScope(EObject context, EReference reference) {
		// TODO Auto-generated method stub
		return null;
and bind it to my RuntimeModule?:
public class PldxRuntimeModule extends org.itea2.amalthea.model.variability.xtext.AbstractPldxRuntimeModule {
	public Class<? extends AbstractGlobalScopeDelegatingScopeProvider> bindAbstractGlobalScopeDelegatingScopeProvider() {
	    return MyAbstractGlobalScopeDelegatingScopeProvider.class;
[Updated on: Fri, 28 June 2013 13:32] by Moderator
Re: restriction/clear of index [message #1065999 is a reply to message #1065995] Fri, 28 June 2013 14:08 Go to previous messageGo to next message
No
this is not what i intended. i wanted you to subclass ImportedNamespaceAwareLocalScopeProvider (or whatever is used in your setup) and bind it like ImportedNamespaceAwareLocalScopeProvider is bound
	public void configureIScopeProviderDelegate(com.google.inject.Binder binder) {
		binder.bind(org.eclipse.xtext.scoping.IScopeProvider.class).annotatedWith(com.google.inject.name.Names.named(org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.class);
Re: restriction/clear of index [message #1066171 is a reply to message #1065999] Mon, 01 July 2013 07:14 Go to previous messageGo to next message
Thx Christian,
I've bound it now in this way, but couldn't notice any effects. I've set a breaking point to the getGlobalScope method, but it's never used. Am I'm missing something?
	public void configureIScopeProviderDelegate(Binder binder) {
				.annotatedWith(
				.to(MyImportedNamespaceAwareLocalScopeProvider.class);
public class MyImportedNamespaceAwareLocalScopeProvider extends ImportedNamespaceAwareLocalScopeProvider {
	protected IScope getGlobalScope(Resource context, EReference reference){
		System.out.println("Resources: " + context);
		return null;
Re: restriction/clear of index [message #1066179 is a reply to message #1066171] Mon, 01 July 2013 08:33 Go to previous message
Hi sorry don't know. Debug the chain I mentioned
Previous Topic:ignoreCase for Serializer 2.0
Next Topic:Duplicate methodes in generated SemanticSequencer
Current Time: Tue Oct 28 10:05:06 EDT 2025
Powered by FUDForum. Page generated in 0.33582 seconds
