Home » Modeling » EMF » Re: In my model, Class not found or is abstract
Re: In my model, Class not found or is abstract [message #540814] Thu, 17 June 2010 08:33 Go to next message
--------------000605090900040001000302
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Maxime,
If I understand correctly, this is more of an EMF question than it is an
M2T question, I added the emf newsgroup to the to: list of this answer.
Laurent Goubet
Obeo
Maxime Lecourt wrote:
> I made a metamodel, where Items is my container EClass.
> part of the metamodel :
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="hla"
> nsURI="http://hla/1.0" nsPrefix="hla">
> <eClassifiers xsi:type="ecore:EClass" name="Items">
> <eStructuralFeatures xsi:type="ecore:EReference" name="entities"
> upperBound="-1"
> eType="#//HEntity" derived="true" containment="true"/>
> </eClassifiers>
> So after that I wanted to define a model
> <hla:Items xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:metamodel="http://www.example.org/metamodel"
> xsi:schemaLocation="http://www.example.org/metamodel metamodel/hla.ecore">
> </hla:Items>
> But I get "Class 'Items' is not found or is abstract". The most
> surprising is that it worked for a while.
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000605090900040001000302--
Re: In my model, Class not found or is abstract [message #540853 is a reply to message #540814] Thu, 17 June 2010 09:45 Go to previous messageGo to next message
I see the package's nsURI is "http://hla/1.0" but I don't see an xmlns
declaration for that (so the XML looks invalid) nor any other use of the
package's namespace (so the instance doesn't conform to the model).
Laurent Goubet wrote:
> Hi Maxime,
> an M2T question, I added the emf newsgroup to the to: list of this
> answer.
> Laurent Goubet
> Obeo
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> </eClassifiers>
>> </hla:Items>
Re: In my model, Class not found or is abstract [message #540876 is a reply to message #540814] Thu, 17 June 2010 10:22 Go to previous messageGo to next message
I didn't find any tutorial or documentation regarding how to define a model (didn't know what to search for), do you know where I could find some ?
Until now I've been going by trial and error Embarrassed
Re: In my model, Class not found or is abstract [message #540952 is a reply to message #540876] Thu, 17 June 2010 13:59 Go to previous messageGo to next message
Maxime,
There's the EMF book. Other than that, you'll have to make due with
what's on the EMF documentation page.
> some ?
> Until now I've been going by trial and error :blush:
Re: In my model, Class not found or is abstract [message #541086 is a reply to message #540814] Fri, 18 June 2010 05:45 Go to previous messageGo to next message
From the EMF documentation, there is a tutorial, that would generate a .genmodel file, java files, and finally a library file.
Isn't there a way to generate an empty model file directly from an ecore metamodel, that I can fill with my instances ?
The EMF 2003 book seem's JAVA oriented mostly, there are examples about how to generate JAVA code, it states you can use a XMI serializer, but not how to use it.
Re: In my model, Class not found or is abstract [message #541179 is a reply to message #541086] Fri, 18 June 2010 10:31 Go to previous message
Maxime,
From the context menu of an EClass you can invoke Create Dynamic
Instance... Both versions of the book talk about the resource framework
and how to use it; the 2nd edition has twice as much content and hence a
lot more detail.
Previous Topic:DOM like fallback
Next Topic:Ecore as its own metamodel
Current Time: Thu Jul 24 21:16:03 EDT 2025
Powered by FUDForum. Page generated in 1.09456 seconds
