Home » Language IDEs » Java Development Tools (JDT) » -Xmx
-Xmx [message #521969] Fri, 19 March 2010 09:51 Go to next message
I'm working on some shortest path algorithms, and I was implementing Floyd-Warshalls algorithm. My system used 1024MB of RAM, which wasn't enough to initialise the large 2D matrix, so eclipse ran out of heap size.
I upgraded my core 2 duo imac from 2x512MB RAM to 1GB RAM + 2GB RAM. The system recognizes the new 3GB RAM on Mac OSX and on my bootcamp booted windows partition.
I use eclipse and had the VM arguments on -Xmx1024M and tried switching it to -Xmx2G. This gives this error:
"Error occurred during initialization of VM
Could not reserve enough space for object heap"
I tried gradually decreasing the amount of used memory, every time getting the same error. The highest amount of RAM I could use is -Xmx1600M. Which still isn't enough to run the program without running out of heap size.
Why can't I use the full amount of memory? (well not the full 3GB ofcourse, but at least I would like to be able to use 2GB to 2,5GB)
Re: -Xmx [message #521979 is a reply to message #521969] Fri, 19 March 2010 10:23 Go to previous message
There're many restrictions to memory allocation. The operating system use part of it. Eclipse also will use another part. Other applications running, will also take more memory.
I found this two pages about memory allocation, I don't know if they'll be useful to you but here they are:
http://javahowto.blogspot.com/2006/06/6-common-errors-in-set ting-java-heap.html
http://publib.boulder.ibm.com/infocenter/iseries/v5r4/index. jsp?topic=/rzatz/51/admin/prftunejmem.htm
Try checking how much free memory you have. Normally a windows machine running eclipse will take almost 1GB or more, depending on how much applications you have installed.
Also, from what I understand, when you run an application from within Eclipse, it starts a new process, new JVM. You didn't specify if you placed the argument when starting your app or Eclipse, but the right thing to do is to put the arguments in the Run directive you're using.
I hope it helps.
Regards.
Previous Topic:Building jars headless
Next Topic:How to limit the depth of .project file searching when importing projects
Current Time: Tue Oct 21 19:55:19 EDT 2025
Powered by FUDForum. Page generated in 0.04265 seconds
