| ECollections.setEList() does not minimize notifications [message #424293] |
Wed, 22 October 2008 08:14  |
I was just confronted with the method
org.eclipse.emf.common.util.ECollections.setEList(EList<T>, List<? extends
T>)
At the end, the list is truncated by removing one item after another,
causing one notification for each item.
Instead, removeAll() should be used, since it creates just one single
notification of type ADD_MANY:
eList.removeAll(eList.subList(index, eList.size() - 1);
Of course this requires building the subList, but the goal is minimizing
notifications.
Or are there reasons not to do this?
Kind regards, Sebastian
| Re: ECollections.setEList() does not minimize notifications [message #424296 is a reply to message #424293] |
Wed, 22 October 2008 08:26   |
Sebastian,
Comments below.
Sebastian Paul wrote:
> extends T>)
> causing one notification for each item. Instead, removeAll() should be
> used, since it creates just one single notification of type ADD_MANY:
I'm not sure how this would behave if the list has duplicates...
> minimizing notifications.
We don't really minimize the other adds and removes up to that point.
One might argue that we should...
The duplicates issue would concern me, but eList.subList(index,
eList.size() - 1).clear() should work though, right?
| Re: ECollections.setEList() does not minimize notifications [message #424302 is a reply to message #424301] |
Wed, 22 October 2008 11:46  |
Sebastian,
Good point. It would just use an iterator and be no better. We can't
make any assumptions about the implementation class behavior, so that
doesn't help. We could specialize removeRange to be similar to how
removeAll is specialized. That would definitely help, in combination
with clearing the subList. But the rest of the adds and removes aren't
optimized for producing ADD_MANY and REMOVE_MANY. It looks like quite a
bit of work to do all that optimally... I suppose it's reasonable to
argue the work would be done only once whereas the cost of suboptimal
notifications scale. The logic involved in minimizing the number of
modifications and hence notifications will definitely be slower though...
>> Sure, but as far as I can see, it would also cause notifications for
>> each removed item.
> Maybe some ELists should overwrite
> java.util.AbstractList.removeRange(int, int)?
FUDForum. Page generated in 0.04104 seconds
