Home » Language IDEs » Java Development Tools (JDT) » Java compiled error - file icon not marked for error
Java compiled error - file icon not marked for error [message #656172] Thu, 24 February 2011 07:54 Go to next message
Hi!
I have a compiler error in one java file, but the error is not marked:
- on the icon of that file in the Project Explorer view
- in the Markers or Problems view under Java Problems / Errors
If I open the file in editor, it has the error underlined, there are red markings in that column right of the vertical scroll bar,
there is a red square at the top right corner. But no error mark in the icon in tha tab title.
Also in the Project Explorer the project icon has an error mark and the "Java resources" has an error mark in its icon.
What I have are several related projects checked out from SVN (using subclipse). Today I checked out some more.
They depend on some of the precious ones. The described error is in one of the newly checked out projects.
Is this a sync issue?
The maven console also reports the error.
Versions:
Eclipse Java EE IDE for Web Developers.
Version: Helios Service Release 1
Build id: 20100917-0705
Subclipse (Required) 1.6.17 org.tigris.subversion.subclipse.feature.group
Maven Integration for Eclipse (Required) 0.12.1.20110112-1712 org.maven.ide.eclipse.feature.feature.group
Sun Java 1.6.0_24
Windows XP Pro SP3
David Balažic
Re: Java compiled error - file icon not marked for error [message #656186 is a reply to message #656172] Thu, 24 February 2011 08:36 Go to previous messageGo to next message
Did you try to run a full clean?
Project > Clean...
Select all projects and then click ok?
Normally, synchronization problems are solved with that.
You can also try to right-click on the project and then Refresh and Validate so that all validators and files are in sync with Eclipse view.
I had that kind of problem before and solved with these procedures.
Re: Java compiled error - file icon not marked for error [message #656188 is a reply to message #656186] Thu, 24 February 2011 08:40 Go to previous messageGo to next message
I tried Clean, Refresh, Validate, neither helps.
Re: Java compiled error - file icon not marked for error [message #656200 is a reply to message #656188] Thu, 24 February 2011 09:40 Go to previous messageGo to next message
Your problem comes from the reconciler. Are you using mixed 1.4/1.5 projects ?
I would open a bug report against JDT/Core with steps to reproduce. We need to be able to reproduce the problem in order to fix it.
You can also try a I-build from 3.7 stream to see if this is fixed in HEAD.
Olivier
Re: Java compiled error - file icon not marked for error [message #656206 is a reply to message #656200] Thu, 24 February 2011 09:55 Go to previous messageGo to next message
Olivier Thomann wrote on Thu, 24 February 2011 15:40
Every project in workspace has the Java Compiler / JDK Compliance set to "Use complience from execution environment 'JavaSE-1.6' on the Java Build Path" *
Or did you mean something else?
They are maven managed projects, using the m2eclispe plugin v0.12.1.
There are also a few non-java projects.
David
* - funny, if I right click this text, the option get enabled/disable. All other can be switched only with left click.
Re: Java compiled error - file icon not marked for error [message #656209 is a reply to message #656206] Thu, 24 February 2011 10:02 Go to previous messageGo to next message
When you hover on it, what kind of error is shown ?
The best I can recommend is that you open a bug report with steps to reproduce.
Without further details, it is difficult to give you hints to solve this issue.
Olivier
Re: Java compiled error - file icon not marked for error [message #656210 is a reply to message #656209] Thu, 24 February 2011 10:06 Go to previous messageGo to next message
Hover over what?
Over the error in editor?
I fixed the original error, but I created a nrew one, simply by adding a space into a method call: x.fooBar(..) -> x.foo Bar(...)
Hovering over the broken method name gives: foo cannot be resolved or is not a field
This seems to happen just in one project, the others seem to be fine.
PS: I really don't know what steps reproduce this, so I wont open a bug (yet).
[Updated on: Thu, 24 February 2011 10:07] by Moderator
Re: Java compiled error - file icon not marked for error [message #656250 is a reply to message #656210] Thu, 24 February 2011 12:10 Go to previous messageGo to next message
David Balažic wrote on Thu, 24 February 2011 10:06
This is expected. When you add a space, foo cannot be resolved. This is because the reconciler tries to "resolve" the current unit.
You can disable this inside the java editor preferences.
Olivier
Re: Java compiled error - file icon not marked for error [message #657301 is a reply to message #656186] Wed, 02 March 2011 06:17 Go to previous messageGo to next message
I think I found a hint.
The problematic project has no javabuilder declared in its .project file.
The other, "good" projects have this:
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
So what is the next step?
Add this into the .project file directly (in some editor) ?
Or is there a GUI for it?
[Updated on: Wed, 02 March 2011 06:17] by Moderator
Re: Java compiled error - file icon not marked for error [message #657337 is a reply to message #657301] Wed, 02 March 2011 08:49 Go to previous messageGo to next message
> The other, "goog" projects have this:
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
Right click the project in Package Explorer and select properties from
the context menu. Go to 'Builders' page in the properties dialog and
check the 'Java Builder'.
Re: Java compiled error - file icon not marked for error [message #657342 is a reply to message #657337] Wed, 02 March 2011 09:01 Go to previous messageGo to next message
Deepak Azad wrote on Wed, 02 March 2011 14:49
There is no 'Java Builder' on that page.
Re: Java compiled error - file icon not marked for error [message #657345 is a reply to message #657301] Wed, 02 March 2011 09:08 Go to previous messageGo to next message
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
Yes, add the following using the default Text Editor:
<buildSpec>
<buildCommand>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.jdt.core.javanature</nature>
</natures>
Dani
Re: Java compiled error - file icon not marked for error [message #657346 is a reply to message #657345] Wed, 02 March 2011 09:13 Go to previous message
This is already there, only the builder was missing.
Previous Topic:Java and enums
Next Topic:Make Eclipse not to follow symbolic links
Current Time: Fri Oct 10 06:49:20 EDT 2025
Powered by FUDForum. Page generated in 0.31262 seconds
