| Newbie: An error ocurred while setting the build path [message #141212] |
Tue, 07 October 2003 22:48 |
Originally posted by: sschwarz.hotmail.com
I've just installed Eclipse 2.1.1 stable on RH 8.0 and I'm running it
with j2sdk1.4.1_02. I'm getting an error dialog when I visit the Project
-> Properties -> Java Build Path anytime after the first time I add
external Jars to the project. That is, I can add the jars and OK the
dialog - subsequent viewing of that selection in the dialog and
selecting OK gives the error:
"An error occurred while setting the build path
Reason:
Resource /home does not exist"
I have to select Cancel to close the dialog.
Of course, this makes it difficult to modify the project... unless there
is a DTD for the .classpath that I can use to manually modify the file.
The .classpath file contains:
?xml version="1.0" encoding="UTF-8"?>
<classpath>
<classpathentry excluding="src/|save/" kind="src" path=""/>
<classpathentry kind="src" path="src"/>
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry kind="lib"
path=" /home/sschwarz/cocoon-2.1/build/webapp/WEB-INF/lib/xreporter -expression-20030725.jar "/>
path=" /home/sschwarz/cocoon-2.1/build/webapp/WEB-INF/lib/actions.j ar "/>
... and so on
</classpath>
the .log entry:
!SESSION Oct 07, 2003 20:48:44.445
java.version=1.4.1_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -install
file:/usr/local/share/eclipse/
!ENTRY org.eclipse.jdt.ui 4 10001 Oct 07, 2003 20:48:44.447
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource /home
does not exist.
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:302)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:174)
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:102)
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Folder.java:26)
org.eclipse.core.internal.resources.Folder.create(Folder.jav a:84)
org.eclipse.core.internal.resources.Folder.create(Folder.jav a:114)
org.eclipse.jdt.internal.ui.util.CoreUtility.createFolder(Co reUtility.java:37)
org.eclipse.jdt.internal.ui.util.CoreUtility.createFolder(Co reUtility.java:35)
org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathsBlo ck.internalConfigureJavaProject(BuildPathsBlock.java:646)
org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathsBlo ck.configureJavaProject(BuildPathsBlock.java:597)
org.eclipse.jdt.internal.ui.preferences.BuildPathsPropertyPa ge$1.run(BuildPathsPropertyPage.java:155)
org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.ex ecute(WorkspaceModifyDelegatingOperation.java:45)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:71)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1595)
<snip>
I don't know if it matters: I installed Eclipse to
/usr/local/share/eclipse as root and am running it as a non-root user.
I've searched the newsgroups, dev list, google, but can't seem to find
any others with this problem.
Any help would be greatly appreciated!
Steve
FUDForum. Page generated in 0.13831 seconds
