| Validating an EMF model programatically [message #628460] |
Mon, 24 May 2010 14:42 |
I was going over the EMF Validation Framework example and I was able to set everything up and add a few extra constraints. Then I run the plugin as an eclipse application, I create the model and then in the editor menu I can select validate to check the constraints and everything works fine.
But I was wondering if it is possible to validate a model programmatically, without using the editor.
// For example, create a few objects:
Book myBook = EXTLibraryFactory.eINSTANCE.createBook();
myBook.setTitle("EMF Validation");
Writer writer = EXTLibraryFactory.eINSTANCE.createWriter();
writer.setName("Hector");
//And then do the validation
I've been searching the web with no luck. Can something like this be done? I would appreciate any hints.
Thanks.
FUDForum. Page generated in 0.04558 seconds
