Home » Eclipse Projects » Eclipse 4 » NPE using the live editor
NPE using the live editor [message #697669] Sun, 17 July 2011 12:57 Go to next message
Originally posted by: Jonas Helming
I am starting a very basic e4 Application. The workbench model only
contains one TrimmedWindow and a Binding Context. The application starts
fine, but when I add the liveeditor to my launch config, I get an NPE on
start-up (see below). It seems that the EHandlerService is null. e4 core
service and commands are part of the launch config.
any ideas?
Cheers
Jonas
Affected Line:
EHandlerService hs = (EHandlerService)
context.get(EHandlerService.class.getName());
Exception:
org.eclipse.e4.ui.internal.workbench.E4Workbench.processHierarchy(E4Workbench.java:191)
org.eclipse.e4.ui.internal.workbench.E4Workbench.init(E4Workbench.java:115)
org.eclipse.e4.ui.internal.workbench.E4Workbench.<init>(E4Workbench.java:70)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:288)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:130)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: NPE using the live editor [message #699877 is a reply to message #697669] Fri, 22 July 2011 10:17 Go to previous messageGo to next message
Is your Application.e4xmi is missing the default addons?
Tom
Am 17.07.11 18:57, schrieb Jonas Helming:
> any ideas?
> Cheers
> Jonas
> Affected Line:
> Exception:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NPE using the live editor [message #701076 is a reply to message #699877] Sun, 24 July 2011 11:03 Go to previous message
Thanks Tom, that helped! I added the following addons (the can be copied
from the template by creating a new e4 project)
<addons xmi:id="_xp_mhLYDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.core.commands.service"
contributionURI="platform:/plugin/org.eclipse.e4.core.commands/org.eclipse.e4.core.commands.CommandServiceAddon"/>
<addons xmi:id="_xp_mhbYDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.ui.contexts.service"
contributionURI="platform:/plugin/org.eclipse.e4.ui.services/org.eclipse.e4.ui.services.ContextServiceAddon"/>
<addons xmi:id="_xp_mhrYDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.ui.bindings.service"
contributionURI="platform:/plugin/org.eclipse.e4.ui.bindings/org.eclipse.e4.ui.bindings.BindingServiceAddon"/>
<addons xmi:id="_xp_mh7YDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.ui.workbench.commands.model"
contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.CommandProcessingAddon"/>
<addons xmi:id="_xp_miLYDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.ui.workbench.contexts.model"
contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.ContextProcessingAddon"/>
<addons xmi:id="_xp_mibYDEeC0lu-qC79bNA"
elementId="org.eclipse.e4.ui.workbench.bindings.model"
contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench.swt/org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon"/>
Am 22.07.2011 16:17, schrieb Tom Schindl:
> Tom
>> any ideas?
>> Cheers
>> Jonas
>> Affected Line:
>> Exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:Information on Menus, Contribution, Handlers, Commands, etc.
Next Topic:(no subject)
Current Time: Wed Nov 05 05:52:27 EST 2025
Powered by FUDForum. Page generated in 0.03371 seconds
