Home » Eclipse Projects » Rich Client Platform (RCP) » How to get value from RCP forms
How to get value from RCP forms [message #992504] Fri, 21 December 2012 15:23 Go to next message
I created a form by using the forms API:
My question is how can write the code to get the values of "first name" and "last name" when "submit" button is clicked. Theanks.
here is my code in View.java
public class View extends ViewPart {
public static final String ID = "com.test.forms.view";
private TableViewer viewer;
public void createPartControl(Composite parent) {
FormToolkit toolkit = new FormToolkit(parent.getDisplay());
Composite client = toolkit.createComposite(parent, SWT.WRAP);
Table t = toolkit.createTable(client, SWT.NULL);
viewer = new TableViewer(t);
viewer.setContentProvider(new ArrayContentProvider());
viewer.setInput(getViewSite());
Form form = toolkit.createForm(parent);
Composite composite = form.getBody();
composite.setLayout (new GridLayout(2, true));
Label lblFirstName = toolkit.createLabel(composite, "First Name");
Label lblLastName = toolkit.createLabel(composite, "Last Name");
Text txtFirstName = toolkit.createText(composite, "");
Text txtLastName = toolkit.createText(composite, "");
Button b = toolkit.createButton(composite, "Submit", SWT.PUSH);
public void setFocus() {
viewer.getControl().setFocus();
Re: How to get value from RCP forms [message #994443 is a reply to message #992504] Thu, 27 December 2012 05:30 Go to previous messageGo to next message
Hello davy,
you just have to add an selection listener to the button in order to get to know when the button is clicked.
And then use the txtFirstName.getText() and txtLastName.getText() methods to get the values.
By the way the FormToolkit also does only create SWT widgets internally.
Simon
Re: How to get value from RCP forms [message #995952 is a reply to message #994443] Mon, 31 December 2012 11:15 Go to previous message
Thank you very much Simon! I got it now!
Previous Topic:How can i add an perspective from a plugin to my e4 application model?
Next Topic:Databinding, IListener, and Data Retention post application close
Current Time: Fri Oct 31 13:00:47 EDT 2025
Powered by FUDForum. Page generated in 0.32607 seconds
