Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Custom Control Traversal
| Custom Control Traversal [message #450513] |
Mon, 14 February 2005 14:30  |
I am having trouble understanding focus traversal in a custom control. I
have a custom control that extends composite. My custom control contains
three other custom controls. I want to traverse these custom controls in
order as a tab group.
I have played around with the few things I have found in this forum
(archive) to help me get a grasp on understanding traversal.... however I
am coming up more confused than when I began.
Do I need to implement traversal on my own (simply setting the tab list
does not do the trick)? If so, do I do this in a traverse listener for
each control in my composite or in a traverse listener for for my custom
control (composite)? Do I do this using the traverse() method or is the
setFocus() method prefered?
| Re: Custom Control Traversal [message #450588 is a reply to message #450554] |
Tue, 15 February 2005 13:42   |
> Is focus ever supposed to go to the parent of the three other custom
> controls?
No, just the custom child controls.
Here is the design of my custom control:
Composite comp0 - is the parent.
Composite comp1 - is a child of comp0.
Composite comp2 - is a child of comp0.
Composite comp3 - is a child of comp0.
comp1 contains 2 Labels
comp2 contains n Canvas (where n >= 1; generally 1 to 3)
comp3 contains 1 Button
I want focus order to be:
comp1, comp2(canvas[0]), comp2(canvas[1]), ..., comp2(canvas[n]),
comp2(Button);
> Have you seen Snippet21? It might be exactly what you are looking for to
> use with the three controls.
Yes, this is where I started.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet21.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
> If you could post a small stand alone snippet, we could probably help you
> more.
I will work on getting one posted. BTW, I am developing for PPC.
> "Scott Pelton" <scottp@worldpac.com> wrote in message
> news:cuqu80$am1$1@www.eclipse.org...
| Re: Custom Control Traversal [message #450642 is a reply to message #450588] |
Wed, 16 February 2005 08:58   |
Ok, I'll wait for the snippet.
news:cutfrd$bmn$1@www.eclipse.org...
> > controls?
> comp2(Button);
to
you
> > more.
I
contains
in
I
custom
| Re: Custom Control Traversal [message #450722 is a reply to message #450642] |
Wed, 16 February 2005 19:34   |
Here is the snippet.....it is quite long...
the main class "snippet_DPPanel" plus five classes (1 inner and 1 inner
inner)
import java.util.*;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
* @author spelton Feb 16, 2005
* Snippet to test custom control (DPPanel)
* I am having trouble getting tabbing to work.
* NOTE1: to be run on pocket pc
* NOTE2: if you pass in an integer n on the command line then n controls
will be created
* (recommend n=5) otherwise two controls are created.
* NOTE3: there is no functionality in this snippet
* (except for a popup menu appearing upon clicking down arrow button)
public class snippet_DPPanel
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display, SWT.NONE);
shell.setLayout(new GridLayout());
Menu bar = new Menu(shell, SWT.BAR);
shell.setMenuBar(bar);
int cnt = 2;
try
cnt = Integer.parseInt(args[0]);
catch(Exception e)
//just test data
DPPanel[] dpp = new DPPanel[cnt];
for(int i = 0; i < cnt; i++)
dpp[i] = new DPPanel(shell, "test"+i, i+1);
dpp[i].setLayoutData(new GridData(GridData.FILL_BOTH));
dpp[0].setFocus();
shell.open();
while(!shell.isDisposed())
if(!display.readAndDispatch ()) display.sleep();
display.dispose();
class DPPanel extends Composite
ImageLabel imglblIdentifier;
Label lblStatus;
BoxesPanel boxesPanel;
FormData fd1;
ArrowButtonPanel abPanel;
Menu popupMenu;
MenuItem itemPartial, itemLater, itemCancel, itemReset;
int iBoxes;
* Constructor for DPPanel.
* @param arg0 - Composite to which this DPPanel is a child of.
* @param sID - identifies this delivery/pickup (i.e. Pick Ticket #)
* @param iBoxes - number of packages
* Generic constructor
public DPPanel(Composite arg0, String sID, int iBoxes)
super(arg0, SWT.NONE);
this.iBoxes = iBoxes;
//creat layout stuff
FormLayout fl = new FormLayout();
fl.marginWidth = 2;
fl.marginHeight = 2;
this.setLayout(fl);
FormData fd0 = new FormData();
fd0.left = new FormAttachment(0 ,2);
fd0.top = new FormAttachment(0 ,2);
//add identifier label
imglblIdentifier = new ImageLabel(this, SWT.LEFT);
imglblIdentifier.setImage(null);
imglblIdentifier.setText(sID);
imglblIdentifier.setLayoutData(fd0);
FormData fd2 = new FormData();
fd2.top = new FormAttachment(0,-4);
fd2.right = new FormAttachment(100, 0);
//add arrow button
abPanel = new ArrowButtonPanel(this);
abPanel.setLayoutData(fd2);
//do popup menu stuff
popupMenu = new Menu(this);
itemPartial = new MenuItem(popupMenu, SWT.PUSH);
itemPartial.setText("Partial");
itemLater = new MenuItem(popupMenu, SWT.PUSH);
itemLater.setText("Later");
itemCancel = new MenuItem(popupMenu, SWT.PUSH);
itemCancel.setText("Cancel");
itemReset = new MenuItem(popupMenu, SWT.PUSH);
itemReset.setText("Reset");
fd1 = new FormData();
fd1.top = new FormAttachment(0,-4);
fd1.left = new FormAttachment(30, 2);
fd1.right = new FormAttachment(90, 0);
boxesPanel = new BoxesPanel(this, iBoxes, 0);
boxesPanel.setLayoutData(fd1);
//add listeners
addListeners();
public void setBackground(Color clr)
super.setBackground(clr);
imglblIdentifier.setBackground(clr);
abPanel.setBackground(clr);
boxesPanel.setBackground(clr);
void addListeners()
this.addDisposeListener(new DisposeListener()
public void widgetDisposed(DisposeEvent e)
this.addListener(SWT.Traverse, new Listener()
public void handleEvent(Event e)
switch(e.detail)
/* Do tab group traversal */
case SWT.TRAVERSE_ESCAPE:
case SWT.TRAVERSE_RETURN:
case SWT.TRAVERSE_TAB_NEXT:
case SWT.TRAVERSE_TAB_PREVIOUS:
case SWT.TRAVERSE_PAGE_NEXT:
case SWT.TRAVERSE_PAGE_PREVIOUS:
e.doit = true;
break;
this.addListener(SWT.FocusIn, new Listener()
DPPanel.this.redraw();
this.addListener(SWT.FocusOut, new Listener()
abPanel.ab.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
showPopupMenu();
abPanel.ab.addKeyListener(new KeyAdapter()
public void keyDown(KeyEvent e)
if(e.character == SWT.CR) showPopupMenu();
void showPopupMenu()
if(popupMenu.isVisible()) return;
Rectangle rect = abPanel.ab.getBounds();
rect = Display.getCurrent().map(abPanel.ab.getParent(), null, rect);
int x = rect.x;
int y = rect.y + rect.height;
//note: menu.getSize() will be available in SWT3.0 M8
//which may not help here if it only returns size of a visible menu
//see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=48341
//show popup menu
int xAlign =54;
popupMenu.setLocation(x-xAlign, y-1);
popupMenu.setVisible(true);
* INNER class
* control that represents the number of pkgs
class BoxesPanel extends Composite
BoxButton[] bbArray;
int iBoxes;
* @author spelton Nov 24, 2003
* CONSTR
public BoxesPanel(Composite arg0, int iB, int iL)
RowLayout rl = new RowLayout(SWT.HORIZONTAL);
rl.marginWidth = 2;
rl.marginHeight = 2;
this.setLayout(rl);
this.iBoxes = iB;
int n = 0;
if(iL > iB) n = iL - iB;
bbArray = new BoxButton[iBoxes+n];
//do boxes up to pkg count
int i = 0;
for(; i < iBoxes; i++)
bbArray[i] = new BoxButton(this, i);
bbArray[i].setLayoutData(new RowData(17,17));
switch(e.detail)
e.doit = true;
break;
BoxesPanel.this.redraw();
public void setEnabled(boolean b)
super.setEnabled(b);
for (int i = 0; i < bbArray.length; i++)
bbArray[i].setEnabled(b);
* INNER INNER class
class BoxButton extends Canvas
final static int PKG_NOT_LOADED = 20;
int iState = PKG_NOT_LOADED;
String sID;
private boolean bEnabled = true;
Color clrTopTri;//previous bckgrnd color
* @author spelton Nov 26, 2003
* CONSTR
public BoxButton(Composite parent, int idx)
super(parent, SWT.NO_BACKGROUND);
this.sID = Integer.toString(idx+1);
clrTopTri = getBackground();
addListeners();
* @author spelton Feb 9, 2005
void addListeners()
this.addPaintListener(new PaintListener()
public void paintControl(PaintEvent e)
paint();
switch(e.detail)
e.doit = true;
break;
BoxButton.this.redraw();
* override setEnabled
bEnabled = b;
paint();
public boolean isEnabled(){ return bEnabled; }
* draw this box button
void paint()
GC gc = new GC(this);
gc.setBackground(getBackground());
gc.setForeground(getForeground());
gc.setLineWidth(this.isFocusControl() ? 3 : 1);
//draw box border
gc.drawRectangle(0, 0, 16, 16);
//draw box id - package number
String fnt_name = gc.getFont().getFontData()[0].getName();
Font f = new Font(Display.getCurrent(), fnt_name, 7, SWT.NORMAL);
gc.setFont(f);
Point pt = gc.stringExtent(sID);
gc.drawString(sID, 8-pt.x/2, 8-pt.y/2, true);
f.dispose();
gc.dispose();
class ArrowButtonPanel extends Composite
Button ab;
* CONSTR
public ArrowButtonPanel(Composite arg0)
rl.marginWidth = 0;
this.setLayout(rl);
ab = new Button(this, SWT.ARROW | SWT.DOWN);
ab.setLayoutData(new RowData(17,17));
addListeners();
this.setTabList(new Control[] {ab});
void addListeners()
switch(e.detail)
e.doit = true;
break;
ArrowButtonPanel.this.redraw();
class ImageLabel extends Composite
Label lblImage, lblText;
* Constructor for ImageLabel.
* @param arg0
* @param arg1
public ImageLabel(Composite arg0, int arg1)
super(arg0, arg1);
fl.marginWidth = 1;
fl.marginHeight = 1;
this.setLayout(fl);
FormData fd00 = new FormData();
fd00.left = new FormAttachment(0,0);
fd00.top = new FormAttachment(0,0);
//add image label
lblImage = new Label(this, SWT.CENTER | SWT.NO_FOCUS);
lblImage.setLayoutData(fd00);
fd0.left = new FormAttachment(lblImage, 2);
fd0.top = new FormAttachment(0,0);
//add text label
lblText = new Label(this, SWT.LEFT | SWT.NO_FOCUS);
lblText.setLayoutData(fd0);
addListeners();
* @author spelton Dec 17, 2004
void addListeners()
//underline text
lblText.addPaintListener(new PaintListener()
Point p = e.gc.textExtent(lblText.getText());
e.gc.drawLine(0, p.y-1, p.x, p.y-1);
switch(e.detail)
e.doit = true;
break;
ImageLabel.this.redraw();
//draw focus border
paint();
* @author spelton Feb 8, 2005
void paint()
if(isFocusControl())
Rectangle r = getBounds();
gc.drawFocus(0,0,r.width,r.height);
else
gc.setForeground(getBackground());
gc.drawRectangle(0,0,r.width,r.height);
gc.dispose();
* @author spelton May 27, 2004
public void setImage(Image img)
lblImage.setImage(img);
public void setText(String s)
lblText.setText(s);
lblImage.setBackground(clr);
lblText.setBackground(clr);
>> > controls?
>> comp2(Button);
> to
> you
>> > more.
> I
> contains
> in
> I
> custom
| Re: Custom Control Traversal [message #450756 is a reply to message #450722] |
Thu, 17 February 2005 13:25  |
Yikes ... that's a lot of code. Ok, it was impossible for me to know if it
was working but when I added key listeners to the various components, I was
able to tab around. You need to add a key listener to a control or it won't
get focus (because there is nobody processing keys).
news:cv0org$n87$1@www.eclipse.org...
> inner)
> import java.util.*;
> will be created
> int cnt = 2;
> try
> catch(Exception e)
> //just test data
> dpp[0].setFocus();
> shell.open();
> display.dispose();
> Label lblStatus;
> FormData fd1;
> Menu popupMenu;
> int iBoxes;
> fl.marginWidth = 2;
> this.setLayout(fl);
> //add arrow button
> //add listeners
> addListeners();
> void addListeners()
> switch(e.detail)
> e.doit = true;
> break;
> showPopupMenu();
> int x = rect.x;
> //show popup menu
> int xAlign =54;
> * INNER class
> int iBoxes;
> * CONSTR
> rl.marginWidth = 2;
> this.setLayout(rl);
> this.iBoxes = iB;
> int n = 0;
> int i = 0;
> switch(e.detail)
> e.doit = true;
> break;
> * INNER INNER class
> String sID;
> * CONSTR
> addListeners();
> void addListeners()
> paint();
> switch(e.detail)
> e.doit = true;
> break;
> bEnabled = b;
> paint();
> void paint()
> //draw box border
> gc.setFont(f);
> f.dispose();
> gc.dispose();
> Button ab;
> * CONSTR
> rl.marginWidth = 0;
> this.setLayout(rl);
> addListeners();
> void addListeners()
> switch(e.detail)
> e.doit = true;
> break;
> * @param arg0
> * @param arg1
> super(arg0, arg1);
> fl.marginWidth = 1;
> this.setLayout(fl);
> //add image label
> //add text label
> addListeners();
> void addListeners()
> //underline text
> switch(e.detail)
> e.doit = true;
> break;
> //draw focus border
> paint();
> void paint()
> else
> gc.dispose();
> lblText.setText(s);
> >> > controls?
> >> comp2(Button);
for
> > to
> > you
> >> > more.
control.
> > I
> > contains
controls
> > in
however
> > I
list
for
> > custom
the
Current Time: Wed Oct 29 20:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.03980 seconds
