Home » Eclipse Projects » Rich Client Platform (RCP) » Remove search and Run menu for menu bar
Remove search and Run menu for menu bar [message #552138] Wed, 11 August 2010 00:25 Go to next message
HI,
Run and search menu is included automatically to my main menu.
when i have not set any thing to include it.
can any one tell how to remove it...
ashok
Re: Remove search and Run menu for menu bar [message #553166 is a reply to message #552138] Mon, 16 August 2010 11:16 Go to previous messageGo to next message
Which plugins are you including in your RCP app that is adding them?
org.eclipse.debug.ui? org.eclipse.search?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Remove search and Run menu for menu bar [message #554206 is a reply to message #553166] Fri, 20 August 2010 10:03 Go to previous messageGo to next message
I have the same problem. My run configuration has neither org.eclipse.debug.ui nor org.eclipse.search in it but the menus Run and Search are there.
Re: Remove search and Run menu for menu bar [message #554776 is a reply to message #552138] Tue, 24 August 2010 07:56 Go to previous messageGo to next message
even i have not included these plugin can any one tell how to remove them.
Re: Remove search and Run menu for menu bar [message #554833 is a reply to message #554776] Tue, 24 August 2010 09:50 Go to previous messageGo to next message
Someone has answered this in the forum but the topoc has been removed. Here is the answer(not mine) via Google Cache:
when you use the plug-in for ide and others (I am not sure)... this will add the menus and tool buttons provided by those plug-in...
you can remove the unwanted menus from your application as shown below...
class ApplicationWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor
void postWindowCreate()
IContributionItem[] mItems, mSubItems;
IMenuManager mm = getWindowConfigurer ().getActionBarConfigurer ().getMenuManager ();
mItems = mm.getItems ();
for (int i = 0; i < mItems.length; i++)
if (mItems[i] instanceof MenuManager)
mSubItems = ((MenuManager) mItems[i]).getItems ();
for (int j = 0; j < mSubItems.length; j++)
if (mItems[i].getId ().equals ("file"))
((MenuManager) mItems[i]).remove ("org.eclipse.ui.openLocalFile");
else if (mItems[i].getId ().equals ("help"))
((MenuManager) mItems[i]).remove ("group.updates");
((MenuManager) mItems[i]).remove ("org.eclipse.update.ui.updateMenu");
((MenuManager) mItems[i]).remove ("org.eclipse.ui.actions.showKeyAssistHandler");
All the Best!
S.Prabhu
Re: Remove search and Run menu for menu bar [message #554937 is a reply to message #554833] Tue, 24 August 2010 15:50 Go to previous messageGo to next message
I tried the following code and it removed single entries from the menus but not the menus itself (like the Run or Search menu).
    public void postWindowCreate() {
        // remove unwanted menu entries
	List<String> unwantedItems = Arrays.asList(
		"org.eclipse.ui.openLocalFile",
		"converstLineDelimitersTo",
		"org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction",
		"org.eclipse.debug.ui.actions.BreakpointTypesContribution" ,
		"ExternalToolsGroup" ,
		"org.eclipse.ui.externaltools.ExternalToolMenuDelegateMenu" ,
		"navigate" ,
		"org.eclipse.search.menu",
		"org.eclipse.ui.run"
        IMenuManager menuManager = getWindowConfigurer().getActionBarConfigurer().getMenuManager();
        removeUnwantedItems(unwantedItems, menuManager);
    private void removeUnwantedItems(final List<String> unwantedItems, final IMenuManager menuManager) {
	IContributionItem[] items = menuManager.getItems();
	for (IContributionItem item : items) {
	    if (item instanceof IMenuManager) {
		removeUnwantedItems(unwantedItems, (IMenuManager) item);
	    if (unwantedItems.contains(item.getId())) {
		menuManager.remove(item);
Any ideas why Run and Search are not removed?
Re: Remove search and Run menu for menu bar [message #555098 is a reply to message #554833] Wed, 25 August 2010 08:46 Go to previous message
eshvar60 wrote:
Just a note. This kind of down-casting classifies as using internals.
There is not programmatic access to the WorkbenchWindow MenuManager,
except for during the WW creation when the ActionBarAdvisor gets to fill
it in.
It is 100% incompatible with the e4 initiative and eclipse 4.0 as the
MenuManager has been replaced.
PW
Paul Webster
Previous Topic:3.3 org.eclipse.ide Is it safe to use in RCP?
Next Topic:Remembering the last directory from which a user opened a file
Current Time: Tue Nov 04 04:35:00 EST 2025
Powered by FUDForum. Page generated in 0.06821 seconds
