No UI at runtime [message #73008] |
Sun, 28 November 2004 16:29  |
Originally posted by: jupiter49antiSPam.msn.com
Hi, I'm new to VE and the Java platform and am having trouble getting my
frame (with panel and button) to display when I run a simple Java App
project. No clue! Main executes, but no UI components seem to execute.
I tried putting a method breakpoint on "private JFrame getJFrame()" but the
debugger ignores it, so I don't know if I'm asking the debugger to do
something it can't do, or if there's a code problem of some type.
Shouldn't the JFrame and components just display or am I missing some
configuration issue?
Versions:
jdk1.4.2
eclipse 3.0.1
jre1.4.1_03
Re: No UI at runtime [message #73061 is a reply to message #73044] |
Sun, 28 November 2004 21:15  |
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:codup8$c4j$1@www.eclipse.org...
> Hi Paul,
> Did you write any code within your main() method to call the getJFrame()
> method? The VE doesn't write the main() method for you when working
> with Swing because usually there's more to starting up an application
> than simply opening the JFrame. Using Run As->Java Bean we allow you to
> test out your visual classes without having to write a main() method.
> - Jeff
Jeff,
No, I only tried a static call to getJFrame() and it predictably (I'm now
realizing why) complained about the method not being static. So that's my
problem. I have to now catch up with how you guys do this because I'm not
used to instantiating an instance of a class that I'm already in order to
run its private methods. I shoulda known when I saw the compiler error.
This is obviously not a VE or IDE problem, so thanks for steering me in the
right direction. Paul
Re: No UI at runtime [message #603450 is a reply to message #73008] |
Sun, 28 November 2004 20:42  |
Hi Paul,
- Jeff
> Versions:
> jdk1.4.2
> eclipse 3.0.1
> jre1.4.1_03
Re: No UI at runtime [message #603457 is a reply to message #73044] |
> Hi Paul,
> - Jeff
Jeff,
FUDForum. Page generated in 0.04473 seconds
