Home » Modeling » EMF » [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance
[Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554467] |
Mon, 23 August 2010 05:52  |
I am doing a raw copy from one resource to my Teneo Hibernate resource.
When saving the hibernate resource, I get the exception below.
What would be the best way to (deep) copy the content of one resource so
the Hibernate resource and it's references are correctly filled?
Now I use this:
Library dbLib = Util.getDBLibrary();
if (dbLib != null) {
dbLib.getCompanies().addAll(
EcoreUtil.copyAll(srcLib.getCompanies()));
Caused by: org.hibernate.TransientObjectException: object references an
unsaved transient instance - save the transient instance before
flushing: Company
org.hibernate.engine.ForeignKeys.getEntityIdentifierIfNotUns aved(ForeignKeys.java:242)
at org.hibernate.type.EntityType.getIdentifier(EntityType.java: 430)
Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554468 is a reply to message #554467] |
Mon, 23 August 2010 06:14   |
Hi Christophe,
You have to tell Hibernate to cascade the persist operation for the reference on which it fails. Have you set one of
these options?
teneo.mapping.cascade_policy_on_containment
teneo.mapping.cascade_policy_on_non_containment
if it is a non-containment then the default is that MERGE, PERSIST and REFRESH are set. For containment the default is ALL.
In general for many-to-one associations Hibernate will work best with minimal cascade settings. This works fine in
normal production situations (for example in case a sales order references a currency then one can assume that the
currency has already been created in the database). For these large copy action though, this approach does not work well
as you are not sure about the order in which data is committed to the database.
gr. Martin
On 08/23/2010 11:52 AM, Christophe Bouhier wrote:
> Now I use this:
> dbLib.getCompanies().addAll( EcoreUtil.copyAll(srcLib.getCompanies()));
> flushing: Company
> at
> Thanks Christophe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554469 is a reply to message #554467] |
Hi Christophe,
these options?
gr. Martin
> Now I use this:
> flushing: Company
> at
> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554470 is a reply to message #554468] |
Mon, 23 August 2010 06:23   |
Thanks Martin,
see inline on some response.
Martin Taal wrote:
> Hi Christophe,
> reference on which it fails. Have you set one of these options?
No, I haven't. I actually suspect my references are not copied, as I
perform a serie of CopyAll(...) actions on various collections of my
model. The references within these collections would not be copied..
I will try with these options.
rgds Christophe
> minimal cascade settings. This works fine in normal production
> one can assume that the currency has already been created in the
> work well as you are not sure about the order in which data is committed
> to the database.
> gr. Martin
>> Now I use this:
>> flushing: Company
>> at
>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554472 is a reply to message #554470] |
Mon, 23 August 2010 06:39   |
Martin, I have the same issue, even with these options.
So it's a copy issue.
I just don't know how to copy the children of an EObject which consists
of various EList to a peer EObject while maintaining all references....
i.e.
original: Lib
- Companies
- Equipments
DB: Lib (existing)
- Companies (Copy)
- Equipments (Copy
What I do now is
dblib.getCompanies().addAll(EcoreUtil.copyAll(srcLib.getComp anies));
dblib.getEquipments().addAll(EcoreUtil.copyAll(srcLib.getEqu ipments));
So references between equipments and companies get lost it seems.
rgds Christophe
> Thanks Martin,
> Martin Taal wrote:
>> Hi Christophe,
> rgds Christophe
>> then one can assume that the currency has already been created in the
>> gr. Martin
>>> Hi,
>>> Now I use this:
>>> flushing: Company
>>> at
>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554481 is a reply to message #554472] |
Mon, 23 August 2010 07:01   |
This seems to be more a EcoreUtil question, so I hope Ed can give some good pointers.
gr. Martin
> i.e.
> original: Lib
> - Companies
> - Equipments
> DB: Lib (existing)
> - Companies (Copy)
> - Equipments (Copy
> What I do now is
> rgds Christophe
>> Thanks Martin,
>> Martin Taal wrote:
>>> Hi Christophe,
>> rgds Christophe
>>> gr. Martin
>>>> Hi,
>>>> resource so
>>>> Now I use this:
>>>> flushing: Company
>>>> at
>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554483 is a reply to message #554481] |
Mon, 23 August 2010 07:12   |
Actually, I think the options you mentioned do have some effect.
I set them like this now:
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_CONTA INMENT, "ALL");
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_NON_C ONTAINMENT,
"MERGE,PERSIST,REFRESH");
But now, I get another error:
The referred object Company#Huawei is unique, but likely referenced by
various other objects.
Caused by: org.hibernate.NonUniqueObjectException: a different object
with the same identifier value was already associated with the session:
[Company#Huawei]
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:191)
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:144)
rgds Christophe
> good pointers.
> gr. Martin
>> i.e.
>> original: Lib
>> - Companies
>> - Equipments
>> DB: Lib (existing)
>> - Companies (Copy)
>> - Equipments (Copy
>> What I do now is
>> rgds Christophe
>>> Thanks Martin,
>>> Martin Taal wrote:
>>>> Hi Christophe,
>>> rgds Christophe
>>>> gr. Martin
>>>>> Hi,
>>>>> resource.
>>>>> resource so
>>>>> Now I use this:
>>>>> references an
>>>>> flushing: Company
>>>>> at
>>>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554490 is a reply to message #554483] |
Mon, 23 August 2010 07:30   |
Yes, this is the issue you identified, one object (the Huawei company) is copied twice, so 2 instances exist for
Hibernate (with the same database id, which is not allowed).
gr. Martin
> [Company#Huawei]
> at
> at
> rgds Christophe
>> good pointers.
>> gr. Martin
>>> i.e.
>>> original: Lib
>>> - Companies
>>> - Equipments
>>> DB: Lib (existing)
>>> - Companies (Copy)
>>> - Equipments (Copy
>>> What I do now is
>>> rgds Christophe
>>>> Thanks Martin,
>>>> Martin Taal wrote:
>>>>> Hi Christophe,
>>>> rgds Christophe
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> resource.
>>>>>> resource so
>>>>>> Now I use this:
>>>>>> references an
>>>>>> flushing: Company
>>>>>> at
>>>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554511 is a reply to message #554490] |
Mon, 23 August 2010 08:34   |
> is copied twice, so 2 instances exist for Hibernate (with the same
Yes, the object indeed already existed in the DB.
I still don't understand, why I am not allowed to create another object
in the DB (Though with the same name)?
Which databse id do you refer to below? (Apologies for the wrapping).
| name | dtype | e_version | rssurl | shortname |
symbol | website | library_companies_e_id |
library_companies_idx | econtainer_class | e_container |
e_container_feature_name
| 3GPP | Company | 0 | NULL | NULL |
NULL | www.3gpp.org | 1 |
4 | Library | 1 |
http://www.netxforge.com/15072010/netxstudio_;_Library_;_http://www.netxforge.com/15072010/netxstudio_;_Library_;_companies
| Cisco | Company | 0 | NULL | NULL |
NULL | www.cisco.com | 1 |
3 | Library | 1 |
| Huawei | Company | 0 | NULL | NULL |
NULL | www.huawei.com | 1 |
0 | Library | 1 |
| Nokia Siemens Networks | Company | 0 | NULL | NULL |
NULL | www.nsn.com | 1 |
1 | Library | 1 |
| Tekelec | Company | 0 | NULL | NULL |
NULL | www.tekelec.com | 1 |
2 | Library | 1 |
> gr. Martin
>> "ALL");
>> [Company#Huawei]
>> at
>> at
>> rgds Christophe
>>> good pointers.
>>> gr. Martin
>>>> i.e.
>>>> original: Lib
>>>> - Companies
>>>> - Equipments
>>>> DB: Lib (existing)
>>>> - Companies (Copy)
>>>> - Equipments (Copy
>>>> What I do now is
>>>> rgds Christophe
>>>>> Thanks Martin,
>>>>> Martin Taal wrote:
>>>>>> Hi Christophe,
>>>>> rgds Christophe
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> resource.
>>>>>>> resource so
>>>>>>> Now I use this:
>>>>>>> references an
>>>>>>> flushing: Company
>>>>>>> at
>>>>>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554512 is a reply to message #554511] |
Mon, 23 August 2010 08:43   |
Hi Christophe,
I understand that you execute these lines:
The first line will copy the companies, as there are references from equipments to companies, the second line will again
copy the referenced companies. So one company will then be copied twice (and exist twice in memory), when you then
persist the two sets (companies and equipments), these 2 instances are persisted by Hibernate resulting in the error.
This because Hibernate only allows one instance for a record to be present in one session.
At least this is what I understand from this situation.
gr. Martin
> | name | dtype | e_version | rssurl | shortname | symbol | website |
> library_companies_e_id | library_companies_idx | econtainer_class |
> e_container | e_container_feature_name |
> | 3GPP | Company | 0 | NULL | NULL | NULL | www.3gpp.org | 1 | 4 |
> Library | 1 |
> | Cisco | Company | 0 | NULL | NULL | NULL | www.cisco.com | 1 | 3 |
> Library | 1 |
> | Huawei | Company | 0 | NULL | NULL | NULL | www.huawei.com | 1 | 0 |
> Library | 1 |
> | Nokia Siemens Networks | Company | 0 | NULL | NULL | NULL |
> www.nsn.com | 1 | 1 | Library | 1 |
> | Tekelec | Company | 0 | NULL | NULL | NULL | www.tekelec.com | 1 | 2 |
> Library | 1 |
>> gr. Martin
>>> "ALL");
>>> [Company#Huawei]
>>> at
>>> at
>>> rgds Christophe
>>>> good pointers.
>>>> gr. Martin
>>>>> consists
>>>>> references....
>>>>> i.e.
>>>>> original: Lib
>>>>> - Companies
>>>>> - Equipments
>>>>> DB: Lib (existing)
>>>>> - Companies (Copy)
>>>>> - Equipments (Copy
>>>>> What I do now is
>>>>> rgds Christophe
>>>>>> Thanks Martin,
>>>>>> Martin Taal wrote:
>>>>>>> Hi Christophe,
>>>>>> rgds Christophe
>>>>>>> with
>>>>>>> the
>>>>>>> not
>>>>>>> gr. Martin
>>>>>>>> Hi,
>>>>>>>> resource.
>>>>>>>> resource so
>>>>>>>> Now I use this:
>>>>>>>> references an
>>>>>>>> flushing: Company
>>>>>>>> at
>>>>>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554513 is a reply to message #554512] |
Mon, 23 August 2010 08:54   |
Martin Taal wrote:
> Hi Christophe,
> equipments to companies, the second line will again copy the referenced
> memory), when you then persist the two sets (companies and equipments),
Ahah... so it seems copyReferences in EcoreUtil, actually also creates a
copy of the referenced non-containment object. mmmh, that's not what I
want. I expected only the reference like below the BodyRef would be copied:
<Elements BodyRef="#Huawei" etc.....
rgds Christophe
> gr. Martin
>> Library | 1 |
>> Library | 1 |
>> Library | 1 |
>> Library | 1 |
>>> gr. Martin
>>>> "ALL");
>>>> [Company#Huawei]
>>>> at
>>>> at
>>>> rgds Christophe
>>>>> good pointers.
>>>>> gr. Martin
>>>>>> consists
>>>>>> references....
>>>>>> i.e.
>>>>>> original: Lib
>>>>>> - Companies
>>>>>> - Equipments
>>>>>> DB: Lib (existing)
>>>>>> - Companies (Copy)
>>>>>> - Equipments (Copy
>>>>>> What I do now is
>>>>>> rgds Christophe
>>>>>>> Thanks Martin,
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Christophe,
>>>>>>> rgds Christophe
>>>>>>>> with
>>>>>>>> the
>>>>>>>> not
>>>>>>>> gr. Martin
>>>>>>>>> Hi,
>>>>>>>>> resource.
>>>>>>>>> resource so
>>>>>>>>> Now I use this:
>>>>>>>>> references an
>>>>>>>>> flushing: Company
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554528 is a reply to message #554513] |
Mon, 23 August 2010 09:40   |
Hi Christophe,
It depends if the reference is a containment or not (the first should be copied, the second not). Is it a containment
association (the naming suggests no)?
gr. Martin
On 08/23/2010 02:54 PM, Christophe Bouhier wrote:
> Martin Taal wrote:
>> Hi Christophe,
>> exist twice in memory), when you then persist the two sets (companies
>> resulting in the error. This because Hibernate only allows one
> rgds Christophe
>> gr. Martin
>>> Library | 1 |
>>> Library | 1 |
>>> Library | 1 |
>>> Library | 1 |
>>>> gr. Martin
>>>>> "ALL");
>>>>> session:
>>>>> [Company#Huawei]
>>>>> at
>>>>> at
>>>>> rgds Christophe
>>>>>> some
>>>>>> good pointers.
>>>>>> gr. Martin
>>>>>>> consists
>>>>>>> references....
>>>>>>> i.e.
>>>>>>> original: Lib
>>>>>>> - Companies
>>>>>>> - Equipments
>>>>>>> DB: Lib (existing)
>>>>>>> - Companies (Copy)
>>>>>>> - Equipments (Copy
>>>>>>> What I do now is
>>>>>>> rgds Christophe
>>>>>>>> Thanks Martin,
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi Christophe,
>>>>>>>>> the
>>>>>>>> as I
>>>>>>>> of my
>>>>>>>> copied..
>>>>>>>> rgds Christophe
>>>>>>>>> with
>>>>>>>>> currency
>>>>>>>>> the
>>>>>>>>> not
>>>>>>>>> gr. Martin
>>>>>>>>>> Hi,
>>>>>>>>>> resource.
>>>>>>>>>> resource so
>>>>>>>>>> Now I use this:
>>>>>>>>>> references an
>>>>>>>>>> flushing: Company
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554548 is a reply to message #554528] |
Mon, 23 August 2010 10:02   |
Martin Taal wrote:
> Hi Christophe,
> copied, the second not). Is it a containment association (the naming
> suggests no)?
No, it's a non-containment.
> gr. Martin
>> Martin Taal wrote:
>>> Hi Christophe,
>> copied:
>> rgds Christophe
>>> gr. Martin
>>>> Library | 1 |
>>>> Library | 1 |
>>>> Library | 1 |
>>>> 2 |
>>>> Library | 1 |
>>>>> gr. Martin
>>>>>> "ALL");
>>>>>> referenced by
>>>>>> session:
>>>>>> [Company#Huawei]
>>>>>> at
>>>>>> at
>>>>>> rgds Christophe
>>>>>>> some
>>>>>>> good pointers.
>>>>>>> gr. Martin
>>>>>>>> consists
>>>>>>>> references....
>>>>>>>> i.e.
>>>>>>>> original: Lib
>>>>>>>> - Companies
>>>>>>>> - Equipments
>>>>>>>> DB: Lib (existing)
>>>>>>>> - Companies (Copy)
>>>>>>>> - Equipments (Copy
>>>>>>>> What I do now is
>>>>>>>> rgds Christophe
>>>>>>>>> Thanks Martin,
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi Christophe,
>>>>>>>>>> the
>>>>>>>>> as I
>>>>>>>>> of my
>>>>>>>>> copied..
>>>>>>>>> rgds Christophe
>>>>>>>>>> PERSIST
>>>>>>>>>> with
>>>>>>>>>> currency
>>>>>>>>>> the
>>>>>>>>>> not
>>>>>>>>>> gr. Martin
>>>>>>>>>>> Hi,
>>>>>>>>>>> resource.
>>>>>>>>>>> resource so
>>>>>>>>>>> Now I use this:
>>>>>>>>>>> references an
>>>>>>>>>>> flushing: Company
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554567 is a reply to message #554548] |
Mon, 23 August 2010 10:20   |
Is the dbid stored in the object using an efeature?
gr. Martin
On 08/23/2010 04:02 PM, Christophe Bouhier wrote:
> Martin Taal wrote:
>> Hi Christophe,
>> be copied, the second not). Is it a containment association (the
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Christophe,
>>> copied:
>>> rgds Christophe
>>>> gr. Martin
>>>>>> company)
>>>>> object
>>>>> Library | 1 |
>>>>> Library | 1 |
>>>>> Library | 1 |
>>>>> | 2 |
>>>>> Library | 1 |
>>>>>> gr. Martin
>>>>>>> "ALL");
>>>>>>> referenced by
>>>>>>> object
>>>>>>> session:
>>>>>>> [Company#Huawei]
>>>>>>> at
>>>>>>> at
>>>>>>> rgds Christophe
>>>>>>>> some
>>>>>>>> good pointers.
>>>>>>>> gr. Martin
>>>>>>>>> consists
>>>>>>>>> references....
>>>>>>>>> i.e.
>>>>>>>>> original: Lib
>>>>>>>>> - Companies
>>>>>>>>> - Equipments
>>>>>>>>> DB: Lib (existing)
>>>>>>>>> - Companies (Copy)
>>>>>>>>> - Equipments (Copy
>>>>>>>>> What I do now is
>>>>>>>>> rgds Christophe
>>>>>>>>>> Thanks Martin,
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>> the
>>>>>>>>>> as I
>>>>>>>>>> of my
>>>>>>>>>> copied..
>>>>>>>>>> rgds Christophe
>>>>>>>>>>> PERSIST
>>>>>>>>>>> with
>>>>>>>>>>> currency
>>>>>>>>>>> created in
>>>>>>>>>>> the
>>>>>>>>>>> does
>>>>>>>>>>> not
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> resource.
>>>>>>>>>>>> resource so
>>>>>>>>>>>> filled?
>>>>>>>>>>>> Now I use this:
>>>>>>>>>>>> references an
>>>>>>>>>>>> flushing: Company
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554568 is a reply to message #554567] |
Mon, 23 August 2010 10:39   |
Sorry, dbid in the object?
> gr. Martin
>> Martin Taal wrote:
>>> Hi Christophe,
>>> gr. Martin
>>>> Martin Taal wrote:
>>>>> Hi Christophe,
>>>> creates a
>>>> copied:
>>>> rgds Christophe
>>>>> gr. Martin
>>>>>>> company)
>>>>>> object
>>>>>> Library | 1 |
>>>>>> Library | 1 |
>>>>>> 0 |
>>>>>> Library | 1 |
>>>>>> | 2 |
>>>>>> Library | 1 |
>>>>>>> gr. Martin
>>>>>>>> "ALL");
>>>>>>>> referenced by
>>>>>>>> object
>>>>>>>> session:
>>>>>>>> [Company#Huawei]
>>>>>>>> at
>>>>>>>> at
>>>>>>>> rgds Christophe
>>>>>>>>> some
>>>>>>>>> good pointers.
>>>>>>>>> gr. Martin
>>>>>>>>>> consists
>>>>>>>>>> references....
>>>>>>>>>> i.e.
>>>>>>>>>> original: Lib
>>>>>>>>>> - Companies
>>>>>>>>>> - Equipments
>>>>>>>>>> DB: Lib (existing)
>>>>>>>>>> - Companies (Copy)
>>>>>>>>>> - Equipments (Copy
>>>>>>>>>> What I do now is
>>>>>>>>>> rgds Christophe
>>>>>>>>>>> Thanks Martin,
>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>> the
>>>>>>>>>>> as I
>>>>>>>>>>> of my
>>>>>>>>>>> copied..
>>>>>>>>>>> rgds Christophe
>>>>>>>>>>>> PERSIST
>>>>>>>>>>>> best
>>>>>>>>>>>> with
>>>>>>>>>>>> currency
>>>>>>>>>>>> created in
>>>>>>>>>>>> the
>>>>>>>>>>>> does
>>>>>>>>>>>> not
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> resource.
>>>>>>>>>>>>> resource so
>>>>>>>>>>>>> filled?
>>>>>>>>>>>>> Now I use this:
>>>>>>>>>>>>> references an
>>>>>>>>>>>>> before
>>>>>>>>>>>>> flushing: Company
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> Thanks Christophe
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #554569 is a reply to message #554568] |
Mon, 23 August 2010 10:43   |
Yes, if the dbid is an efeature then after copying, a second instance, with the same dbid, exists in-memory. So when
copying you have to clear the dbid so that Hibernate knows it is a new object.
gr. Martin
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Christophe,
>>>> gr. Martin
>>>>> Martin Taal wrote:
>>>>>> Hi Christophe,
>>>>> creates a
>>>>> copied:
>>>>> rgds Christophe
>>>>>> gr. Martin
>>>>>>>> company)
>>>>>>> object
>>>>>>> wrapping).
>>>>>>> Library | 1 |
>>>>>>> Library | 1 |
>>>>>>> | 0 |
>>>>>>> Library | 1 |
>>>>>>> | 2 |
>>>>>>> Library | 1 |
>>>>>>>> gr. Martin
>>>>>>>>> "ALL");
>>>>>>>>> referenced by
>>>>>>>>> object
>>>>>>>>> session:
>>>>>>>>> [Company#Huawei]
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> rgds Christophe
>>>>>>>>>> some
>>>>>>>>>> good pointers.
>>>>>>>>>> gr. Martin
>>>>>>>>>>> consists
>>>>>>>>>>> references....
>>>>>>>>>>> i.e.
>>>>>>>>>>> original: Lib
>>>>>>>>>>> - Companies
>>>>>>>>>>> - Equipments
>>>>>>>>>>> DB: Lib (existing)
>>>>>>>>>>> - Companies (Copy)
>>>>>>>>>>> - Equipments (Copy
>>>>>>>>>>> What I do now is
>>>>>>>>>>> seems.
>>>>>>>>>>> rgds Christophe
>>>>>>>>>>>> Thanks Martin,
>>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>> for
>>>>>>>>>>>>> the
>>>>>>>>>>>>> options?
>>>>>>>>>>>> as I
>>>>>>>>>>>> of my
>>>>>>>>>>>> copied..
>>>>>>>>>>>> rgds Christophe
>>>>>>>>>>>>> PERSIST
>>>>>>>>>>>>> best
>>>>>>>>>>>>> with
>>>>>>>>>>>>> currency
>>>>>>>>>>>>> created in
>>>>>>>>>>>>> the
>>>>>>>>>>>>> does
>>>>>>>>>>>>> not
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> resource.
>>>>>>>>>>>>>> below.
>>>>>>>>>>>>>> resource so
>>>>>>>>>>>>>> filled?
>>>>>>>>>>>>>> Now I use this:
>>>>>>>>>>>>>> references an
>>>>>>>>>>>>>> before
>>>>>>>>>>>>>> flushing: Company
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [Teneo] org.hibernate.TransientObjectException: object references an unsaved transient instance [message #555191 is a reply to message #554569] |
Wed, 25 August 2010 14:38  |
> with the same dbid, exists in-memory. So when copying you have to clear
Hi Martin,
I gave up on this for now, I just don't understand why copying objects
from A to B should be such hassle...I don't really need duplicates, but
it seems these are created with ECoreUtil.copy...It's not my intention
to clear what I didn't want in the first place.
Thanks for your help anyways!
rgds Christophe
> gr. Martin
>>> gr. Martin
>>>> Martin Taal wrote:
>>>>> Hi Christophe,
>>>>> gr. Martin
>>>>>> Martin Taal wrote:
>>>>>>> Hi Christophe,
>>>>>>> (companies
>>>>>> creates a
>>>>>> what I
>>>>>> copied:
>>>>>> rgds Christophe
>>>>>>> gr. Martin
>>>>>>>>> company)
>>>>>>>> object
>>>>>>>> wrapping).
>>>>>>>> website |
>>>>>>>> Library | 1 |
>>>>>>>> 3 |
>>>>>>>> Library | 1 |
>>>>>>>> | 0 |
>>>>>>>> Library | 1 |
>>>>>>>> | 2 |
>>>>>>>> Library | 1 |
>>>>>>>>> gr. Martin
>>>>>>>>>> "ALL");
>>>>>>>>>> referenced by
>>>>>>>>>> object
>>>>>>>>>> session:
>>>>>>>>>> [Company#Huawei]
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> rgds Christophe
>>>>>>>>>>> give
>>>>>>>>>>> some
>>>>>>>>>>> good pointers.
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> consists
>>>>>>>>>>>> references....
>>>>>>>>>>>> i.e.
>>>>>>>>>>>> original: Lib
>>>>>>>>>>>> - Companies
>>>>>>>>>>>> - Equipments
>>>>>>>>>>>> DB: Lib (existing)
>>>>>>>>>>>> - Companies (Copy)
>>>>>>>>>>>> - Equipments (Copy
>>>>>>>>>>>> What I do now is
>>>>>>>>>>>> seems.
>>>>>>>>>>>> rgds Christophe
>>>>>>>>>>>>> Thanks Martin,
>>>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>> for
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> options?
>>>>>>>>>>>>> copied,
>>>>>>>>>>>>> as I
>>>>>>>>>>>>> of my
>>>>>>>>>>>>> copied..
>>>>>>>>>>>>> rgds Christophe
>>>>>>>>>>>>>> PERSIST
>>>>>>>>>>>>>> best
>>>>>>>>>>>>>> with
>>>>>>>>>>>>>> production
>>>>>>>>>>>>>> currency
>>>>>>>>>>>>>> created in
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> does
>>>>>>>>>>>>>> not
>>>>>>>>>>>>>> data is
>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> Hibernate
>>>>>>>>>>>>>>> resource.
>>>>>>>>>>>>>>> below.
>>>>>>>>>>>>>>> resource so
>>>>>>>>>>>>>>> filled?
>>>>>>>>>>>>>>> Now I use this:
>>>>>>>>>>>>>>> references an
>>>>>>>>>>>>>>> before
>>>>>>>>>>>>>>> flushing: Company
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> Thanks Christophe
Current Time: Fri Aug 29 10:17:36 EDT 2025
Powered by FUDForum. Page generated in 0.11200 seconds
