Home » Eclipse Projects » Equinox » newbie: Building equinox from the source
newbie: Building equinox from the source [message #73883] Tue, 03 October 2006 23:29 Go to next message
Originally posted by: coddx.yahoo.com.br
Hi there,
I have downloaded equinox using eclipse import feature but I didnot find
a doc for make a jar file.. I tried sometimes to regenerate the
org.eclipse.osgi but I have failed..
How can I build a fresh jar from equinox??
I'm planing to change some features, that's what I'm need to rebuild all.
I did this:
I used the existing MANIFEST and export it all to jar then I got JAR
creation failed due a lot of messages like this:
JAR creation failed. See details for additional information.
Exported with compile warnings:
/org.eclipse.osgi/resolver/src/org/eclipse/osgi/internal/res olver/BundleDescriptionImpl.java
- a lot of those warnings above-
Problem writing
/org.eclipse.osgi/bin/org/eclipse/osgi/internal/resolver/Sys temState.class
to JAR: duplicate entry:
org/eclipse/osgi/internal/resolver/SystemState.class
Problem writing
/org.eclipse.osgi/resolver/src/org/eclipse/osgi/internal/res olver/SystemState.java
to JAR: duplicate entry: org/eclipse/osgi/internal/resolver/SystemState.java
/org.eclipse.osgi/resolver/src/org/eclipse/osgi/internal/res olver/UserState.java
Problem writing
/org.eclipse.osgi/bin/org/eclipse/osgi/internal/resolver/Use rState.class
to JAR: duplicate entry: org/eclipse/osgi/internal/resolver/UserState.class
Problem writing
to JAR: duplicate entry: org/eclipse/osgi/internal/resolver/UserState.java
/org.eclipse.osgi/resolver/src/org/eclipse/osgi/internal/res olver/VersionConstraintImpl.java
Problem writing
/org.eclipse.osgi/bin/org/eclipse/osgi/internal/resolver/Ver sionConstraintImpl.class
org/eclipse/osgi/internal/resolver/VersionConstraintImpl.cla ss
Problem writing
org/eclipse/osgi/internal/resolver/VersionConstraintImpl.jav a
there's no ant/maven script buiding...
thank your help
Re: newbie: Building equinox from the source [message #73903 is a reply to message #73883] Wed, 04 October 2006 05:35 Go to previous messageGo to next message
The recommended way to export bundles is to use the export deployable
plug-ins and features wizard.
This will generate a build.xml and run it to produce the desired jar and
then it will be deleted.
PaScaL
"exquisitus" <coddx@yahoo.com.br> wrote in message
news:efv9rg$15f$1@utils.eclipse.org...
> Hi there,
> I have downloaded equinox using eclipse import feature but I didnot find a
> I did this:
> Problem writing
> Problem writing
> Problem writing
> Problem writing
> Problem writing
> Problem writing
> thank your help
Re: newbie: Building equinox from the source [message #73921 is a reply to message #73903] Wed, 04 October 2006 09:49 Go to previous messageGo to next message
Originally posted by: nightwatch2006.gmail.com
Thanks Pascal,
I ran the wizard again and realize that, even with those duplicate error
messages, the jar file were successfully generated and then I could ran
it without problems.
thank you again.
Pascal Rapicault escreveu:
> PaScaL
>> Hi there,
>> I did this:
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> thank your help
Re: newbie: Building equinox from the source [message #73939 is a reply to message #73903] Wed, 04 October 2006 10:23 Go to previous message
> PaScaL
>> Hi there,
>> I did this:
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> Problem writing
>> thank your help
Thanks Pascal,
thank you again.
Previous Topic:Corona logging vs log4j direct access
Next Topic:Control RCP App on Server over Web Interface (RAP)
Current Time: Wed Oct 22 01:34:31 EDT 2025
Powered by FUDForum. Page generated in 0.04190 seconds
