Home » Eclipse Projects » Rich Client Platform (RCP) » How to disable closing of Welcome screen
How to disable closing of Welcome screen [message #464465] Wed, 07 March 2007 17:14 Go to next message
I have an RCP application that I license via software keys. For new
(e.g., currently unlicensed) users, I enable only a small bit of
functionality -- the ability to register/license the software.
I have a custom Intro plugin that tells users what to do if they're
running unlicensed. I only have a couple of actions defined in this
case -- exit, register, about.
I would like to disable closing of the Welcome screen in this case. Is
there a way of doing that programmatically. If the user is running a
licensed/registered copy, then the Welcome screen should then be closable.
Thanks!
sharing initialization data across Editors [message #464466 is a reply to message #464465] Wed, 07 March 2007 21:40 Go to previous messageGo to next message
Originally posted by: cszamudio.msn.com
Hi. I am having trouble figuring this one out and I'm wondering if anyone
has solved this.
What I'd like to be able to do is on RCP application startup, download some
dynamic initialization information from a database and share this data
across the views in a Perspective. Any suggestions on where I can place
this data so that it is accessible to any instance of an Editor? Thanks.
Carlos
Re: How to disable closing of Welcome screen [message #464468 is a reply to message #464465] Thu, 08 March 2007 03:31 Go to previous messageGo to next message
Originally posted by: peter_ossipov.mail.ru
Hello!
Well, you do not have to mess with welcome page.
Before the workbench appears you can show your own dialog asking to
register and if registered you can start your application.
This is how it is done with login, for example. I think you can put your
dialog in IPlatformRunnable#run() before starting the workbench, but I
do not remember that for sure. All I know is that it can be done that way.
> Is there a way of doing that programmatically. If the user is running
> a licensed/registered copy, then the Welcome screen should then be
> closable.
> Thanks!
two mode of rcp application..? [message #464482 is a reply to message #464468] Thu, 08 March 2007 08:35 Go to previous messageGo to next message
Originally posted by: fermi.inetmon.com
It possible to have like two mode of operation of rcp application. So it
will receive arguments from user and based on the argument then the
application is run either in console mode or GUI mode (standard).
i.e., Application.exe -nogui ===> console mode
Application.exe -gui ===> GUI mode.
or maybe if I can call the main RCP app class, the one that implements
IPlatformRunnable, this things can worked..
any idea..?
Fermi
Re: How to disable closing of Welcome screen [message #464486 is a reply to message #464468] Thu, 08 March 2007 16:54 Go to previous message
Ah, thanks. I'll look into that.
RN
Peter Osipov wrote:
> Hello!
>> closable.
>> Thanks!
Previous Topic:Problem with the Selection Service
Next Topic:TreeViewer and scrolling
Current Time: Fri Oct 24 15:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.04048 seconds
