Home » Modeling » Epsilon » Eugenia: Starters/ideas to automate GMF generation?
Eugenia: Starters/ideas to automate GMF generation? [message #501713] Thu, 03 December 2009 10:07 Go to next message
Hey guys,
I'm getting kind of tired of repeatedly going through a whole list of steps to regenerate my GMF editor everytime I make a change to the EMF (generate ecore, reload genmodel, sync genmodel, generate code, generate edit, generate editor,... you get the idea). Not only is it a bit cumbersome (OK, nothing compared to the time savings through Eugenia) but often I forget a step (e.g. an EOL sync) and have to figure out what screwed up my editor.
I was thinking about a way to automate this. In a bug report I read something about Ant tasks for Eugenia but couldn't make much sense of it. While Ant tasks might work for the Eugenia steps, I would still have to automate the genmodel and gmf steps, like reloading the genmodel, generating the gmfgen, and the GMF diagram plug-in. The main problem I see with automating these steps is that they are dialog-based so I probably can't just call some GMF function.
I'm not expecting a full solution but lacking in-depth Eclipse knowledge, could someone give me a starter (which Eclipse mechanism to use, where to look up information, etc.) of how to automate all these non-dialog and dialog-based steps?
If I get it working, I will make the code available for possible integration into Eugenia.
Thanks a lot, Christoph
Re: Eugenia: Starters/ideas to automate GMF generation? [message #501742 is a reply to message #501713] Thu, 03 December 2009 11:23 Go to previous messageGo to next message
Hi Christoph,
When developing Eugenia, we too wanted to make it work in one step
(right click .ecore -> generate everything) but couldn't figure out how
to do this. If memory serves, automating the EMF bits was possible (i.e.
reloading .genmodel and generating the EMF code) but for GMF there was
no visible API for automating the gmfmap->gmfgen and gmfgen->code steps.
Could you possibly post a question in the GMF newsgroup and see if
someone comes up with any ideas on how to do this?
Dimitris
Christoph Wienands wrote:
> Hey guys,
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Eugenia: Starters/ideas to automate GMF generation? [message #501825 is a reply to message #501742] Thu, 03 December 2009 18:07 Go to previous messageGo to next message
Originally posted by: nyoescape.gmail.com
--------------080208040805090908080404
Content-Type: text/plain; charset=UTF-8
Hi all,
Actually, I went through this last summer, but I've been too busy with
other things to actually post about it. BTW, there seems to be an
official GMF Ant task in the works for this sort of things. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282331
Anyway, I cooked up two tasks to convert an Emfatic description into its
..ecore file, and to produce the .gmfgen model from the .gmftool,
..gmfgraph and .gmfmap models. I just poked around the code and took what
I needed to produce the models. I've attached a ZIP file with a plugin
project you can try out. Comments are welcome :-).
If you need the .gmfgen -> code part, you can use the GMF Ant tasks made
by Ecliptical Software, which I believe to be under the EPL. Here's the
update site:
http://www.eclipticalsoftware.com/updates/site.xml
I've also attached a simplified version of Ant buildfile I use to
generate my code from scratch. The full version munges a bit the Emfatic
textual description using some Ant filters. It's still a bit rough
around the edges, but basically, you could add it to your Eclipse
project like this:
- Add the generate-code.xml Ant script as a custom Ant builder, using
the "default" target (which ends up generating the GMF code). This
way, every time you build the project, everything will be cleaned up
and regenerated from scratch.
- Customize the variables in the "Basic project info" section to
the values you like.
- Add these files to the model/ directory in your project:
* yourmodel.emf (Emfatic textual description)
* Optionally, model/ECore2GMF.eol (same as that used in EuGENia)
* Optionally, model/FixGenModel.eol (same as that used in EuGENia)
* Optionally, model/FixGMFGen.eol (same as that used in EuGENia)
* Optionally, model/copyright.txt (copyright info, like in EuGENia)
- Optionally, you can add dynamic templates to touch up some of the
code that is generated during the GMF*->GMFGen transformation to
the templates-gmfgraph/ directory in your project. BTW, I found it
a bit confusing that some code gets generated even before the
final GMFGen->code step, but that's how it is.
- If you want to use dynamic templates for the GMFGen->code
transformation, you'll need to tweak your FixGMFGen.eol script. If
you want, I can send you a sample.
The Ant buildfile basically does this, in sequence:
- refreshes all the files under the project, if inside Eclipse (I have
the bad habit of poking around with Eclipse, Emacs and/or Git at the
same time :-D)
- produces the ECore model from the Emfatic description, and
registers it (useful for the following EOL invocations)
- generates and fixes the EMF .genmodel with EuGENia's built-in EOL
script and our own (if existing)
- generates the code for the EMF model, edit, editor and test plugins
- generates and fixes the GMF files, like before
- generates and fixes the GMFGen model
- produces the GMF code
Again, it's still a bit rough around the edges, but I'd love to hear any
comments you might have on it. Perhaps I should make this into a blog
post somewhere :-D.
Antonio
Content-Type: application/zip;
name="ant-tasks.zip"
Content-Disposition: inline;
filename="ant-tasks.zip"
UEsDBAoAAAAAAAa8gzsAAAAAAAAAAAAAAAAUAAAAZXMudWNhLm1vZGVsaW5n LmFudC9QSwME
CgAAAAgABryDO/Pcq4jNAAAAbwEAAB4AAABlcy51Y2EubW9kZWxpbmcuYW50 Ly5jbGFzc3Bh
dGiVkMFKAzEQhs/2KZbcO2sLgofdFpEVWrCWduu1pMmwHY2TOEmKfXtdsFQE hd7mH775+Jlq
+vHmigNKJM+1GsG1KpCNt8RdrTbtw/BWTSeDyjgdY9BpPxlcnQNykmPxSmxr ZTyrol/WyksH
aByFiPBiEzid2ey/jDBfNdv7p0V7N1s0q/I3R5xQWDuwuMsdZPq+RIF10my1 2OfH9hiwnI/X
zXAEN6q8tE+wCMYLguB7JkG7dLkjjv+YopiTqR//Bn1OIacTuyPu2ar88btP UEsDBAoAAAAA
AAa8gzsAAAAAAAAAAAAAAAAqAAAAZXMudWNhLm1vZGVsaW5nLmFudC8uZXh0 ZXJuYWxUb29s
QnVpbGRlcnMvUEsDBAoAAAAIAAa8gztr//yF0QEAACAFAAA6AAAAZXMudWNh Lm1vZGVsaW5n
LmFudC8uZXh0ZXJuYWxUb29sQnVpbGRlcnMvQnVpbGQgSmFyLmxhdW5jaKWU QW+bMBiG7/0V
CO3YwnrboWnlGoewUkC2qbST5YCbkjl2ZEzUaNp/n0katiqoTbs7PO/3fe8j X908r6S3EaZt
tJr4l8FX3xOq0nWjFhO/pNOLb/7N9dmV5J2qnqBWj82iM9y6rz27XYuJr80i EJVs1q0IuLIB
UPa2a2QtTHr8D3W/+A4311oKroC1ppl3Vng/xfYY1TUBoBQzCnCMKGFlEQGK It/bcNm5aGs6
4YcfwUVoCsqUsod7lmSEgjQdYI9ctnta6yhq8QasFvNuEVTaiP18GE0xIjNG YF6gAfjl19ro
pajs7x1VNq09jXkPigJFjkryEkPECkBnxH9BIGXN9hARijboKh6sdC2km7lf M5z3179YchO4
anfR4avs/5qF/ijQ+CyX41HvV7NPO3SdgjKDM9cOuwXwLsZ5mUWf6WhZ22Av bX8XmAJC+juy
AucPSYTwwByTTlkoeduuuX0qjN40TuYTPXsde9BtiD9W94OLuPG/I0hZf6sB NmLBaWy3q3i2
wigurVutfakgh4AmefaPyTun2MHnEcU+GYVL13OZpBG7S7KI/C26k/K8UZUR K6Esl+cnnn88
heIkjhEmDObZNIlLPPaGhCNP3PXZH1BLAwQKAAAAAAAGvIM7PV9kEAgAAAAI AAAAHgAAAGVz
LnVjYS5tb2RlbGluZy5hbnQvLmdpdGlnbm9yZWJpbgpsaWIKUEsDBAoAAAAI AAa8gzs7Disn
XAEAAMoDAAAcAAAAZXMudWNhLm1vZGVsaW5nLmFudC8ucHJvamVjdL1TTU8C MRA9w68ge+CE
rd5MKEsiaoxRYwL+gLE7lGK33fSDwL+3u1s2gBg9cXtv5k3fSztl022pBhu0 Tho9yW7IdTZA
zU0htZhkH4vHq9tsmvdZZc0aub9Hx62sfBTn/R7TUGKOjgQOpDQFqjhFQHtG m05UcFOWqH3O
6B7FYjrM1Zgeks8gVTGvkEeS2CyOgS7qQvIzVhDkSlYOybrwhBsbAWyg0aPt zOMAWBFqV9dS
esQZPXX4j2VVIHkFLZfo/N3FHOd8hSVcxi9IgluPVoPyxihHHhJbRHYmgrdS iLhB+TIoNZKa
W6wTgBox2vXOhO2xQvJ6lcDu2kKPfeEuf4Gg+Wpm9FKKpxhTIaN1PUk2oALm Q+XHaXWGwo9p
F/kgpKMNGDyDJao5lNF2urWnJ/5/3V4qpAWNF+eDxVba4h/P9q6CkPqtadZX 1oh+0R/tsj4d
2cNo1/2Zo9/4DVBLAwQKAAAAAAAGvIM7AAAAAAAAAAAAAAAAHgAAAGVzLnVj YS5tb2RlbGlu
Zy5hbnQvLnNldHRpbmdzL1BLAwQKAAAACAAGvIM7jxfR1KsAAACEAQAAOAAA AGVzLnVjYS5t
b2RlbGluZy5hbnQvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5jb3JlLnBy ZWZzlY7PSsNA
HITvfYoF70sSIrWBPago6KlgX2BNJsuv7D9mN0LfvhHsufEyDMN88D28U9Tz 4lSzV+3T0PdD
16nXt6+T6prmsMPoJRfoTMwg4oiif8AiKZp2l+j07XGeqh4TsUbI4sG1THCI WqKXiM/Cl0vF
72gQ7bfHtJGvlg716G2dE4Np9eNdMGQvdpXdcM5Mq0vQthSwfkyIVWYBDcjE jTDiEv6JlrTw
T/AKUEsDBAoAAAAAAAa8gzsAAAAAAAAAAAAAAAAdAAAAZXMudWNhLm1vZGVs aW5nLmFudC9N
RVRBLUlORi9QSwMECgAAAAgABryDOxRPTtUrAQAAAAMAACgAAABlcy51Y2Eu bW9kZWxpbmcu
YW50L01FVEEtSU5GL01BTklGRVNULk1GlZJLa4NAFIX3/goJdFcvagkFSzYF N4WU0kD343hj
Lp2HmUdI/31HjUmos+lCmOGc755zGbdM0R6ty77QWNKqSgvIk1evWoHZ9iJe tXJW3pnEKn24
u83K7kc2WhCfHGjBcwZStyhIdcCUe7HhINCFeRtn/BW8LwAFHD0TtCc0N121 2txCp/usfuLR
k8G2PiP3Lsyp1YmMVhKVq9K3cldnBayTiy2bqCrVJnTqGT/gWK2Zhp2mKptV Ac9QrB6T0Ydc
UG8RUO6HjzniwLXBBZUHKv9LhfFx9xOUUOQL/+AFg1Z7w9FGqPUyY2K8ciRj ORGiC7s0htoO
wVNk/XKJjOtHNyljCYOdh+fvUP0HG4pJ1kfMQ6WkPvfauOyD8W/Wxf+z+Y3C 4JgaAkKl5BdQ
SwMECgAAAAAABryDOwAAAAAAAAAAAAAAAB0AAABlcy51Y2EubW9kZWxpbmcu YW50L09TR0kt
SU5GL1BLAwQKAAAAAAAGvIM7AAAAAAAAAAAAAAAAIgAAAGVzLnVjYS5tb2Rl bGluZy5hbnQv
T1NHSS1JTkYvbDEwbi9QSwMECgAAAAgABryDOw8lhbpcAAAAZAAAADMAAABl cy51Y2EubW9k
ZWxpbmcuYW50L09TR0ktSU5GL2wxMG4vYnVuZGxlLnByb3BlcnRpZXM1yjEO gzAMBdCdU1hi
JjdggIq1YgB2i/wgq8FBiTNwe1i6Pr12zulCNkGhIBEUUiYUV3d2Z/KIoodj tWas6iO6Derf
0dP6Gf725ROvTPWACtNqEsVuGtRo4fIrD1BLAwQKAAAACAAGvIM7PpuBDLAA AAD+AAAAIQAA
AGVzLnVjYS5tb2RlbGluZy5hbnQvYnVpbGQtamFyLnhtbFWPsRKCMBBEa/iK zPUQ7SwSGCws
bcQPSMKBwRCcJDB+viFoYXHNvtvbPVa/J0NWdF7PlsOxPABBq+ZO24HDvb0U J6irnL3cPKIK
xIoJOZwXbbobulUrbGwA0mEvFhM4yI0Uo3BQ5RkLwg34M/2hjKF6zFU6FKNI c21JRIwmeePT
s9OOxOFgtASaxLgSs3zotcGkU7+3iP0Uel8KG8otgkjhMZmltsnM6N4mPkO/ 31QfUEsDBAoA
AAAIAAa8gzuTur5AqAAAAJkBAAAkAAAAZXMudWNhLm1vZGVsaW5nLmFudC9i dWlsZC5wcm9w
ZXJ0aWVzfVE7DsIwDN1zih6AJnAABpAAdQAGOrIkqQWp3CRyEqnHJ3QqaqgH S37Pn2c7uEQa
OK/2VSAtmEvRpzjFyljBsuPGakwdhIx5TK+MjANunqz6teupPdTN7SyWFF9C aFQh8f64NFMP
3G2tUMl2CNyT80DRQGBZ41wO1yhD8DK+CzNzWQ86FhgYI5CV2DqHx2SwAwoF MSsLqW/VTNif
jLqXVD7W2iGnR3wAUEsDBAoAAAAIAAa8gzvW6FyTCQEAAOUCAAAeAAAAZXMu dWNhLm1vZGVs
aW5nLmFudC9wbHVnaW4ueG1srZLNTsMwDMfvfYoqd1IQHDik7QF1e4HxACZz S1i+5GTT9vak
bViZBgcmfIkT2z//LUe0R6PLA1JQztbsgd+zEq10W2WHmr1uVnfPrG0K0aLU ygdcUh/50xTx
ej8o2xRlWQo8RrRjeLzN5p2ysWaOBp4RHGzk0tHkbCDsAmtyvsgvS3kyqSGE mmHgewncuC3q
JG6ioOkhKsm7+exG6hotEkRHI4hdkLR6I6BTzZJTBaSDkujJSQxhwn0AXRZY MJg65y7DTMZF
bpX13qp/MH2C8iwZV+TM2vQG/L9pzx36M/kX8aI67+6mVaZ0gpdxUg/xvbOR FH7b63X49Ofp
FuE/0K6HKET19TU/AVBLAwQKAAAAAAAGvIM7AAAAAAAAAAAAAAAAGAAAAGVz LnVjYS5tb2Rl
bGluZy5hbnQvc3JjL1BLAwQKAAAAAAAGvIM7AAAAAAAAAAAAAAAAGwAAAGVz LnVjYS5tb2Rl
bGluZy5hbnQvc3JjL2VzL1BLAwQKAAAAAAAGvIM7AAAAAAAAAAAAAAAAHwAA AGVzLnVjYS5t
b2RlbGluZy5hbnQvc3JjL2VzL3VjYS9QSwMECgAAAAAABryDOwAAAAAAAAAA AAAAACgAAABl
cy51Y2EubW9kZWxpbmcuYW50L3NyYy9lcy91Y2EvbW9kZWxpbmcvUEsDBAoA AAAAAAa8gzsA
AAAAAAAAAAAAAAAsAAAAZXMudWNhLm1vZGVsaW5nLmFudC9zcmMvZXMvdWNh L21vZGVsaW5n
L2FudC9QSwMECgAAAAAABryDOwAAAAAAAAAAAAAAADQAAABlcy51Y2EubW9k ZWxpbmcuYW50
L3NyYy9lcy91Y2EvbW9kZWxpbmcvYW50L2VtZmF0aWMvUEsDBAoAAAAIAAa8 gzuR1UovzgIA
AJMGAABSAAAAZXMudWNhLm1vZGVsaW5nLmFudC9zcmMvZXMvdWNhL21vZGVs aW5nL2FudC9l
bWZhdGljL0VtZmF0aWNFY29yZUdlbmVyYXRvclRhc2suamF2Ya1UTU8bMRA9 Z3/FiF4SBE7o
rSAkUgoICakRRerZ8U52Xby2648EWvGT+BX8Mcb2BhQE9FD2kKy97828mXn2 ePtjnwq24djY
WyebNsBQjODzZPIFpjoYLQ2ccSce7jl8M93DvW4i/mGJMVUKMsODQ49uiTWD q1Z6sM40jnfA
dQ2hReBCmM5yfSt1Ax0P6CRXPsXgDmmjJsiSS8XnCiHqGl2mEa7zYBZ5cWy6 zmiYxbmSAi6k
QO0RlntskuKsWinapzwSPXFISC19cHIegzR6J8uhzedUPCRuG4LdH49XqxVD oaT1yIxrxgob
rsbCqt3l3oS1oVMELp3SJahxfj9t0PN2q2AXpJaBCobp7Lxo6KzCDnXgSRdF +NhnXFWWi2ve
IKBnUXDWmRoV9Z5xHRh2C8orDqqKdBgX4Bc1hEnDTqXC511qAeMUp0UWjFE+ c79GqeqTG4E2
KT94F3vF/fUGYt1cYRwycoyJTpDA85L338DL9dtMxUbqdyhRB9khm/HQvoqi FqzbUBgNanSc
BkqQtD5Jv2frTWrKOE+epgwrx60lg5pl79JNLAjFPZ0AnlIu4KTPApf4O0qq heBZQwoXDJBU
8qV/JdCnXhMN8caioEPGNeRe5cOXfXfkEf+nsKccJRqPoaUK3vZygVHhnqYP /dEjv9lyKEvp
fcmbmZIZqJCAuvaQF3+rgXVymQpMRcGiuG/Qx1oaWYPH8MOJYf5uaZijxBqk k80SHA7z7kE1
uHsmZnBTiAXvMESn+wQZevSdanCyxs10eIMiBiRaaJ1Zedi0ew4mFzAsuQ9B R6VKikEmgMbV
C85wyztB90y5MOiuiz7AHFNlWyNSQ3IGgzxVoLmlf1oDFfbC7DTI8NO4a0+n jASm5aUxobwl
2qlxF0bkC2WYZCTvZ6EJMJ17oyh93hyNcuIXtiUnUNbE3PwwzGD6urYSDnuh O6X+3NK76hFQ
SwMECgAAAAAABryDOwAAAAAAAAAAAAAAADMAAABlcy51Y2EubW9kZWxpbmcu YW50L3NyYy9l
cy91Y2EvbW9kZWxpbmcvYW50L2dtZmdlbi9QSwMECgAAAAgABryDO3Ql5dW+ BQAAfRIAAE4A
AABlcy51Y2EubW9kZWxpbmcuYW50L3NyYy9lcy91Y2EvbW9kZWxpbmcvYW50 L2dtZmdlbi9H
ZW5lcmF0ZUZyb21HbWZtYXBUYXNrLmphdmGtV9tu3DYQfd+vmCxQQE4dbtK3 2jAQN77AaBwb
vjTPtDSrZUyRKkntxkn8SfmK/FiHpO7edZzCi1wkaubM4ZnhkJy9fN7fBF7C O13eGZEvHCTp
Fvzx+vWfsK+cVkLDMTfpj+8cDnTx47vKK/zCvMe+lBA8LBi0aJaYMbhaCAul 0bnhBXCVgVsg
8DTVRcnVnVA5FNyhEVxaj8EN0kBGJksuJL+RCJXK0AQ3siss6Hl4eaeLQis4 r26kSOG9SFFZ
hOUb9trjrBYiXbRxBFryISKZsM6Im8oJrbYDHRrsQnHnfRfOlTuz2Wq1YphK UVpk2uQziTmX
s7SUr5ZvXrOFKyQZR6VUBNXG7vgB+m2WCl6BUMLRhGH//CRyKEqJBSrHPS9C eN7fbFLy9Jbn
CGhZlXJW6AwlSc+4ciwv5jmq3cmEWGjj4BPJwRQ6dn3xvhslARgnmAUyp7W0 wfWvSsjs8HOK
pee9+6jtFbe3A4tG2lQbZKZSThTITi5Jg8quNcRiTsY+6YzyJ9mB4LnS1on0 SebXFycb7TCQ
KGWVC8UO/ct5eP6JA1W5rkyK7KJ+uET3VBef877fCb2v9aX8MKGo9BWX7MaI LCdZDVd2rk3B
rpqnK32M6tQn9qxEw2NCJrNQoF77ekVQqv3XsB4Qjk+PyAtCPcDc6KIZPeVl HA0L2//9oB3u
xEXkPJzBfythapzDyBXqNMKHsytwGm6QSh38iktdgNummYVVnqZoQ5cI34ir 9fZPnjasBPWa
W5HeejSK4VdRaXBJa6jHMcxopc2tr/VmIm8t4jMJ/DxwH8UXbrKAxSu30OaR 5hGslmgsRYe6
1dH6fntZlTR9az9yo2iyNpn2tJ1uTcrYJVPJSfbjugaOSJ7jYl7wMhQIfnao Mhur5etkAqSo
WJIdXBISNeqMII+EpCzmNfVt6tVl/UQ9/hOm7gMvyMAhlbMvswNhdgNUJLDU IgOL7qCGSmro
+RZF9H3TJ481gWAP5rs0fN9DqB3yHkbja9BVRrU0x55N7Eb3pIWK7wMKzSBR aB43M2kRR0w2
eTZMTmvxGiaNmAMmzSAxaR43M2kRR0w2eTZMzrvkNWR6+Rzw6Y0Tpd7bZlZ9 9BGxR/wbble9
WmrI9etrwK7/gegN63ATv0GEEcG1CG/PaA3S0sYRW/yMaeX8JN3C6JWF4Q5Z I9PGmN7uu3hm
QJtshRVCEzB3tQXAXFD7gMeaD+iSJqhw9ahVUuOFuAZpIr09J9na2q2/D8I2 FcDd4rhbB3GU
+UDcJdPZb5b+TLcfJHh7uCTaEA+wT7vK/iXsrsg3Yx+HU83/gu/6ygieThBQ GdGThEZYVPWc
asTDN+rSl6SvH7VEU+F6wJ4OPwc8bRvuZsDh5J9AsrMfweqSSc0zClqSgFH1 HuNtUJWUY+s2
9z2xHlrGTuwpDBm3NmIOycPF+WIvIrUrZU3yr4ZN4JeyPwzXkoGgbb8ZXBvx JHH7gCN1AaTO
k+m1DbvrneIFNZI2hsfegSn8Pg7b8ycdifNZ6C7USLyoRyKvDLZRz4lC4rsE HeeTERAdz6M2
NNEW9H7YEeoTOZ3iwn97PmTd5tq+EzvNIME+eS+iDxP27G+K0MuY/1p/JPpt f1yfXoC1prQR
0TGL2KW3RCTFpCcLxP4buuOwBa8P23O9b59Q0on2669hntIZjC5aaxHve9LE vMXj9z9ciixI
SKVTSerK/tslHWaNcHekyd4edHcddnhxcXbR12cjrenweE+XXMxg2UabjlIe /025o2tC0u1Z
2MXCzZpvJNFU+327+9aHyrBhPtgKH904vXLd2TBWCnz7Bl2z68a6Y1M3Nji6 jAtts4yPnXvr
m0eHW1TW+YsPp5C0GqcPp08XqdRRJnob8bqtuSYWm9voogjG1nv/6EOTEBOq kRrIO62ojug2
EquKRqh3J1tt8bCycvtSJr1Lr78102jb0BqfBjqei4yNp6H7yX9QSwECAAAK AAAAAAAGvIM7
AAAAAAAAAAAAAAAAFAAAAAAAAAAAABAAAAAAAAAAZXMudWNhLm1vZGVsaW5n LmFudC9QSwEC
AAAKAAAACAAGvIM789yriM0AAABvAQAAHgAAAAAAAAAAAAAAAAAyAAAAZXMu dWNhLm1vZGVs
aW5nLmFudC8uY2xhc3NwYXRoUEsBAgAACgAAAAAABryDOwAAAAAAAAAAAAAA ACoAAAAAAAAA
AAAQAAAAOwEAAGVzLnVjYS5tb2RlbGluZy5hbnQvLmV4dGVybmFsVG9vbEJ1 aWxkZXJzL1BL
AQIAAAoAAAAIAAa8gztr//yF0QEAACAFAAA6AAAAAAAAAAAAAAAAAIMBAABl cy51Y2EubW9k
ZWxpbmcuYW50Ly5leHRlcm5hbFRvb2xCdWlsZGVycy9CdWlsZCBKYXIubGF1 bmNoUEsBAgAA
CgAAAAAABryDOz1fZBAIAAAACAAAAB4AAAAAAAAAAAAAAAAArAMAAGVzLnVj YS5tb2RlbGlu
Zy5hbnQvLmdpdGlnbm9yZVBLAQIAAAoAAAAIAAa8gzs7DisnXAEAAMoDAAAc AAAAAAAAAAAA
AAAAAPADAABlcy51Y2EubW9kZWxpbmcuYW50Ly5wcm9qZWN0UEsBAgAACgAA AAAABryDOwAA
AAAAAAAAAAAAAB4AAAAAAAAAAAAQAAAAhgUAAGVzLnVjYS5tb2RlbGluZy5h bnQvLnNldHRp
bmdzL1BLAQIAAAoAAAAIAAa8gzuPF9HUqwAAAIQBAAA4AAAAAAAAAAAAAAAA AMIFAABlcy51
Y2EubW9kZWxpbmcuYW50Ly5zZXR0aW5ncy9vcmcuZWNsaXBzZS5qZHQuY29y ZS5wcmVmc1BL
AQIAAAoAAAAAAAa8gzsAAAAAAAAAAAAAAAAdAAAAAAAAAAAAEAAAAMMGAABl cy51Y2EubW9k
ZWxpbmcuYW50L01FVEEtSU5GL1BLAQIAAAoAAAAIAAa8gzsUT07VKwEAAAAD AAAoAAAAAAAA
AAAAAAAAAP4GAABlcy51Y2EubW9kZWxpbmcuYW50L01FVEEtSU5GL01BTklG RVNULk1GUEsB
AgAACgAAAAAABryDOwAAAAAAAAAAAAAAAB0AAAAAAAAAAAAQAAAAbwgAAGVz LnVjYS5tb2Rl
bGluZy5hbnQvT1NHSS1JTkYvUEsBAgAACgAAAAAABryDOwAAAAAAAAAAAAAA ACIAAAAAAAAA
AAAQAAAAqggAAGVzLnVjYS5tb2RlbGluZy5hbnQvT1NHSS1JTkYvbDEwbi9Q SwECAAAKAAAA
CAAGvIM7DyWFulwAAABkAAAAMwAAAAAAAAAAAAAAAADqCAAAZXMudWNhLm1v ZGVsaW5nLmFu
dC9PU0dJLUlORi9sMTBuL2J1bmRsZS5wcm9wZXJ0aWVzUEsBAgAACgAAAAgA BryDOz6bgQyw
AAAA/gAAACEAAAAAAAAAAAAAAAAAlwkAAGVzLnVjYS5tb2RlbGluZy5hbnQv YnVpbGQtamFy
LnhtbFBLAQIAAAoAAAAIAAa8gzuTur5AqAAAAJkBAAAkAAAAAAAAAAAAAAAA AIYKAABlcy51
Y2EubW9kZWxpbmcuYW50L2J1aWxkLnByb3BlcnRpZXNQSwECAAAKAAAACAAG vIM71uhckwkB
AADlAgAAHgAAAAAAAAAAAAAAAABwCwAAZXMudWNhLm1vZGVsaW5nLmFudC9w bHVnaW4ueG1s
UEsBAgAACgAAAAAABryDOwAAAAAAAAAAAAAAABgAAAAAAAAAAAAQAAAAtQwA AGVzLnVjYS5t
b2RlbGluZy5hbnQvc3JjL1BLAQIAAAoAAAAAAAa8gzsAAAAAAAAAAAAAAAAb AAAAAAAAAAAA
EAAAAOsMAABlcy51Y2EubW9kZWxpbmcuYW50L3NyYy9lcy9QSwECAAAKAAAA AAAGvIM7AAAA
AAAAAAAAAAAAHwAAAAAAAAAAABAAAAAkDQAAZXMudWNhLm1vZGVsaW5nLmFu dC9zcmMvZXMv
dWNhL1BLAQIAAAoAAAAAAAa8gzsAAAAAAAAAAAAAAAAoAAAAAAAAAAAAEAAA AGENAABlcy51
Y2EubW9kZWxpbmcuYW50L3NyYy9lcy91Y2EvbW9kZWxpbmcvUEsBAgAACgAA AAAABryDOwAA
AAAAAAAAAAAAACwAAAAAAAAAAAAQAAAApw0AAGVzLnVjYS5tb2RlbGluZy5h bnQvc3JjL2Vz
L3VjYS9tb2RlbGluZy9hbnQvUEsBAgAACgAAAAAABryDOwAAAAAAAAAAAAAA ADQAAAAAAAAA
AAAQAAAA8Q0AAGVzLnVjYS5tb2RlbGluZy5hbnQvc3JjL2VzL3VjYS9tb2Rl bGluZy9hbnQv
ZW1mYXRpYy9QSwECAAAKAAAACAAGvIM7kdVKL84CAACTBgAAUgAAAAAAAAAA AAAAAABDDgAA
ZXMudWNhLm1vZGVsaW5nLmFudC9zcmMvZXMvdWNhL21vZGVsaW5nL2FudC9l bWZhdGljL0Vt
ZmF0aWNFY29yZUdlbmVyYXRvclRhc2suamF2YVBLAQIAAAoAAAAAAAa8gzsA AAAAAAAAAAAA
AAAzAAAAAAAAAAAAEAAAAIERAABlcy51Y2EubW9kZWxpbmcuYW50L3NyYy9l cy91Y2EvbW9k
ZWxpbmcvYW50L2dtZmdlbi9QSwECAAAKAAAACAAGvIM7dCXl1b4FAAB9EgAA TgAAAAAAAAAA
AAAAAADSEQAAZXMudWNhLm1vZGVsaW5nLmFudC9zcmMvZXMvdWNhL21vZGVs aW5nL2FudC9n
bWZnZW4vR2VuZXJhdGVGcm9tR21mbWFwVGFzay5qYXZhUEsFBgAAAAAZABkA awgAAPwXAAAA
AA==
Content-Type: text/xml;
name="generate-code.xml"
filename="generate-code.xml"
<project name="serviceProcess" default="default">
<description>
<![CDATA[
This Ant buildfile attempts to mimic the basic Eugenia workflow
included in the documentation. It consists of: generating the
ECore model from the Emfatic source file, generating the .genmodel
file, customizing it with the global and user-defined EOL scripts,
generating the EMF code, deriving the GMF models from the ECore
file, deriving the GMFGen model from these, customizing it, and
finally generating the source code from it.
It depends on the es.uca.modeling.ant and ca.ecliptical.gmf.ant
plugins to do its work. The Ecliptical update site is at [1].
Currently, there's one known issue: the edit and editor projects,
when created from scratch, do not have the required Java and PDE
natures assigned to them. For the first nature, see [2]. For the
second, right-click on the project and use "Configure > Convert
to Plugin Projects...". Another option is generating the projects
the first time through the GUI, and then "Refactor > Move" them
to the locations in the *Project.location properties. Nevertheless,
this bug might be fixed by EMF 2.6 [3].
[1]: http://www.eclipticalsoftware.com/updates/site.xml
[2]: http://enarion.net/programming/tools/eclipse/changing-genera l-project-to-java-project/
[3]: http://www.eclipse.org/forums/index.php?t=msg&th=152228
</description>
<!-- PROPERTIES ####################################################### -->
<!-- Basic project info -->
<property name="project.name" value="ServiceProcess" />
<property name="model.dir" value="model" />
<property name="model.basename" value="serviceprocess" />
<property name="templates.dir" value="templates"/>
<property name="templates.gmfgraph.dir" value="templates-gmfgraph"/>
<!-- File locations -->
<property name="copyright.location" value="${model.dir}/copyright.txt" />
<property name="emfatic.location" value="${model.dir}/${model.basename}.emf" />
<property name="ecore.location" value="${model.dir}/${model.basename}.ecore" />
<property name="genmodel.location" value="${model.dir}/${model.basename}.genmodel" />
<property name="gmfgen.location" value="${model.dir}/${model.basename}.gmfgen" />
<property name="gmfgraph.location" value="${model.dir}/${model.basename}.gmfgraph" />
<property name="gmfmap.location" value="${model.dir}/${model.basename}.gmfmap" />
<property name="gmftool.location" value="${model.dir}/${model.basename}.gmftool" />
<!-- Project locations -->
<!-- For some reason, to create the edit and editor projects, we need to
pass some special arguments to emf.Ecore2Java, and place them in paths
different to their expected placement: (workspace)/(project name).
Otherwise, Eclipse will complain that their paths overlaps with
themselves, which strikes me as very odd. Perhaps it's being created
several times, or something like that? -->
<property name="modelProject.location" location="${basedir}" />
<property name="editProject.location" location="${basedir}/../generated/${project.name}.edit" />
<property name="editorProject.location" location="${basedir}/../generated/${project.name}.editor" />
<property name="testsProject.location" location="${basedir}/../generated/${project.name}.tests" />
<property name="diagramProject.location" location="${basedir}/../${project.name}.diagram" />
<!-- EPackage URIs -->
<property name="ecore.nsuri" value="http://www.eclipse.org/emf/2002/Ecore" />
<property name="genmodel.nsuri" value="http://www.eclipse.org/emf/2002/GenModel" />
<property name="gmfgraph.nsuri" value="http://www.eclipse.org/gmf/2006/GraphicalDefinition" />
<property name="gmftool.nsuri" value="http://www.eclipse.org/gmf/2005/ToolDefinition" />
<property name="gmfmap.nsuri" value="http://www.eclipse.org/gmf/2008/mappings" />
<property name="gmfgen.nsuri" value="http://www.eclipse.org/gmf/2009/GenModel" />
<!-- Epsilon URLs -->
<property name="epsilon.ecore2gmf.uri" value=" platform:/plugin/org.eclipse.epsilon.eugenia/transformations /ECore2GMF.eol " />
<property name="epsilon.fixgenmodel.uri" value=" platform:/plugin/org.eclipse.epsilon.eugenia/transformations /FixGenModel.eol " />
<property name="epsilon.fixgengmf.uri" value=" platform:/plugin/org.eclipse.epsilon.eugenia/transformations /FixGMFGen.eol " />
<property name="epsilon.ecore2gmf.local" value="${model.dir}/ECore2GMF.eol" />
<property name="epsilon.fixgenmodel.local" value="${model.dir}/FixGenModel.eol" />
<property name="epsilon.fixgmfgen.local" value="${model.dir}/FixGMFGen.eol" />
<available property="epsilon.ecore2gmf.local.exists" file="${epsilon.ecore2gmf.local}" />
<available property="epsilon.fixgenmodel.local.exists" file="${epsilon.fixgenmodel.local}" />
<available property="epsilon.fixgmfgen.local.exists" file="${epsilon.fixgmfgen.local}" />
Copyright text: try loading the copyright text. If it doesn't exist,
use the empty string.
<loadfile srcFile="${copyright.location}" property="copyright.contents" quiet="true" />
<property name="copyright.contents" value="" />
<!-- MAIN BODY ######################################################## -->
<target name="init">
<tstamp />
</target>
<target name="refreshEmfatic" if="eclipse.application">
<echo>Refreshing the project directory under Eclipse</echo>
<eclipse.refreshLocal resource="/${project.name}" depth="infinite"/>
</target>
<target name="generateECore" depends="refreshEmfatic">
<echo>Generating ${ecore.location} file from Emfatic source ${emfatic.location}</echo>
<emfatic.generate src="${emfatic.location}" />
</target>
<target name="registerECore" depends="generateECore">
<echo>Registering ${ecore.location} file permanently</echo>
<epsilon.emf.register file="${ecore.location}" permanently="true"/>
</target>
<target name="generateGenModel" depends="registerECore">
<echo>Generating initial ${genmodel.location} file</echo>
<emf.Ecore2Java model="${ecore.location}" genmodel="${genmodel.location}" modelproject="${modelProject.location}" modelProjectFragmentPath="src" modelPluginID="${project.name}" generateJavaCode="false" validateModel="true">
<arg line="-editProject ${editProject.location} src" />
<arg line="-editorProject ${editorProject.location} src" />
<arg line="-testsProject ${testsProject.location} src" />
</emf.Ecore2Java>
</target>
<target name="defaultFixGenModel" depends="generateGenModel">
<echo>Fixing ${genmodel.location} (default EOL script) </echo>
<epsilon.emf.loadModel name="ECore" modelFile="${ecore.location}" metamodeluri="${ecore.nsuri}" read="true" store="false" />
<epsilon.emf.loadModel name="GenModel" modelFile="${genmodel.location}" metamodeluri="${genmodel.nsuri}" read="true" store="true" />
<epsilon.eol uri="${epsilon.fixgenmodel.uri}">
<parameter name="copyright" value="${copyright.contents}" />
<model ref="ECore" as="ECore" />
<model ref="GenModel" as="GenModel" />
</epsilon.eol>
</target>
<target name="customFixGenModel" depends="defaultFixGenModel" if="epsilon.fixgenmodel.local.exists">
<echo>Fixing ${genmodel.location} (user-defined EOL script)</echo>
<epsilon.eol src="${epsilon.fixgenmodel.local}">
</epsilon.eol>
</target>
<target name="saveGenModel" depends="customFixGenModel">
<epsilon.disposeModel model="GenModel" />
</target>
<target name="generateEMFCode" depends="customFixGenModel">
<echo>Generating EMF edit and editor code</echo>
<emf.Ecore2Java model="${ecore.location}" genmodel="${genmodel.location}" reconcileGenModel="keep" modelproject="${modelProject.location}" modelProjectFragmentPath="src" modelPluginID="${project.name}" jdkLevel="5.0" validateModel="true" autoBuild="true">
</emf.Ecore2Java>
</target>
<target name="generateGMFFiles" depends="generateEMFCode">
<echo>Generating GMF models</echo>
<epsilon.emf.loadModel name="GmfGraph" modelFile="${gmfgraph.location}" metamodeluri="${gmfgraph.nsuri}" read="false" store="true" />
<epsilon.emf.loadModel name="GmfTool" modelFile="${gmftool.location}" metamodeluri="${gmftool.nsuri}" read="false" store="true" />
<epsilon.emf.loadModel name="GmfMap" modelFile="${gmfmap.location}" metamodeluri="${gmfmap.nsuri}" read="false" store="true" />
<epsilon.eol uri="${epsilon.ecore2gmf.uri}">
<model ref="GmfGraph" as="GmfGraph" />
<model ref="GmfTool" as="GmfTool" />
<model ref="GmfMap" as="GmfMap" />
</epsilon.eol>
</target>
<target name="customFixGMFFiles" depends="generateGMFFiles" if="epsilon.ecore2gmf.local.exists">
<echo>Customizing GMF models</echo>
<epsilon.eol src="${epsilon.ecore2gmf.local}">
</epsilon.eol>
</target>
<target name="saveGMFFiles" depends="customFixGMFFiles">
<epsilon.disposeModel model="GmfGraph" />
<epsilon.disposeModel model="GmfTool" />
<epsilon.disposeModel model="GmfMap" />
</target>
<target name="generateGMFGenModel" depends="saveGMFFiles">
<echo>Generating and synchronizing GMFGen model ${gmfgen.location} from GMFMap model</echo>
<gmfgen.fromGmfmap projectName="${project.name}" destFile="${gmfgen.location}" genModel="${genmodel.location}" mapModel="${gmfmap.location}" templatesDir="${templates.gmfgraph.dir}"/>
<epsilon.emf.loadModel name="GmfGen" modelFile="${gmfgen.location}" metamodeluri="${gmfgen.nsuri}" read="true" store="true" />
<epsilon.eol uri="${epsilon.fixgengmf.uri}">
<model ref="GmfGen" as="GmfGen" />
</epsilon.eol>
</target>
<target name="customFixGMFGenModel" depends="generateGMFGenModel" if="epsilon.fixgmfgen.local.exists">
<echo>Customizing GMFGen model ${gmfgen.location}</echo>
<epsilon.eol src="${epsilon.fixgmfgen.local}">
</epsilon.eol>
</target>
<target name="saveGMFGenModel" depends="customFixGMFGenModel">
<epsilon.disposeModel model="GmfGen"/>
</target>
<target name="generateDiagramCode" depends="saveGMFGenModel"
xmlns:gmf="http://ecliptical.ca/gmf/ant">
<echo>Generating diagram project in ${diagramProject.location}</echo>
<gmf:GenerateDiagramCode gmfgenpath="${project.name}/${gmfgen.location}"/>
</target>
<!-- Default target -->
<target name="default" depends="generateDiagramCode"/>
<target name="clean">
<delete includeEmptyDirs="true" quiet="true">
<fileset dir="${modelProject.location}" includes="src/**/*"/>
<fileset dir="${modelProject.location}" includes="bin/**/*"/>
<fileset dir="${modelProject.location}" includes="${genmodel.location}"/>
<fileset dir="${modelProject.location}" includes="${gmfmap.location}"/>
<fileset dir="${modelProject.location}" includes="${gmftool.location}"/>
<fileset dir="${modelProject.location}" includes="${gmfgraph.location}"/>
<fileset dir="${modelProject.location}" includes="${gmfgen.location}"/>
<fileset dir="${modelProject.location}" includes="${ecore.location}"/>
<fileset dir="${modelProject.location}" includes="${emfatic.location}"/>
<fileset dir="${editProject.location}" includes="src/**/*"/>
<fileset dir="${editProject.location}" includes="bin/**/*"/>
<fileset dir="${editorProject.location}" includes="src/**/*"/>
<fileset dir="${editorProject.location}" includes="bin/**/*"/>
<fileset dir="${testsProject.location}" includes="src/**/*"/>
<fileset dir="${testsProject.location}" includes="bin/**/*"/>
<fileset dir="${diagramProject.location}" includes="src/**/*"/>
<fileset dir="${diagramProject.location}" includes="bin/**/*"/>
</delete>
</target>
</project>
--------------080208040805090908080404--
Re: Eugenia: Starters/ideas to automate GMF generation? [message #501826 is a reply to message #501825] Thu, 03 December 2009 18:14 Go to previous messageGo to next message
Hi again,
Ugh, remind me not to write long mails in a hurry at midnight. Let me
correct a few things.
Careful with this. I've tried to only remove what's strictly required,
but it might be a little trigger-happy for your taste. I prefer to have
as few files under version control as possible.
Replace with:
* Optionally, ECore2GMF.eol (same as that used in EuGENia)
* Optionally, FixGenModel.eol (same as that used in EuGENia)
* Optionally, FixGMFGen.eol (same as that used in EuGENia)
* Optionally, copyright.txt (copyright info, like in EuGENia)
Well, that's it for today. Hope it helps :-).
Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #502038 is a reply to message #501742] Fri, 04 December 2009 16:07 Go to previous messageGo to next message
Just to add to this briefly: The EMF generation bit is not problematic:
EMF has a class called Generator that does all of this and, IIRC, comes
with its own main method and all.
Steffen
Dimitris Kolovos wrote:
> Hi Christoph,
> Cheers,
> Dimitris
>> Hey guys,
Re: Eugenia: Starters/ideas to automate GMF generation? [message #502089 is a reply to message #502038] Sat, 05 December 2009 09:09 Go to previous messageGo to next message
Hi Steffen,
That's nice to know, thanks :-). Are the generated projects set up just
like those created from the ECore editor context menu entries?
On August I ran into some problems with the EMF Ant tasks because they
didn't generate the projects in the exact same way. They weren't
completely set up and had to be placed in a subdirectory of the
workspace (workspace/generated/X.model, workspace/generated/X.edit, and
so on). I think they might have fixed some of these issues by now, but I
haven't checked yet.
Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #502233 is a reply to message #502089] Mon, 07 December 2009 05:46 Go to previous messageGo to next message
I think, the projects should be set up the same way as I believe this is
the same code that is run from the IDE.
Steffen
Antonio García Domínguez wrote:
> Hi Steffen,
> Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #536651 is a reply to message #501825] Sat, 29 May 2010 06:10 Go to previous messageGo to next message
Hi Antonio,
I just started to browse the Epsilon forums myself looking to automatize the process of diagram generation.
I came across your ANT script, but I can't make it work. It dies when trying to generate the .ecore file from the .emf file, with the following message:
Problem: failed to create task or type emfatic.generate
It doesn't seem to recognize any of these tasks, as I removed this part, and then it died with this:
Problem: failed to create task or type epsilon.emf.register
I installed the required plugins from here
Ecliptical - http://www.eclipticalsoftware.com/updates/site.xml
and here
Ant tasks for GMF - http://neptuno.uca.es/~agarcia/sodmt-updates/site.xml
Well actually, I installed every plugin from these sites, hoping it would make it work - probably not a wise choice, I will revert my eclipse to a previous state Smile.
I also have the latest version of modeling tools and epsilon (just checked for updates from eclipse).
Did I miss any requirements?
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #538125 is a reply to message #536651] Sat, 05 June 2010 08:11 Go to previous messageGo to next message
I found some topics on the forum about using epsilon with ant, and started fiddling with the build script again.
The tasks that begin with epsilon, e.g.epsilon.eol, epsilon.emf.register now work, however others, such as gmfgen.fromGmfmap and emfatic.generate do not.
Does anybody know what can be done for Ant to recognize these tasks?
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #538189 is a reply to message #538125] Sun, 06 June 2010 05:05 Go to previous messageGo to next message
Hi Endre,
These appear to be tasks written by Antonio, so it's probably worth
dropping him an email to speed things up.
Dimitris
> started fiddling with the build script again. The tasks that begin with
> Cheers,
> Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #538205 is a reply to message #538189] Sun, 06 June 2010 07:32 Go to previous messageGo to next message
Hi Dimitris,
Thanks for the suggestion, I will write him about it.
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583376 is a reply to message #501713] Thu, 03 December 2009 11:23 Go to previous messageGo to next message
Hi Christoph,
Dimitris
> Hey guys,
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583388 is a reply to message #501742] Thu, 03 December 2009 18:07 Go to previous messageGo to next message
Hi all,
update site:
project like this:
same time :-D)
post somewhere :-D.
Antonio
AA==
<description>
<![CDATA[
</description>
<tstamp />
</target>
</target>
</target>
</target>
</emf.Ecore2Java>
</target>
</epsilon.eol>
</target>
</epsilon.eol>
</target>
</target>
</emf.Ecore2Java>
</target>
</epsilon.eol>
</target>
</epsilon.eol>
</target>
</target>
</epsilon.eol>
</target>
</epsilon.eol>
</target>
</target>
</target>
</delete>
</target>
</project>
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583407 is a reply to message #501825] Thu, 03 December 2009 18:14 Go to previous messageGo to next message
Hi again,
Replace with:
Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583472 is a reply to message #501742] Fri, 04 December 2009 16:07 Go to previous messageGo to next message
Steffen
> Hi Christoph,
> Cheers,
> Dimitris
>> Hey guys,
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583499 is a reply to message #502038] Sat, 05 December 2009 09:09 Go to previous messageGo to next message
Hi Steffen,
Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #583593 is a reply to message #502089] Mon, 07 December 2009 05:46 Go to previous messageGo to next message
Steffen
> Hi Steffen,
> Antonio
Re: Eugenia: Starters/ideas to automate GMF generation? [message #589487 is a reply to message #501825] Sat, 29 May 2010 06:10 Go to previous messageGo to next message
Hi Antonio,
and here
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #589827 is a reply to message #589487] Sat, 05 June 2010 08:11 Go to previous messageGo to next message
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #589839 is a reply to message #589827] Sun, 06 June 2010 05:05 Go to previous messageGo to next message
Hi Endre,
Dimitris
> Cheers,
> Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #589853 is a reply to message #538189] Sun, 06 June 2010 07:32 Go to previous messageGo to next message
Hi Dimitris,
Endre
Re: Eugenia: Starters/ideas to automate GMF generation? [message #1263278 is a reply to message #583499] Tue, 04 March 2014 05:39 Go to previous messageGo to next message
How to run the following build.xml from command prompt ?
<project default="main">
<target name="main">
<epsilon.eugenia src="new_file.emf"/>
</target>
</project>
I have the latest ant installed and working perfectly.
Currently it says Problem: failed to create task or type epsilon.eugenia
Kindly help!
Shrikanth NC
[Updated on: Tue, 04 March 2014 05:40] by Moderator
Re: Eugenia: Starters/ideas to automate GMF generation? [message #1266305 is a reply to message #1263278] Fri, 07 March 2014 03:47 Go to previous message
Please see http://www.eclipse.org/forums/index.php/mv/msg/660072/1266297/#msg_1266297
Dimitris
Previous Topic:[Eugenia] using xcore class from another plugin
Next Topic:ETL trafo plug-in - no target model visible
Current Time: Sat Jul 26 01:12:18 EDT 2025
Powered by FUDForum. Page generated in 0.10011 seconds
