Home » Eclipse Projects » SWTBot » Internal Web Browser is not available when using SWTBot(Missing functionality when running SWTBot headlessly)
Internal Web Browser is not available when using SWTBot [message #559515] Thu, 16 September 2010 19:48 Go to next message
I found another problem when running SWTBot in headless mode. See the 3 Scenarios below:
Scenario 1:
SWTBot started from Eclipse testing the plug-ins in the workspace.
During the test I open the preference page: General Web Browser. The page displays the "Use internal web browser" as AVAILABLE.
Scenario 2:
SWTBot started headless with the same plug-ins as in the previous launch configuration but wrapped in an Eclipse Product.
During the test I open the preference page: General Web Browser. The page shows the "Use internal web browser" as DISABLED (greyed out).
Scenario 3:
The eclipse product in the previous scenario is opened manually and the "Use internal web browser" preference is again AVAILABLE.
The only difference between 2 and 3 is the way I start eclipse. Directly through eclipse exe or through SWTBot.
Scenario 2 has a problem it disables some functionality.
I also compared the configuration/org.eclipse.equinox.simpleconfigurator/bundles .info after the start of scenarios 2 and 3 and the loaded plug-ins are the same.
I also tried to programmatically access the Browser thinking that a plug-in is not loaded using the code:
IWorkbenchBrowserSupport browserSupport = PlatformUI.getWorkbench().getBrowserSupport();
isAvailable = browserSupport.isInternalWebBrowserAvailable();
This also tells me that the browser is not available.
Any ideas why this?
Gabriel
Re: Internal Web Browser is not available when using SWTBot [message #560204 is a reply to message #559515] Tue, 21 September 2010 10:38 Go to previous messageGo to next message
I'm unaware of how the browser loading works in eclipse.
It appears that the org.eclipse.ui.browserSupport extension is not
set/loaded/initialized correctly.
A breakpoint in WorkbenchBrowserSupport.getActiveSupport() might help
eliminating these possibilities.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
On 9/16/10 4:48 PM, Gabriel Petrovay wrote:
> Scenarios below:
> Scenario 1:
> Scenario 2:
> Scenario 3:
> I also compared the
> Any ideas why this?
> Gabriel
Re: Internal Web Browser is not available when using SWTBot [message #1123749 is a reply to message #559515] Wed, 02 October 2013 18:02 Go to previous message
On Ubuntu 13.04 using Eclipse it automagically worked, I was not sure which webkit I was missing, so I installed all that seemed relevant, if someone has pinpointed which it is, please comment,
Gabriel Medina
aptitude install libqt4-webkit libqt5webkit5 libqtscript4-webkit libqtwebkit4 libswt-webkit-gtk-3-jni libwebkitgtk-1.0-0 libwebkitgtk-3.0-0
Previous Topic:Target Platform configuration problem
Next Topic:Warnings on SWTBot tests
Current Time: Wed Oct 22 17:41:17 EDT 2025
Powered by FUDForum. Page generated in 0.05035 seconds
