Home » Modeling » EMF » Best practices: versioning .ecore files
Best practices: versioning .ecore files [message #655739] Tue, 22 February 2011 09:31 Go to next message
in our project we're working with an .ecore file we generate code from (Xpand-based generator with ecore.ecore as metamodel).
In the beginning of the project there was only one developer working with the model and the .ecore file was put to the projects SVN repository.
Now there are a couple of developers working concurrently on that model and it's getting harder to cope with concurrent model changes since SVN only works with xml comparision.
Are there any best practices for versioning of and concurrently working with .ecore files?
I took a look at EMFStore and I think that it looks pretty cool, but as far as I can see it's for working with models based on my model (defined in .ecore file).
I also took a look at CDO, but it seems to me that it's designed for similar use cases like covered by EMFStore.
Is there "something on top of SVN", so that we're able to still store the file in SVN, but get merge support in a more convenient was?
Greets,
Christian
Re: Best practices: versioning .ecore files [message #655782 is a reply to message #655739] Tue, 22 February 2011 10:45 Go to previous messageGo to next message
Am 22.02.2011 15:31, schrieb Christian Huelsmeier:
> Hello,
Recently we've added support for storing instances of Ecore just like instances of other models. Please note that certain backend stores (like the DBStore) require that you declare your intent to store Ecore instances in the cdo-server.xml:
<property name="supportingEcore" value="true"/>
Cheers
/Eike
http://www.esc-net.de
Re: Best practices: versioning .ecore files [message #655866 is a reply to message #655739] Tue, 22 February 2011 17:05 Go to previous messageGo to next message
Originally posted by: jconlon.apache.org
Hi Christian,
I too am interested in hearing an answer from the more experienced and
knowledgeable EMFers out there regarding your question...
Just read Kenn and Marcello's EclipseCon 2009 Modeling tutorial
'Building Restful Java Applications with EMF'
http://www.eclipsecon.org/2009/sessions?id=272
which contain many best practices for modeling and persisting EMF
models. There are a couple that are oriented toward versioning of.ecore
files as well.
Have you looked at EMFCompare?
cheers,
John
Christian Huelsmeier wrote:
> Hello,
> with .ecore files?
> in .ecore file).
> Greets,
> Christian
Re: Best practices: versioning .ecore files [message #656746 is a reply to message #655739] Mon, 28 February 2011 07:06 Go to previous messageGo to next message
Hi Christian,
EMFStore is capable of versioning and storing any EMF-based Model
including Ecore itself. However from a user perspective we believe an
integration with your (source code) team provider such as SVN or Git
would be very beneficial.
With the current state of EMFStore you can import a model into the
EMFStore and use its versioning and merging capabilities. EMFStore
supports interactive merging of EMF-based models, so you will only need
to resolve conflicting changes to merge. If you want to generate code
you can export to an .ecore file again.
We are currently working on an integration of EMFStore with SVN and GIT.
(see this blog post:
http://unicase.blogspot.com/2010/11/how-to-version-ecore-fil es.html).
This will integrate the EMFStore-hosted Ecore models as files into your
project/package explorer. Also an update/commit on your project will
also trigger an update/commit on the EMFStore-hosted ecore file. We hope
to release a beta version for the EclipseCon.
If you would like to test an alpha, please let me know!
Maximilian
> Hello,
> with .ecore files?
> in .ecore file).
> Greets,
> Christian
Re: Best practices: versioning .ecore files [message #659317 is a reply to message #655866] Sat, 12 March 2011 01:50 Go to previous messageGo to next message
Hi John,
yes, I took a look at EMFCompare and basicly in most cases it's working for us. Meanwhile our problem with many developers working on one .ecore file has been solved by defining some processes and conventions.
Now we are coming into a phase where we are creating models on top of our .ecore file (now as meta model).
I will have a deeper look at EMFStore now.
Christian
Re: Best practices: versioning .ecore files [message #659318 is a reply to message #656746] Sat, 12 March 2011 02:03 Go to previous message
Maximilian Koegel wrote on Mon, 28 February 2011 07:06
Hi Maximilian,
yes, I'm interested in testing and using your SVN integration.
I also read your blog some weeks ago, but didn't find any plugins or documentation.
Is it still stable? I really need a reliable solution.
Christian
Previous Topic:EMF Editor and CrossReference
Next Topic:Multiple branch merging in CDO
Current Time: Mon Nov 03 13:54:35 EST 2025
Powered by FUDForum. Page generated in 0.04298 seconds
