Home » Language IDEs » ServerTools (WTP) » Failed while installing Dynamic Web Module 2.5
Failed while installing Dynamic Web Module 2.5 [message #480304] Fri, 14 August 2009 16:55 Go to next message
Originally posted by: louisseize.gmx.de
Eclipse IDE for Java Developers (Galileo)
Build id: 20090619-0625
Eclipse Web Developer Tools:
3.1.0.v200905242131-7R77FShEVw2xUGpF1LiNxdVAELXy
The creation of a Dynamic Web Project in Galileo with WTP via the Dynamic
Web Project wizard elicits an error message:
Reason: [ditto]
Details: java.lang.NullPointerException
Project contents: Use default
Target runtime: Apache Tomcat v6.0 (works)
Dynamic web module version: 2.5
Configuration: Default Configuration for Apache Tomcat v6.0
[all defaults accepted]
The error occurs on clicking "Finish".
The project "xxx" is created; however, when trying to add a servlet to
"xxx" via the wizard, the project "xxx" is not available in the selector
labeled "Web project". The web project creation appears to have been a
failure.
Googling for the error message brings up some hits (for 2.5 and 2.4), but
no resolution. What could it be?
Being an Eclipe noob, what could I do to track this down?
Note that I'm *not* using the "Eclipse IDE for Java EE Developers", but
the simply the "Eclipse IDE for Java Developers" with additional
components such as WST, Subclipse, Java EE Developer Tools installed.
Re: Failed while installing Dynamic Web Module 2.5 [message #480575 is a reply to message #480304] Mon, 17 August 2009 13:03 Go to previous messageGo to next message
> Dynamic Web Project wizard elicits an error message:
> Reason: [ditto]
> failure.
> but no resolution. What could it be?
Michael,
Is this still a problem? If so, seeing the stack trace leading to the
NullPointerException would help.
Larry
Re: Failed while installing Dynamic Web Module 2.5 [message #480923 is a reply to message #480575] Tue, 18 August 2009 19:33 Go to previous messageGo to next message
Same problem for mee too. Stack trace follows ... Thanks in advance
java.lang.NullPointerException: No IModelProvider exists for project P/TestJSP of version: Dynamic Web Module 2.5
at org.eclipse.jst.j2ee.model.ModelProviderManager.getModelProv ider(ModelProviderManager.java:99)
at org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.createWeb25DeploymentDescriptor(WebFacetInstallDelegate.j ava:283)
at org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.execute(WebFacetInstallDelegate.java:116)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1467)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:438)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChangesInternal(FacetedProject.java:1171)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:1107)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$5.run(FacetedProject.java:1089)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChanges(FacetedProject.java:1099)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectWorkingCopy.commitChanges(FacetedProjectWorkingCopy.jav a:1958)
at org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard.performFinish(ModifyFacetedProjectWizard.java:400)
at org.eclipse.wst.web.ui.internal.wizards.NewProjectDataModelF acetWizard.performFinish(NewProjectDataModelFacetWizard.java :279)
at org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard$3.run(ModifyFacetedProjectWizard.java:331)
at org.eclipse.wst.common.project.facet.ui.ModifyFacetedProject Wizard$4.run(ModifyFacetedProjectWizard.java:345)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: Failed while installing Dynamic Web Module 2.5 [message #480925 is a reply to message #480575] Tue, 18 August 2009 20:15 Go to previous messageGo to next message
Same problem for me too ... stack trace follows. Thanks in advance.
Re: Failed while installing Dynamic Web Module 2.5 [message #480928 is a reply to message #480925] Tue, 18 August 2009 20:34 Go to previous messageGo to next message
Sorry for double posting ...
Forgot to say that Dynamic Web Module 2.4 works without problems
Thanks again
Re: Failed while installing Dynamic Web Module 2.5 [message #480931 is a reply to message #480928] Tue, 18 August 2009 20:50 Go to previous messageGo to next message
Solved it, installing additional packages for j2ee develpment (not sure which package did the magic, installed almost all of them) ...
Anyway I think the cause is a dependency mismatch between WTP and J2EE plugins ...
Greetings
Re: Failed while installing Dynamic Web Module 2.5 [message #482830 is a reply to message #480575] Fri, 28 August 2009 05:39 Go to previous messageGo to next message
Larry,
sorry I lost of track this thread I started. Reading Sebastiano's reply below, I installed all items in the collection "Web, XML, and Java EE Development" from the Galileo release site. That fixed it.
Where does Eclipse write stack traces? Didn't see any in the Eclipse installation directory. Do I have to do some configuration to make log files appear?
Michael Ludwig
Re: Failed while installing Dynamic Web Module 2.5 [message #482841 is a reply to message #482830] Fri, 28 August 2009 06:20 Go to previous messageGo to next message
Hi Michael,
> files appear?
"...\workspace\.metadata\.log" contains all Eclipse errors.
Best regards
Wolfgang
Re: Failed while installing Dynamic Web Module 2.5 [message #482981 is a reply to message #482841] Fri, 28 August 2009 16:28 Go to previous messageGo to next message
Indeed. Besten Dank, Wolfgang!
Michael
Re: Failed while installing Dynamic Web Module 2.5 [message #483075 is a reply to message #482841] Sun, 30 August 2009 16:57 Go to previous messageGo to next message
I'm having the same issue and nothing I try fixes it. Stack dump is
below. Please help!
!ENTRY org.eclipse.core.resources 4 2 2009-08-30 16:52:03.728
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 0
org.eclipse.jst.j2ee.refactor.operations.ProjectRefactorMeta data$RefererCachingVirtualComponent. <init>(ProjectRefactorMetadata.java:354)
org.eclipse.jst.j2ee.refactor.operations.ProjectRefactorMeta data.computeMetadata(ProjectRefactorMetadata.java:88)
org.eclipse.jst.j2ee.refactor.operations.ProjectRefactorMeta data.computeMetadata(ProjectRefactorMetadata.java:78)
org.eclipse.jst.j2ee.refactor.listeners.ProjectRefactoringLi stener.cacheDeletedProjectMetadata(ProjectRefactoringListene r.java:100)
org.eclipse.jst.j2ee.refactor.listeners.ProjectRefactoringLi stener.resourceChanged(ProjectRefactoringListener.java:87)
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:288)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:282)
org.eclipse.core.internal.events.NotificationManager.handleE vent(NotificationManager.java:260)
org.eclipse.core.internal.resources.Workspace.broadcastEvent (Workspace.java:307)
org.eclipse.core.internal.resources.Resource.broadcastPreDel eteEvent(Resource.java:1777)
at org.eclipse.core.internal.resources.Resource.delete(Resource .java:696)
at org.eclipse.core.internal.resources.Project.delete(Project.j ava:309)
org.eclipse.ltk.core.refactoring.resource.DeleteResourceChan ge.perform(DeleteResourceChange.java:131)
org.eclipse.ltk.core.refactoring.CompositeChange.perform(Com positeChange.java:278)
org.eclipse.ltk.core.refactoring.PerformChangeOperation$1.ru n(PerformChangeOperation.java:260)
org.eclipse.ltk.core.refactoring.PerformChangeOperation.exec uteChange(PerformChangeOperation.java:308)
org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion.access$1(UIPerformChangeOperation.java:1)
org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion$1.run(UIPerformChangeOperation.java:66)
org.eclipse.ltk.internal.ui.refactoring.UIPerformChangeOpera tion$2.run(UIPerformChangeOperation.java:84)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.run(RefactoringWizardDialog2.java:317)
org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPer formFinish(RefactoringWizard.java:558)
org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFi nish(UserInputWizardPage.java:154)
org.eclipse.ltk.ui.refactoring.resource.DeleteResourcesWizar d$DeleteResourcesRefactoringConfigurationPage.performFinish( DeleteResourcesWizard.java:147)
org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFini sh(RefactoringWizard.java:622)
org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDia log2.okPressed(RefactoringWizardDialog2.java:446)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 72)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n$1.run(RefactoringWizardOpenOperation.java:144)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperatio n.run(RefactoringWizardOpenOperation.java:156)
org.eclipse.ltk.internal.ui.refactoring.actions.DeleteResour cesHandler.execute(DeleteResourcesHandler.java:41)
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
org.eclipse.ui.internal.handlers.HandlerService.executeComma ndInContext(HandlerService.java:270)
org.eclipse.ui.internal.ide.actions.LTKLauncher.runCommand(L TKLauncher.java:95)
org.eclipse.ui.internal.ide.actions.LTKLauncher.openDeleteWi zard(LTKLauncher.java:47)
org.eclipse.ui.actions.DeleteResourceAction.run(DeleteResour ceAction.java:480)
org.eclipse.jdt.internal.ui.refactoring.reorg.DeleteAction.r un(DeleteAction.java:71)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Re: Failed while installing Dynamic Web Module 2.5 [message #483077 is a reply to message #483075] Sun, 30 August 2009 18:37 Go to previous messageGo to next message
Your stack trace is different from the one Sebastiano has posted, which is the same I've observed in my Eclipse log file once I discovered it.
So I don't think you're experiencing the same issue.
If you're still sure it's the same issue, you can try installing all items in the collection "Web, XML, and Java EE Development" from the Galileo release site. That fixed it for me and, apparently, for Sebastiano as well.
Re: Failed while installing Dynamic Web Mod ule 2.5 [message #483081 is a reply to message #483077] Sun, 30 August 2009 20:28 Go to previous messageGo to next message
I just reinstalled the Java EE ones and that seems to have fixed it. It's
the 3rd time I tried that though so I guess 3rd time is the charm.
Strange.
Re: Failed while installing Dynamic Web Module 2.5 [message #490014 is a reply to message #480304] Tue, 06 October 2009 17:21 Go to previous messageGo to next message
It appears that you need to install one or all of the following:
JST Server UI
JST Web UI
It's probably a good idea to also install the following:
JST Server Adapters
WST Server Adapters
Hope this helps.
Re: Failed while installing Dynamic Web Module 2.5 [message #552372 is a reply to message #480304] Wed, 11 August 2010 19:18 Go to previous messageGo to next message
Thanks for everyone's input, you got me started in the right direction. I had the same symptom, similar solution, but my stacktrace is a bit different.
My Solution:
Installed "Java EE IDE Feature" from
http://download.eclipse.org/technology/epp/packages/galileo
My Log Entry:
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2010-08-11 16:16:31.599
!MESSAGE Failed while installing Dynamic Web Module 2.5.
!STACK 0
at org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.createWeb25DeploymentDescriptor(WebFacetInstallDelegate.j ava:247)
at org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallDelega te.execute(WebFacetInstallDelegate.java:117)
!SESSION 2010-08-11 16:22:49.062 -----------------------------------------------
eclipse.buildId=
java.version=1.5.0_22
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Re: Failed while installing Dynamic Web Module 2.5 [message #988832 is a reply to message #490014] Mon, 03 December 2012 06:34 Go to previous message
No real name wrote on Tue, 06 October 2009 17:21
JST Server UI
JST Web UI
JST Server Adapters
WST Server Adapters
This helped in my case with following stack trace:
!MESSAGE No IModelProvider exists for project P/hello-seam of version: Dynamic Web Module 2.5
!STACK 0
java.lang.NullPointerException: No IModelProvider exists for project P/hello-seam of version: Dynamic Web Module 2.5
Thanks Smile
Previous Topic:Eclipse freezes when opening XML schema Editor
Next Topic:Problem with update to version 3.4.1
Current Time: Sat Aug 23 07:14:45 EDT 2025
Powered by FUDForum. Page generated in 0.05785 seconds
