| Common Navigator - Label Provider [message #497552] |
Fri, 13 November 2009 03:55  |
Hello guys.
I have implemented my own Common Navigator for my application, with its ContentProvider and LabelProvider. LabelProvider sets up the icons for the different nodes. I would like it, for certain nodes, change the icon depending if the node is expanded or collapsed. I guess this would be easier have the SWT TreeNode, but I want to know if there is a easier way - sth like catching the event of expanding an calling the LabelProvider...
Any help would be really appreciated, thanks!
| Re: Common Navigator - Label Provider [message #498304 is a reply to message #497552] |
Mon, 16 November 2009 06:57  |
Hi!
Maybe you could override inputChanged(Viewer, Object, Object) in your
IContentProvider and register an ITreeViewerListener that calls "update"
on the viewer every time the expansion state of an element changes.
(I know, this should be done in the label provider instead, but
unfortunately only the content provider gets access to its viewer)
Mario
Javier schrieb:
> Hello guys.
> LabelProvider...
FUDForum. Page generated in 0.04139 seconds
