| Loging SQL to a file [message #988720] |
Sat, 01 December 2012 17:44  |
I need help with configuration settings for logging SQL statements. If I use the Default Logger, the INPUT statements are displayed on the console. But when I change the configuration setting to output the logs to file, EclipseLink no longer logs the INPUT statements...
I would be very grateful if someone could provide me guidance as to what I need to do to get this fixed.
-Anis
I have provided my persistence.xml below:
<persistence
version="1.0">
<persistence-unit name="PerformanceMonitoring" transaction-type="JTA">
<description>PerformanceMoniotring</description>
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>MonitoringXA</jta-data-source>
<non-jta-data-source>MonitoringNonXA</non-jta-data-source>
<jar-file>monitored_activities_analyzer_mdb.jar</jar-file>
<class>org.company.MonitoredActivityVO</class>
<class>org.company.MonitoringSystemProperty</class>
<class>org.company.MonitoredActivityThreshold</class>
<properties>
<property name="eclipselink.logging.file" value="./monitoring.log"/>
<property name="eclipselink.logging.level" value="FINEST" />
<property name="eclipselink.logging.level.sql" value="FINE" />
<property name="eclipselink.logging.parameters" value="true"/>
<property name="eclipselink.logging.level.connection" value="FINE" />
<property name="eclipselink.logging.level.cache" value="FINE" />
<property name="eclipselink.logging.level.sequencing" value="FINE" />
<property name="eclipselink.logging.level.transaction" value="FINE" />
<property name="eclipselink.logging.level.query" value="FINEST" />
</properties>
</persistence-unit>
</persistence>
FUDForum. Page generated in 0.03733 seconds
