| Eclipse Indigo with JDK 1.7 [message #717567] |
Sun, 21 August 2011 08:13  |
Is Eclipse Indigo supposed to be able to use Java 1.7?
Yesterday, I uninstalled Eclipse Indigo. I then installed the new Java 1.7 (specificall, jdk-7-windows-x64.exe) on my 64-bit Windows 7 computer. I adjusted my path environment variable so it points to the new jdk 1.7. My regedit now shows Java 1.7 to be the current version of Java.
I then re-installed Eclipse Indigo. In Eclipse, when I go to Window/Preferences/Java/Compiler, the Compiler Compliance Level drop-down shows options 1.3, 1.4, 1.5, and 1.6, but not 1.7. If I compile a program with a string for a switch control expression (a new feature in Java 1.7), I get a compilation error.
Note:
When I use a different IDE (TextPad), I can compile and run my Java 1.7 program (the one with a string for a switch control expression).
I load Eclipse (successfully) using the command:
C:\eclipse\eclipse.exe -vm "c:\Program Files\Java\jdk1.7.0\bin\javaw" -vmargs -Xmx256M
1. Is Eclipse Indigo supposed to be able to use Java 1.7?
2. If yes, how can I get Eclipse to use Java 1.7?
3. If no, when will Eclipse be able to use java 1.7?
John
| Re: Eclipse Indigo with JDK 1.7 [message #1803364 is a reply to message #717567] |
Wed, 27 February 2019 06:20  |
Hi All,
I need one clarity from you like how we can give security in eclipse indigo.
ex: can we give securities like when we upload code files in eclipse it has to be encrypted because i need to give security to my project.is it possible to give it?
i.e after running tomcat server automatically all the code should be in encrypted format,,others cant use my project?is this possible?
please suggest me on this.
Best,
Anand
FUDForum. Page generated in 0.08536 seconds
