Home » Eclipse Projects » Subversive » Pseudo conflicts shown when off?
Pseudo conflicts shown when off? [message #537455] Wed, 02 June 2010 10:02 Go to next message
In preferences / Compare/Patch I have set Show Pseudo Conflicts to off, but it seems I stil see them.
Also the last quote in some lines is colored as changed, when it is not.
See picture:
http://img17.imageshack.us/img17/7389/pseudodiff.th.png
Versions:
- Eclipse Java EE 3.5.2 - Build id: 20100218-1602
- Subversive SVN Team Provider (Incubation) 0.7.9.I20100512-1900 org.eclipse.team.svn.feature.group
Re: Pseudo conflicts shown when off? [message #537932 is a reply to message #537455] Fri, 04 June 2010 03:52 Go to previous messageGo to next message
Hello David,
It's hard to say from screenshot whether you have pseudo conflict or
not. For testing, I created a very simple pseudo conflict and when I
called compare it showed correctly with enabled and disabled option.
It's better to consult Compare framework team if you are sure that you
have pseudo conflict but it's not correctly shown.
> See picture:
> http://img17.imageshack.us/i/pseudodiff.png/
> Versions:
Igor Burilo
Re: Pseudo conflicts shown when off? [message #537939 is a reply to message #537455] Fri, 04 June 2010 05:14 Go to previous messageGo to next message
Well I just learned from the Help file what a pseudo conflict is.
A s I understand it, if my change and the change in SVN is identical, that is a pseudo conflict.
On the screenshot, the first line colored red (line 309) is the same on both sides, so that is a pseudo conflict, right?
Also line 310 is the same, but now the quote is highlighted , but again same on left and right.
I'll try to contact the Compare team too.
Re: Pseudo conflicts shown when off? [message #538286 is a reply to message #537939] Mon, 07 June 2010 04:35 Go to previous messageGo to next message
Hello David,
I think it's better to ask about this in Compare team and if Subversive
does something wrong please provide details.
Igor Burilo
Re: Pseudo conflicts shown when off? [message #540338 is a reply to message #538286] Tue, 15 June 2010 13:39 Go to previous messageGo to next message
I posted here <http://www.eclipse.org/forums/index.php?t=msg&th=169417> but there doesn't seem to be any traffic in that group.
Is there another, better channel to Compare Team?
David
Re: Pseudo conflicts shown when off? [message #540716 is a reply to message #540338] Thu, 17 June 2010 03:43 Go to previous message
Hello David,
I suppose that Compare component belongs to Platform, please try:
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 11&
> David
Igor Burilo
Previous Topic:revision numbers after branching
Next Topic:Discover WC status
Current Time: Sat Jul 12 11:37:16 EDT 2025
Powered by FUDForum. Page generated in 0.04390 seconds
