Home » Eclipse Projects » Remote Application Platform (RAP) » How to add log4j.xml to RAP-Application classpath
How to add log4j.xml to RAP-Application classpath [message #135494] Mon, 08 June 2009 08:20 Go to next message
I want to use log4j in my RAP application. The plugin that contains the
log4j libs provides factories for creating logger instances. These loggers
are used in other plugins. I can put a log4j.xml in the classpath of this
plugin - this works fine. But this plugin is used in an other application,
too. So I have to use an external log4j.xml-file.
In a RCP-application I use an entry for declaring the path to the
log4j.xml:
log4j.configuration=file:configuration/log4j.xml
The configuration directory contains the log4j.xml and so its easy to
change the configuration before starting the application.
If I add that entry to the config.ini of the RAP-application this
parameter is not passed to the jvm. I tried to declare it in the
launch.ini, too.
What is the best way to bind an external log4j configuration file?
best regards,
p-lex
Re: How to add log4j.xml to RAP-Application classpath [message #135862 is a reply to message #135494] Fri, 12 June 2009 05:48 Go to previous messageGo to next message
p-lex,
did you search the Equinox newsgroup for an answer? Several log4j
issues have been discussed there.
If you just need a replacement RCP way of specifying the
configuration, then search the web for "log4j.configuration web.xml".
HTH
Rüdiger
p-lex wrote:
> Hello,
> loggers are used in other plugins. I can put a log4j.xml in the
> classpath of this plugin - this works fine. But this plugin is used in
> an other application, too. So I have to use an external log4j.xml-file.
> log4j.xml:
> launch.ini, too.
> best regards,
> p-lex
Re: How to add log4j.xml to RAP-Application classpath [message #521361 is a reply to message #135494] Wed, 17 March 2010 08:21 Go to previous messageGo to next message
did you get a solution for your problem? if yes can you tell me how you did it. because i have the same problem. i try to integrate log4j in my rap application deployed as war file on jboss.
Thanks.
Re: How to add log4j.xml to RAP-Application classpath [message #521563 is a reply to message #135494] Wed, 17 March 2010 23:16 Go to previous message
May be you can consider to use pax logging to solve your problem,see [1].
[1] http://www.eclipse.org/forums/index.php?t=msg&&th=16 4627&goto=521363#msg_521363
Best Regards,
Cheney
> Hello,
> log4j.xml:
> launch.ini, too.
> best regards,
> p-lex
Previous Topic:RWT Test Dependencies
Next Topic:To the RAP Team: when are planned fixing bug 219465 ?
Current Time: Wed Oct 15 17:12:42 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
