Home » Archived » M2M (model-to-model transformation) » [qvto] One-to-Many Mappings
[qvto] One-to-Many Mappings [message #107006] Tue, 23 June 2009 14:17 Go to next message
I have a source model that contains an object whose data can cause
multiple objects to be instantiated in the target mapping. The source
model essentially represents a series of target model objects using a
'start' and 'stop' number. The mapping of the source element to the target
elements is potentially one-to-many.
I've tried several approaches to achieving this end. I've tried using a
while construct to loop around an object construct, but that appears to
simply create one object and update it even if I use +=. I've tried some
select/collect structures, but they produce collections that I then can't
iterate over to add to my target model.
Is there a viable pattern for solving this sort of problem?
Rhett
Re: [qvto] One-to-Many Mappings [message #107019 is a reply to message #107006] Wed, 24 June 2009 07:56 Go to previous messageGo to next message
Hi Rhett,
One-to-many mapping can be archived in different ways.
First one is to pass addition parameter (like record number) to the mapping:
main() {
var index := 0;
while (...) {
targetModel.ownedMembers += scrElement.map srcToTarget(index);
index := index + 1;
Another choice is to define constructor and use explicit object
instantiation:
constructor MyTargetType::MyTargetType(srcElement : MySrcType) {
main() {
while (...) {
targetModel.ownedMembers += new MyTargetType(srcElement);
Mapping operates in update semantic only when repeatedly called on the
same source with the identical (to the previous invocation) mapping
arguments.
Sergey.
> target elements is potentially one-to-many.
> can't iterate over to add to my target model.
> Rhett
Re: [qvto] One-to-Many Mappings [message #107048 is a reply to message #107006] Wed, 24 June 2009 08:36 Go to previous message
Hi Rhett,
There is a straightforward pattern for one-to-many mapping, expressed
directly in the operation signature using a collection return type.
You can use something like:
mapping Model::onetoMany() : Collection(Table) {
init {
result := Sequence {
object Table {},
object Table {}
Subsequent mapping calls on the same source object will retrieve
all the objects created in the first mapping call which actually
realized the one-to-many mapping.
/Radek
On Tue, 23 Jun 2009 20:17:06 +0200, Rhett Hudson <rhudson@annapmicro.com>
> Rhett
Previous Topic:[ATL] Call an operation
Next Topic:problem with transformation QVTR.
Current Time: Sun Sep 14 00:18:55 EDT 2025
Powered by FUDForum. Page generated in 0.05559 seconds
