Home » Modeling » EMF » PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor
PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #646429] Fri, 24 December 2010 01:23 Go to next message
I can open XMI files with or without xsi:schemaLocation just fine from
my application, because my application register the package(s) to the
EMF package registry.
However upon saving the resource ("someXMIResource.save(null)") it
removes xsi:schemaLocation from the the .xmi file, making it ineditable
using Eclipse IDE's EMF Editor.
Re-adding schemaLocation works (see
http://eclipsedriven.blogspot.com/2010/12/solving-inside-ecl ipse-
ide.html ), however I'm tired of doing this again and again.
Is there a way to:
1. Add my package to Eclipse *IDE*'s package registry so that XMI files
without xsi:schemaLocation can still be loaded by EMF editor?
2. Or if #1 is not possible, configure so that XMIResource doesn't
remove the xsi:schemaLocation from the XMI file?
Thank you.
Eclipse Driven Rich Application Development -
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #646434 is a reply to message #646429] Fri, 24 December 2010 01:56 Go to previous messageGo to next message
--------------010609010308000309080505
Hendry,
Comments below.
This option controls whether a schema location is saved:
* Produce an xsi:schemaLocation/xsi:noNamespaceSchemaLocation in
the saved result.
String OPTION_SCHEMA_LOCATION = "SCHEMA_LOCATION";
Generally, for registered packages, there's no need for it...
> Is there a way to:
Yes, by installing a plugin that registers it.
The option mentioned above.
A technique that works too is the fact that the nsURI itself will be
used as a schema location if a registered package isn't found...
> Thank you.
<html>
<head>
</head>
Hendry,<br>
<br>
Comments below.<br>
<br>
Hendy Irawan wrote:
<blockquote cite="mid:if1dv6$e2k$1@news.eclipse.org" type="cite">
<pre wrap="">I can open XMI files with or without xsi:schemaLocation just fine from
</pre>
</blockquote>
This option controls whether a schema location is saved:<small><br>
</small>
<blockquote><small>&nbsp; /**</small><br>
<small>&nbsp;&nbsp; * Produce an
xsi:schemaLocation/xsi:noNamespaceSchemaLocation in the saved result.</small><br>
<small>&nbsp;&nbsp; */</small><br>
<small>&nbsp; String OPTION_SCHEMA_LOCATION = "SCHEMA_LOCATION";</small><br>
</blockquote>
Generally, for registered packages, there's no need for it...<br>
<pre wrap="">
<a class="moz-txt-link-freetext" href=" http://eclipsedriven.blogspot.com/2010/12/solving-inside-ecl ipse"> http://eclipsedriven.blogspot.com/2010/12/solving-inside-ecl ipse</a>-
Is there a way to:
</pre>
</blockquote>
Yes, by installing a plugin that registers it.<br>
<pre wrap="">2. Or if #1 is not possible, configure so that XMIResource doesn't
</pre>
</blockquote>
The option mentioned above.<br>
<br>
used as a schema location if a registered package isn't found...<br>
<pre wrap="">
Thank you.
</pre>
</blockquote>
</body>
</html>
--------------010609010308000309080505--
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #646471 is a reply to message #646434] Fri, 24 December 2010 11:24 Go to previous messageGo to next message
ineditable
in
> the saved result.
Wow! Thank you! I found it, it's in XMIResource.OPTION_SCHEMA_LOCATION
... SO we use it like:
opts.put(XMIResource.OPTION_SCHEMA_LOCATION, "file:///somefile.ecore");
resource.save(opts);
right?
Amazing! This is exactly what I needed! Thanks Ed.
I need to use it from the Eclipse IDE, and I don't want to install my
plugins yet in the IDE.. esp when the metamodel changes often.
>> Is there a way to:
files
Thanks! Sounds obvious, but I didn't think of that ;-)
Thanks!
>> Thank you.
Meaning that if I have a nsURI as
"http://somedomain.com/metamodel.ecore" that actually contains an ecore
metamodel, it works? Thanks!!
Thanks again Ed! And thanks for helping so quickly :)
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #646472 is a reply to message #646471] Fri, 24 December 2010 11:44 Go to previous messageGo to next message
--------------060004060606070403060809
Hendy,
No, OPTION_SCHEMA_LOCATION is a boolean option; a serialization can
contain many packages. Be sure to read this FAQ question too.
2.22 How can I ensure that an xsi:schemaLocation is serialized for
my packages?
< http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F>
In general, a schema location is saved only if the option is true *and
*the package's containing resource's URI is different from the nsURI.
Also OPTION_SCHEMA_LOCATION_IMPLEMENTATION might be useful for
serialization of generated models that need to be processed in a stand
alone application; it can use Java reflection to find the package
instance eliminating the need to ensure that it's pre-registered in
EPackage.Registry.INSTANCE or ResourceSet.getPackageRegistry().
> ineditable
> in
>> the saved result.
> right?
>>> Is there a way to:
> files
> Thanks!
>>> Thank you.
<html>
<head>
</head>
Hendy,<br>
<br>
contain many packages.&nbsp; Be sure to read this FAQ question too.<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F"><span
class="tocnumber">2.22</span> <span class="toctext">How can I ensure
that an xsi:schemaLocation is serialized for my packages?</span></a><br>
</blockquote>
In general, a schema location is saved only if the option is true <b>and
</b>the package's containing resource's URI is different from the
nsURI.&nbsp; Also OPTION_SCHEMA_LOCATION_IMPLEMENTATION might be useful for
EPackage.Registry.INSTANCE or ResourceSet.getPackageRegistry().<br>
<br>
<br>
Hendy Irawan wrote:
<blockquote cite="mid:if2h6a$vku$1@news.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">However upon saving the resource ("someXMIResource.save(null)") it
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->ineditable
</pre>
<pre wrap="">using Eclipse IDE's EMF Editor.
</pre>
</blockquote>
<pre wrap="">This option controls whether a schema location is saved:
</pre>
</blockquote>
</pre>
<pre wrap=""> the saved result.
</pre>
</blockquote>
opts.put(XMIResource.OPTION_SCHEMA_LOCATION, <a class="moz-txt-link-rfc2396E" href="file:///somefile.ecore">"file:///somefile.ecore"</a>);
right?
</pre>
<pre wrap="">Is there a way to:
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->files
</pre>
<pre wrap="">without xsi:schemaLocation can still be loaded by EMF editor?
</pre>
</blockquote>
<pre wrap="">Yes, by installing a plugin that registers it.
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
<pre wrap="">The option mentioned above.
</pre>
</blockquote>
Thanks!
</pre>
<pre wrap="">A technique that works too is the fact that the nsURI itself will be
</pre>
<pre wrap="">Thank you.
</pre>
</blockquote>
</blockquote>
<a class="moz-txt-link-rfc2396E" href="http://somedomain.com/metamodel.ecore">"http://somedomain.com/metamodel.ecore"</a> that actually contains an ecore
</pre>
</blockquote>
</body>
</html>
--------------060004060606070403060809--
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #646478 is a reply to message #646472] Fri, 24 December 2010 13:24 Go to previous messageGo to next message
Ed Merks wrote:
> Hendy,
for
> my packages?
*and
stand
Thanks Ed!
I've tried it, overriding createResource() and setting
OPTION_SCHEMA_LOCATION to true works very well as I wanted.
I've also blogged based on your answer on:
http://eclipsedriven.blogspot.com/2010/12/saving-xsischemalo cation-
into-emf-xmi.html
so hopefully it may help others looking for this solution.
Thanks again.
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #1384943 is a reply to message #646472] Tue, 03 June 2014 05:08 Go to previous messageGo to next message
Ed Merks wrote on Fri, 24 December 2010 11:44
Hendy,
my packages?
< hxxp://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F>
How do I specify the schemaLocation for each package ?
Without any configuration : XMIResource.OPTION_SCHEMA_LOCATION=true doesn't do anything.
XMIResource.OPTION_SCHEMA_LOCATION_IMPLEMENTATION=true "works" but it's not what I want.
What I'd like to do is specify schemaLocations manually e.g.
xsi:schemaLocation="hxxp://www.soluvas.org/schema/data/1.0 ../../org.soluvas.data/src/main/resources/org/soluvas/data/data.ecore"
where "../../org.soluvas.data/src/main/resources/org/soluvas/data/data.ecore" is exactly the way I specify it (including the "../../" part).
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #1384947 is a reply to message #646472] Tue, 03 June 2014 05:13 Go to previous messageGo to next message
Spoke too soon. I found it on the link you mentioned. On DataPackageImpl.java, add:
protected Resource createResource(String uri) {
	// assume accessed from bipporeg-model
	return super.createResource("../../../org.soluvas.data/src/main/resources/org/soluvas/data/data.ecore");
Yay!
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #1384949 is a reply to message #1384947] Tue, 03 June 2014 05:23 Go to previous messageGo to next message
Hendy,
Note that in the latest release of EMF, you can specify this via an
EAnnotation on the EPackage, i.e., like this
<eAnnotations source="http://www.eclipse.org/emf/2002/Ecore">
<details key="schemaLocation"
value="http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/models/Git.ecore"/>
</eAnnotations>
It will generate the EPackage so that this publication location is used.
Furthermore, in the GenPackage, you can specify the "Publication
Location" to generate a dynamic version of the model you can publish.
> @Override
> return
It's hard to imagine how such a schema location will work nicely in
general... There's clearly some type of assumption that your data.ecore
will be in the workspace, but how that makes sense, I can't guess...
> Yay!
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #1384951 is a reply to message #1384949] Tue, 03 June 2014 05:30 Go to previous messageGo to next message
Ed Merks wrote on Tue, 03 June 2014 05:23
Hendy,
</eAnnotations>
Thank you Ed!
I think by "latest" you mean the one shipped with Eclipse 4.4, as I can't find it in the GenModel editor UI in Eclipse 4.3.2.
So for now I'll use the Java code approach. When we upgrade to 4.4 later I'll use the GenModel approach. Smile
Re: PackageNotFoundException opening XMI file without xsi:schemaLocation in EMF Editor [message #1384956 is a reply to message #1384951] Tue, 03 June 2014 05:49 Go to previous message
Hendy,
Yes in the EMF 2.10 release, which is already done, and will be part of
Luna at the end of the month.
>> Hendy,
>> </eAnnotations>
> Thank you Ed!
> later I'll use the GenModel approach. :)
Previous Topic:[CDO] Something goes wrong with the repo to corrupt it
Next Topic:How does EcoreUtil.delete() handles objects that are keys in a EMap?
Current Time: Wed Oct 01 22:54:59 EDT 2025
Powered by FUDForum. Page generated in 0.06065 seconds
