Home » Archived » Buckminster » SettingIgnoring Worspace's API Base Line
| SettingIgnoring Worspace's API Base Line [message #664121] |
Thu, 07 April 2011 10:33  |
Hi Bucky Team,
Recently, I've tried to change my hudson job[1] to use buckminster 3.7. I got the following errors, which were warnings when using buckminster 3.6:
Error: file /opt/users/hudsonbuild/workspace/buckminster-mdt-ocl-core-3. 1-nightly/buildroot/buckminster.workspace/plugins/org.eclips e.ocl: An API baseline has not been set for the current workspace.
My questions are the following:
a) Is there any way via buckminster commands to change the workspace settings so that not setting API Base line for it is a warning rather than an error. If there were someone, could I have some guidances to do that ?
b) I have read some documentation concerning setting the API base line for buckminster's workspace [2]. I'm wondering if hudson server has any defined API base lines, so that I may simply add a "setpref" command to use said API base line. Otherwise, would I have to define a baseline ? May a p2 URL be used as the the API Base Line ?
[1] https://hudson.eclipse.org/hudson/job/buckminster-mdt-ocl-co re-3.1-nightly/
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=312021
| Re: SettingIgnoring Worspace's API Base Line [message #664158 is a reply to message #664121] |
Thu, 07 April 2011 11:59   |
Hi Adolfo,
On 2011-04-07 16:33, Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Bucky Team,
> workspace.
If it is possible to control this via a project specific setting, then I would recommend that you do that and check it
in. If not, then what you need is a template workspace. There is large amount of settings that affect your builds in
various ways and the Eclipse IDE provides convenient preference pages for them. The mechanics are simple:
1. Start your IDE on a non-existent workspace.
2. Set all settings that you want in your build.
3. Exit your IDE.
4. Create a zip of the workspace. This is now the template.
5. Unzip the template to the location that you later refer to with -data as the first step in your headless build.
Buckminster will now build your workspace with the settings from #2.
A baseline has to be a target definition so that's something that you'll need to prepare in advance. IIRC, Johannes
Utzig made some experimental support for this in the Hudson Buckminster plug-in but I'm not sure what the status is on that.
- thomas
| Re: SettingIgnoring Worspace's API Base Line [message #664381 is a reply to message #664342] |
Fri, 08 April 2011 11:07   |
Hi All,
comments bellow.
Dne 8.4.2011 14:17, Thomas Hallgren napsal(a):
> On 2011-04-08 14:11, Adolfo Sánchez-Barbudo Herrera wrote:
>> Well, I could try this. However, I've noticed that EMF job is using
>> Buckminster 3.7 and it doesn't seem the build needs
>> this extra effort. Would you mind point Mickal to this thread to
>> obtain his feedback ?
> I can see two reasons for that. Either they use the project specific
> settings that I proposed, or they didn't have the warnings at all when
> they used 3.6.
It is as Thomas have guessed: we didn't get the warnings with the 3.6
based buckminster so we don't have the problem with the 3.7 based one.
On the workspace level settings and workspace template front: I'm not a
huge fan of the workspace template idea, as it is not very flexible when
you are in a need to make a particular workspace level setting a
changeable parameter of a headless build. So the preferred solution IMO
would be to add the support for changing the setting to Buckminster.
This can prove to be very easy to do (as was the case of SSH preferences
- see [1] and [2]). So if you could find out how to change that setting
programmatically and provide a patch for that, I'd be happy to review
and apply it.
Michal
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=310204
[2]
http://dev.eclipse.org/viewcvs/viewvc.cgi?view=revision& root=TOOLS_BUCKMINSTER&revision=11445
| Re: SettingIgnoring Worspace's API Base Line [message #664391 is a reply to message #664381] |
Fri, 08 April 2011 11:50   |
Mid-air collision.
Michal, Thomas thanks, I'll look into the better way to deal with this.
Best Regards,
Adolfo.
>I can see two reasons for that. Either they use the project specific settings that I proposed, or they didn't have the
warnings at all when they used 3.6.
1. As said, there is not project specific settings for this. I mean, setting the API baseline for the workspace, and having a warning or error for not setting it up, is an exclusive workspace setting.
2. I also believe that the didn't have those warning when they used 3.6. Now, the question is why my build has those warnings (Bucky3.6) / errors (Bucky 3.7) and the EMF one doesn't have any, providing we are both using the same Hudson/Buckminster stuff
Perhaps, having any other API Analysys setting could cause this ?. For intance, I can see that the project org.eclipse.ocl has
- an org.eclipse.pde.api.tools.apiAnalysisNature nature.
- an org.eclipse.pde.api.tools.apiAnalysisBuilder builder.
In the case this was the cause, we can't obviously remove this, since this is a requirement for our projects to ensure that developers are doing well with APIs.
Could you please ask Michal if he has done anything setting concerning API Analysy Tooling .
Thanks in advance,
Adolfo.
| Re: SettingIgnoring Worspace's API Base Line [message #664402 is a reply to message #664391] |
Fri, 08 April 2011 12:19   |
Adolfo, Michal, please add enhancement requests to our bugzilla for any additional setting that you think is
appropriate. The API support is relatively new and your experience in this area is important.
Thomas Hallgren
On 2011-04-08 17:50, Adolfo Sánchez-Barbudo Herrera wrote:
> Mid-air collision.
> Best Regards,
> Adolfo.
> org.eclipse.ocl has
> Thanks in advance,
> Adolfo.
| Re: SettingIgnoring Worspace's API Base Line [message #664988 is a reply to message #664402] |
Tue, 12 April 2011 13:26   |
Thommas, Michal,
When reading some bugzillas[1] I've found that using the importprefs command could be an alternative way to tune up this setting (among others) when running my job. Michal, could you expand the information in said bugzilla in which you say that this mechanism is not flexible ?.
On the other hand, I've tried to fix the problem by the means of setting up the API Base Line. I've finally got it [2] using the following commands
# We import a target definition which will be our API Base Line
importtargetdefinition " ${checkout.location}/org.eclipse.mdt/org.eclipse.ocl/releng/ org.eclipse.ocl.releng.buckminster/APIBaseLine.target "
addbaseline -A "MDT/OCL API Base Line"
However, I have a couple of inconveniences/issues/questions:
1. There are a lot of [Fatal Error] :1:1: Premature end of file.
However, this doesn't prevent the build success. Besides, I read in a different forum's thread[3] that this would be fixed in the next milestone.
2. There a lot of ERROR: Error logged from API Tools Core:
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:883)
at org.eclipse.pde.api.tools.internal.ApiBaselineManager.persis tStateCache(ApiBaselineManager.java:339)
However, this doesn't prevent the build sucess. Any idea what about this issue ?.
[2] https://hudson.eclipse.org/hudson/job/buckminster-mdt-ocl-co re-3.1-nightly/425/
[3] http://www.eclipse.org/forums/index.php?t=msg&goto=66349 9
Adolfo.
| Re: SettingIgnoring Worspace's API Base Line [message #670359 is a reply to message #665010] |
Fri, 13 May 2011 12:17  |
Hello Thomas,
Taking this issue up
This is a known bug in p2 3.7M6. It causes no harm other than the ugly
printout and is already fixed in an integration build.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=341508
This is still happening in Eclipse Hudson's job. Would you mind telling Mickal to do an update of the buckminster 3.7 used by Eclipse Hudson?. Would you need a bugzilla for this ?
That might be worth reporting to the PDE team. I haven't seen that before.
- thomas
I've finally fixed this. The problem was that I was using a "path" rather than "uri" in the importtargetdefinitiion command in order to import the target platform which would be act as the API Base line in buckminster's workspace. So, in my job configuration I've replaced:
addbaseline -A "Eclipse OCL API Base Line"
By:
importtargetdefinition " file://${checkout.location}/org.eclipse.mdt/org.eclipse.ocl/ releng/org.eclipse.ocl.releng.buckminster/APIBaseLine.target"
The API Tooling would probably treat path as workspace relative paths, so we would need to use a proper file URI to tell buckminster from where obtain the target platform definition.
I hope this help others.
Adolfo.
Current Time: Fri Oct 24 10:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.06510 seconds
